Question about Maytag Dryers
How do i make an opening in wall for a dryer ventilation
  • Maytag Master
  • 1,253 Answers
Call a carpenter or go buy a big hole saw... both about the same price.
Posted on Dec 09, 2014
What could be the cause of the fan not ventilating the room?
Is there a switch to recirculate,or fresh air ??
May 09, 2017 | Panasonic Dryers
How can i cover ahole that was cut too large in the wall that the dryer hose goes out of?
Fit a ventilation cover to the outside wall, they are available in plastic or metal, and should solve your problem.
Jan 31, 2011 | Dryers
Not drying and vent hose is wet in the inside gas comes on!
You have what I call a humidification problem and there is probably something clogged up in the hole in the wall to wherever it goes outside. It could also be that the dryer is TOO CLOSE to the wall.
PLEASE NOTE: If the HOT air that the dryer creates is restricted from exiting the dryer, the dryer WILL NOT HEAT PROPERLY.
If you have a CLOO in the ventilation system, the heat will try to get out and it cannot. The distance from the dryer to wherever the CLOG is could bu SUCH that this clog will creat a humidification factor that actually creates humidity and all seems wet.
Nov 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 90 series Hi My dryer gets very hot in a short period of time and then turns off. Not on long enough to dry any clothes. The drum and the outside of the dryer is hot. Can you help? Thanks
Please note that if the HOT AIR that the dryer crteates is restricted from exiting the dryer because of a clooged up ventilation system or lint build up in the dryer, The ELEMENT will come on very rapidly and very bright which will eventually break the element. ALSO, please check to see if the element BROKE and as it broke it touches the stack. One way to test the ventilation system = hole on the wall to wherever the air goes outside, IS TO remove the vent hose from the BACK of theDRYER and run JUST ONE normal load to see if this works better. If all is good and the dryer works better, then your ventilation system needs cleaning. IF ALL IS STILL NOT OKAY, then check the interior of dryer to clean any LINT or as stated above, check the element
Nov 12, 2009 | Washing Machines
NO HEAT
You will find either the drier has been to close to the wall thus blocking the ventilation inlet. this in turn allows the elements to heat up excessively and blow the safety th/stat, Suggest you replace it and also check if air inlet vent is not blocked with lint. So use a testing device to see which th/stat is open circuit.(Ps. pull plug out of wall first}.
Sep 21, 2009 | Whirlpool Dryers
Dryer runs will not heat
If this is an ELECTRIC dryer, the following link explains how to troubleshoot a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Begin by verifying your input voltage at the wall receptacle. You should read 220-240 VAC across the two hot leads (the left and right slots in the receptacle). If good, remove the back cover over the terminal block of the dryer (where the power cord is installed) and plug the dryer back in. Take a reading across the RED and BLACK wires at the terminal block. If good, your problem is in the heating circuitry. If bad, you have a bad power cord.
The reason I mention the input voltage is because many people assume it is good if the dryer drum is still spinning. The drive motor which turns the drum, however, only uses half the input voltage because it runs off 110-120 VAC. The heating circuits require the full 220 service in order to operate. If you are missing a portion of the source voltage, the dryer will exhibit the same problems you describe.
Read through the link I provided and pay particular attention to the section that discusses proper dryer ventilation. Most dryer heat related problems are actually caused by poor ventilation causing the dryer to overheat to the point of failure. If you haven't cleaned your ventilation ducting anytime recently, now might be a good time. Leaving a dryer in a clogged or poorly ventilated condition will cause repeated failures of any components you might be replacing.
If you have questions along the way, let me know. I hope you find this information helpful.
Jun 11, 2009 | Dryers
My whirlpool duet does not heat up
You may have a component failure with your dryer. The following link explains:
You will also need to check the voltage at the wall receptacle to ensure it is reading 220-240VAC. Improper voltage can also cause these symptoms. The last paragraph in the link explains this.
Have you checked the dryer ventilation from the wall to where it exits your home? Do you have a lengthy dryer vent run? Simply cleaning the lint trap and the dryer hose may not be enough if you have a lengthy ventilation system. You may have to have your ventilation inspected or cleaned. A simple test to determine the cause is to remove the dryer vent hose from the back of the dryer and attempt to dry a load. The air leaving the back of the dryer should be forceful and warm (about 140 degrees F). If the air is weak, you may have a clog INTERNAL to the dryer. If the air remains cold, you may have a component failure INTERNAL to the dryer. If the the dryer functions normally with no problem drying, you have a clog somewhere in your ventilation EXTERNAL to the dryer. Try these tips and let me know. I hope this helps you.
Jan 06, 2009 | Whirlpool GEW9250 Electric Dryer
My dryer wont heat up at all. Where do we start trying to figure out what is wrong with it? Everything else is working great on it.. No noises, still running, etc.. Please help!
The following link will give you some guidance on how to troubleshoot a dryer "no heat" problem:
Most dryer heat related problems are attributed to poor ventilation. Pay particular attention to the paragraph that discusses your dryer vent ducting. If you're ventilation is clogged and you replace any defective components, those SAME components can fail again. In addition, verify you have the proper voltage at the wall receptacle, FIRST, before assuming you have bad components. I hope you find thids information helpful. Let me know if you have questions.
Dec 11, 2008 | Dryers
Burning smell coming from the dryer!
You have a serious clog somewhere in your dryer exhaust ventilation. I would recommend you STOP using the dryer immediately and clean both the interior and all the vent ducting from where it exits the dryer to where it exits the home. the burning is coming from lint build up in and around the heating element and its beginning to smolder. This is a potential fire hazard and may end up causing the heating circuits to fail. The condensation comes from the the inability of the hot air (which is mixed with humidity from your clothing) condensating inside the vent duct. The lint starts to collect and get wet to the point of saturation. Then it begins to cause water to form and leak out of the ducting and on to your floor. You do not want this condensation inside the dryer where the heating circuits are. The following link will provide with some guidance for future reference:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention the paragraph where it discusses proper dryer ventilation. I hope this helps you. Let me know if I can be of further assistance.
Sep 28, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
42 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
