Question about Edifier Audio Players & Recorders
I am using the Edifier Multimedia Speaker m3300, and no sound plays from either speaker. It is analog output, so it doesn't need drivers, it is the only audio device plugged in, I have tried motherbo
Different ports, restarting computer, re-checking and re-doing connections
2 Suggested Answers
  • 238 Answers
SOURCE: No sound playing from either speaker on the Edifier Multimedia Speaker M3300 setup.
Go to http://www.edifier.ca/french/speakers/m3300/m3300-EN-FR-manual.pdf and check the troubleshooting guide. I notice it says to check to make sure the mute button on the remote is off. Try it without the remote plugged in, also. Try hooking up another device with a headphone jack like an mp3 player. The only other thingI can think of would be a blown fuse, which sometimes lets a small signal through with some amps, but I don't see any fuse holder.
Posted on Dec 09, 2014
Testimonial: "I followed the troubleshooting guide, and nothing works on PC. My MP3 player works though."
Dec 09, 2014 | Edifier Audio Players & Recorders
Edifier m1350
As long as the woofer is functional, get a pair of 8 Ohm matching speakers from Radio Shack.
Jan 09, 2014 | Edifier Audio Players & Recorders
I don't sound from my left Edifier M1250 speaker
If possible, swap the speakers side for side. If that same speaker does not work on the opposite side, the speaker is likely defective. However, the connection to your computer could be bad, causing one channel to drop out.
Dec 29, 2013 | Edifier M1250 2.0 Multimedia Speaker...
One speaker very quiet
The first thing to do is to see if the problem is the computer's output or inside the speaker / amplifier. This can be done easily by removing the speaker plug from the computer's audio output jack and plugging it into a stereo device with the same size jack (likely a stereo 3.5mm type).
You will probably find that many devices support this plug. Check your phone, MP3 player, iPad, iPod, etc. Turn the volume on the speaker (if equipped) DOWN to minimum and the volume of the source device to about 1/4 -to 1/3 of the way up. Choose a source (MP3, etc.) and PLAY. Slowly turn up the volume on the speaker until it can be heard comfortably. Compare the sound from one speaker to the other. If the sound level is equal, the problem lies with your computer. If the sound is louder on one than the other, the problem is with the speakers. Once you know which is the problem, you can see about repairing / replacing the damaged parts.
Oct 24, 2013 | Klipsch Edifier E3350 2 Speakers
We fixed the speakers to my Led tv but the spakers didnt work i cant hear any noise what is the problem guys i need your help pls
Firstly check your power cord which is connected with your speaker.
secondly, check your audio and video output connector i mean there are many color it have like red, yellow, white etc. So placement your av line jack in right connector. I hope it will be work if it functional. Thanks
Nov 05, 2012 | Edifier M1380 Multimedia 2.1 Speaker
We fixed speakers to my tv but so sound is heard
look first to see if a dvd etc connected to a rear input gives sound.
Nov 05, 2012 | Edifier M1380 2.1 Multimedia Speaker...
I fixed the speakers to my Led tv but no sound can be heard
Nov 05, 2012 | Edifier M1380 Multimedia 2.1 Speaker Two...
Trying to connect BA735 speakers to a MacBook? No sound? Are they compatible?
Those speakers were originally supplied with Gateway computer system that had sound cards with digital outputs. While some versions had analog and digital sound inputs, most often the speakers had digital input only. The on-board sound in the eMachines is analog output only, so the speakers are most likely not compatible with your computer. If you want to use those speakers, you will need to locate a PCI sound card with digital output.
It's a matter of the output from the computer's sound card (built-in) being incompatible with the speaker input. The card is sending out analog sound wile the speakers are expecting digital input. Downloading a driver won't help because that doesn't fix the root problem. You need to get speakers designed for analog input, or a sound card with digital output. As it stands now, your computer just can't use those speakers.
Since your using a MacBook there is no option for this Pci Digital Sound Card.
Feb 03, 2011 | Boston Acoustics BA735 Computer Speakers
My speakers will not play on my computer
Mar 08, 2009 | Boston Acoustics BA735 Computer Speakers
59 people viewed this question
Top Edifier Audio Players & Recorders Experts
David Payne
David Payne
Robert Graf
IT Solution
IT Solution
Are you an Edifier Audio Player and Recorder Expert? Answer questions, earn points and help others
