Hi, I have a nice master B150D that ran flawlessly last season,brought it out this year replaced nozzle,spark plug,new fuel. Fired it up ran for 30 sec. pop's the circuit breaker,reset,runs 20 sec. pop's breaker,runs 20 sec. pop's breaker. Motor runs quit no drag,transfer output seems good healthy blue spark,by-passed fire-eye that checked out good,circuit breaker seems to be working, unit had an older 20 ft. cord which was replaced with new 20 ft. one. Sure could use some help.K1 kerosene is the fuel.
If a circuit breaker pops i assume its an RCELD or is it a MCB type
it is some leakage to earth somewhere in the electrics
if it runs and pops the breaker
and you can plug it in and it will sit there
then i assume its something do do with the fan system
or ignitor . driver system
look for sources of leakage to earth
and you could measure the peek current it uses with a multimeter inline
set to AC amps
anyway its defo not a gonner just some bad electrics
Posted on Dec 10, 2014
4 Suggested Answers
tbugger
  • 232 Answers
SOURCE: my DESA C100D kerosene heater quits after running a while. It may
Emery- there are 2 types of filters used in the spark plug heaters.. Most likely yours is a long cylindrical type which is hidden inside the pickup tube that drops into the tank. These filters tend to get gummed up with a black, tar type goo that restricts fuel flow & starves the flame. The other is a lawnmower type filter. Go to this page for pictures of both types of filter.
The filter is probably the problem. The flame goes out due to lack of fuel, then the photocell shuts the heater down due to lack of flame.
Don't rule out water in the fuel. Water will cause a flameout condition, also.
Posted on Dec 20, 2008
heatman101
  • 43501 Answers
SOURCE: I HAVE A MASTER MODEL B165TT FORCED OIL FIRED
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 12, 2011
heatman101
  • 43501 Answers
SOURCE: I have a Dayton kerosene
heatman101
Posted on Feb 20, 2011
Lawn mowers
Maybe it need a spark plug
May 08, 2013 | Garden
KTM 105 SX spark plug fails every ride???
Hi, Sagi nice novella and the usual suspects are:
1. Fuel mixture too rich or enrichner left out too long.
2. Faulty spark plug.
3. Incorrect spark plug for the engine type or service.
4. Piston rings badly worn or broken.
5. Valve guides are badly worn and/or seals worn, crushed or have come off the valve guide and are pumping oil through it.
6. Spark plug cable weak or leaking check for spark jump in the dark.
7. Faulty ignition coil.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.ktmforums.com/forums/two-strokes/1966-solution-fouling-spark-plugs.html
Why Does My Dirt Bike Keep Fouling Spark Plugs
KTM 85sx 105sx service manual repair 2004 2009 85 sx 105 sx Download... $8 cheap
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 85 105 SX Owner Manual
Mar 11, 2017 | 2007 KTM SX 105
My 10 year old weedeater hedge trimmer ran fine last year when I put it away for the season. When I tried to start it this year it wouldn't even fire. I put fresh fuel mix in and a new spark plug and...
I would check for spark and check the fuel lines, especially if fuel is left in it. Also if fuel left in you will have to empty the lines and carburetor or pull it enough to clear. Another thing to consider is that if fuel was left in it that the carburetor may need a rebuild, replacing the diaphrams.
I hope this is helpful for you.
Aug 19, 2011 | Weedeater 19 in 25cc Gas Hedge Trimmer
Hi I have a 22 hp briggs in a husqvarna rider. Started running a little rough at season end last year. This year it started, but ran only about 2-3 min, then would not start at all, put in new plugs (old...
This a common problem after they have set up over the winter. Water has probably condensated in your gas tank and now it is in the gas line. The tank should be drained of old gas and the gas line to the carb should be removed from the tank and blown out with compressed air to remove all old gas/ water. Attach the gas line back to the tank and refill the tank with new fuel. This should take care of the problem. To avoid this next time, just fill your gas tank to the top at the end of the season and leave it full through the winter.
Mar 28, 2011 | Briggs & Stratton Briggs Stratton Intek V...
HISTORY: Here is what happened last summer. The goldwing interstate 1200 (1985) ran fine. I stoped to eat and it would not start, turned over fine, but backfired loud, several times. after setting a...
Hi, they used points and condensors on the very early gl1000' but your model has electronic ignition and does not use points and condensors, more the pitty in the old days you had points condensors and ignition coils, if you had a problem it was far easyer to trace the fault, but now with pulse generators etc its more difficult to diagnose without diagnostic equiptment, and to expensive to re
Feb 27, 2011 | Honda GL 1200 Interstate Gold Wing...
Echo CS600P saw, brand new, ran it last weekend for about 30 minutes. Started and ran flawlessly. Trying to start today and it seems as if it is flooded. I've taken off the spark plug, turned it upside...
Try a new spark plug and make sure gap is .030.and check the air clener and make sure it is not plugged up.you can clean it with soap and water then dry it out.if this doe,s not work you have a carb problem.
Dec 23, 2010 | Echo CS600P Gas Chainsaw 20 Inch
Pro 42CC 2 Cycle Chainsaw, 18": New gas, clean plugs..Ran fine last year, won't st...
Check for a plugged fuel filter and defective fuel lines. Make sure the carburetor fasteners are tight. Check for spark at the plug--it should be blue and snappy with a new plug. If ok, squirt in some fuel mix in the plug hole, replace the plug, and see if it will pop a couple of times. If ok, make sure the primer bulb draws fuel into it after several pumps. If still won't run, remove the lower chamber of the carburetor and check the diaphragm for flexibility and no holes. Hope this helps!
May 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2150 very hard to pull start..first time this season trying to start...seems like too much compression...pulls nice and easy with spark plug removed..with the spk plug in...very hard to pull..still...
If fuel leaked into the engine over the winter, it could cause very hard-to-pull problems. Remove the plug, ignition off, with the cylinder/head down, pull it through vigorously to see if expels any fuel. Replace last year's fuel with fresh fuel mix. It's a good idea to allow the engine to run out of fuel before storage. Does this engine have a compression release? If so, it may need cleaning to work properly. Hope this helps!
Apr 20, 2010 | Garden
Hard wick
runnig the heater too low on kerosene causes the wick to dry out an char and make sure the wick adjustment is working properly and lowering it enough to get saturated
Jan 03, 2009 | Corona 23-DK Compact Heater
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
