Question about Elite Home Security
I have a elite miracle one gate opener that only has 7-8 volts to the drive motor. transformer has 27 volts coming out into the controll panel any ideas
7-8 volts to drive motor 24 volts out of transformer, gate will not open
4 Suggested Answers
  • 68 Answers
SOURCE: The outgoing gate has a positive stop on it, but
Well it seems that their could be a limit switch problem. also if someone has replaced the limit switch they could have not connected the wires back up correctly. if your wiring and switch are correct than you have a bad circuit board. my opinion is to not even fix it and replace the whole opener with a gto-pto gp sl50 They are the most reliable opener out so far and come with all the features that elite charges extra for like a battery backup for instance.
Posted on Oct 24, 2009
  • 10865 Answers
SOURCE: How do I program a new Liftmaster 371LM one button
hello. The programing is the same for both gate openers and garage door openers. Basically you will push the smart button on the gate opener so that it is blinking and then push the button on the remote while it is in close proximity to the gate opener. Here are pix and diagrams for your use. http://www.liftmaster.com/consumerweb/pdfdocs/114A4109.pdf
http://www.liftmaster.com/consumerweb/pages/accessoriesmodeldetail.aspx?modelId=806
Posted on Aug 30, 2010
  • 32 Answers
SOURCE: I have a Miracle One gate opener and, as I've done
The memory could have been somehow corrupted. I would suggest that you call in an experienced person to reset and reprogram the open/close positions.
Hope this helps :)
Posted on Jan 01, 2011
Miracle 1 elite gate opens on power loss. Can I change that to not open on power loss?
I would think it has to open when power is lost as how are you going to escape if there is an emergency.
May 16, 2017 | Elite Home Security
I replace the mothrboard on elite slidding gate but the batery loses power
Since you have a battery and it is a sliding gate, I will assume you have a Roboslide model by Elite. The battery has to be charged in order for the gate to work. The charging comes from a transformer or a solar panel. Check to make sure these have power coming out of them. Most gate operators use a transformer and if the two wires providing the voltage touch each other, it will blow the transformer. If you have a volt ohm meter you can check this. You might need to use the AC setting as well as the DC since some are 18 volt DC and others are 25 volt DC. You can do the same for a solar panel but only use the DC setting.
If this is not your issue, then make sure it is your battery draining and not something binding in either the motor or the gate. Finally, it could be the motor going out. Simply hook the charged up battery directly to the motor to check it. It should respond strongly. Reverse the leads to make the motor go the other way.
Good luck.
Mar 08, 2015 | Elite Sl 3000 Ul Sliding Gate Operator
Elite gate won't open
this system runs of of the batteries and the system is constantly charging the batteries but if the batteries go bad it will act up even if the incoming power is good.
power it down unplug the batteries and use your multi-meter to see if you have good batteries.
Aug 26, 2014 | Chamberlain Elite Miracle One Swing Gate...
Miracle one gate opener not working. Was work fine and lately not opening all the time. Now not at all. Looked and all fuses they are ok. System on light is off. only ligts on in control box are the...
Have you checked the fuses? They are small and can be difficult to see because of the thin wires. Check those first, especially the motor fuse on the lower left corner of the board.
Does you system use a wireless remote or keypad, or to open/close.
Jan 06, 2014 | Chamberlain Elite Miracle One Swing Gate...
Hi,, i have a SL3000UL slide gate opener that stops half way.
well it seems like you have checcked almost everything. there are two things that come to mind that might be your problem, check the backup battery, messure it while on charge with a multi meter, the reading should be between 13.4v and 14.0v. if this is fine then if you have beams or loops installed try replacing them as they might be faulty.
Dec 04, 2013 | Elite Sl 3000 Ul Sliding Gate Operator
Hello friends an fellow countrymen, I have a Presonus ACP88 compressor limiter with noise gates that melted the bridge, and transformer. I am trying to find a replacement transformer. Called Presonus and...
Transformers rarely need replacing unless they plugged into wrong voltage (high) source. Still, a fuse should have opened. Transformers are dipped in varnish and often look damaged when they are fine. I have Presonus mixers but those all use switching power supplies. You can probably assume that the output of the regulators are around +/-15 volts and that the DC to the regulators will need to be about 20 volts for headroom. With a single diode drop assuming FWB with center tap, we need around a 15 volts either side of center transformer... you MIGHT get by with a 27 volt center tapped... probably not a 24 volt one. Recommendation... get an original one... In audio equipment the transformers often are specially designed to run low on the saturation curve or have magnetic shielding to avoid hum. If you call Presonus, DIRECTLY ask for "Parts" or "Repair Parts" else you are likely put on hold for sales or marketing.
Sep 20, 2011 | PreSonus Acp88 8 Channel Compressor...
I have a Miracle One gate opener and, as I've done a hundred times previously without incident, I clicked remote to leave gate partially open (to take trash cans out), about 20 seconds later, the gate then...
Hope this helps :)
Jan 01, 2011 | Elite Sl 3000 Ul Sliding Gate Operator
Where is the programming button to add a Homelink equipped car?
Follow the instructions on homelink's website for programming a garage door opener with a learn button. The learn button on the miracle one is inside the control box. After you remove the cover, you'll see the radio receiver on the left side near the bottom of the control box. The learn button is near the front edge of the receiver.
Dec 28, 2010 | Chamberlain Elite Miracle One Swing Gate...
Oct 24, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Home Security Logo
74 people viewed this question
Top Elite Home Security Experts
John
jr3261
Are you an Elite Home Security Expert? Answer questions, earn points and help others
