Question about Music
I have a used synth, and want to use it as a controller keyboard for GarageBand and other programs.
I have an Ensoniq EPS synth which is quite a few years old. I want to find a good, high-quality Digital Audio Interface to hook up to it that can be used with my MacBook's GarageBand program. Where can I find info on what kind of interface might be best: the keyboard I have if five octave, touch sensitive, and has sampling capability and a SCSI port, MIDI IN, OUT, and THROUGH. All its samples will have to be transferred to the Mac.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,003 Answers
Https://www.google.co.uk/search?espv=2&q=macintosh+MIDI+interface&spell=1&sa=X&ei=BKrLVOGMHpKBabLCgfgN&ved=0CBwQvwUoAA&biw=1920&bih=971
Posted on Jan 30, 2015
  • 1138 Answers
SOURCE: Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Posted on Jun 02, 2009
  • 1138 Answers
SOURCE: Hook up CASIO CTK-720 to Imac with Snow Leopard (10.6.2) G-Band
Thanks Francois. This is good advice. It is posted in the problems and questions section of musical instrument repairs.
Posted on Nov 30, 2009
  • 1138 Answers
SOURCE: What do I need to record/play loops&samples w/microKorg on stage?
I'd recommend a looping pedal as the simplest solution. Check out this link:http://www.recordingreview.com/articles/blogs/67/Confusion-With-Loop-Pedals.html Consider joining. It's free and there is a wealth of good info on gear, Midi, recording etc. Let me know if this helps.
Posted on Jan 18, 2010
  • 5603 Answers
SOURCE: Problem with the Gemini Sound
In the control panel, sounds and devices, check that the device is in each list under audio, voice, and hardware tabs and that your device is the default device. If NOT in the list, the CORRECT drivers are NOT installed or not properly installed.
Posted on Jul 23, 2011
  • 5603 Answers
SOURCE: I hooked up my Mackie
It is likely that your compter is running out of time to service the audio interface. You need to turn off wireless connections, turn off all Anti-virus and antispam and anti popup software that might be running. You are probably getting underun errors.
When data is missed due to insufficient processor power/timing, this causes the sound to break up badly.
Posted on Sep 27, 2011
How do I connect my GK3 equipped guitar to an Electric Piano or Synth ?
You cannot connect a Gk3 directly to an electric piano or synth. What you have to do is connect the 13 pin DIN connecting cable from the gk3 to the input on a Roland guitar synth unit like GR 20 or the GR 55 which supplies the desired instrument tones as required. The synth can be connected via 5 pin midi cable to an external synth to provide further tones...I personally have never used a keyboard to provide extra tones because I am a guitarist so only used synth modules and not keyboard ....remember also you need an amp or pa system to hear the sound output from the guitar synth module or external module.
Aug 30, 2015 | Electric Music
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
Can a Korg CX3 Organ 61 keys be compatible with the RolandFantom XR module?
Hi, from what I can tell you cound plug your CX3 into the synth module with a 1/4 inch patch cable and run the audio through it, however I think you will be quite limited in what you can do to modify your sound.
Where the synth really works well is when you feed it digital input data. For you to be able to do that your CX3 would need midi outputs and while I don't have one, I looked it up and can see that the CX3 is too old and does not have midi capability.
Midi (musical instrument digital interface) is a common language that allows musical devices such as your fantom to communicate with other devices. A keyboard with midi running into a synth is in essence just a control surface, a way for you to input data into your synth module, it is making no sound itself, but rather outputting digital data into your synth which in turn generates the sounds you want it to. There are allot of keyboards out there that are only for this purpose and are simply controllers. For example, M-Audio Oxygen 61 - 61-Key USB MIDI Controller. I'm afraid your CX3 is just too old to be able to do this, however, I imagine some of the sounds that thing makes are very vintage and good, and modern synthesizers often times just cant reproduce that (though they are getting batter all the time). Hope that helps :)
Dec 20, 2013 | Music
No sound
no sound well it has to be used w something from garageband reason, etc u cant just plug it in and play it . so for instance garage band , you wanted the grand piano u open the grand piano and start hitting the keys. should be no problem I have the same one
May 14, 2011 | Akai MPK mini MIDI Controller Keyboard,...
I can´t find CASIO CTK-810
Vista has SO MANY compatibility problems that it MAY be futile to try finding a specific driver for thaat synth. Consider going to Windows 7. HOWEVER, a MIDI driver is a MIDI driver and anything specific to the synth is really not truly just a driver as such, but a user interface type program that may contain things like voice editors and other functions specific to the synth.
Jan 04, 2011 | Casio CTK810 61 Key Keyboard
Have a casio px 320 and trying to use it in GarageBand on my Mac OS X. Connecting USB cable from USB output on Casio to USB input on Mac doesn't work. Any help?
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
Nov 14, 2010 | Casio Privia Keyboard Case
Please teach me how to do a recording of bits with the keyboard PSR S710, it uses a USB drive, but i don't know how to use it
You need to have a basic recording program installed on your computer. If you use Apple you can use garageband. If you use Windows you can install audacity http://sourceforge.net/projects/audacity/
You will have to install the drivers of our yamaha keyboard than connect it with the usb cable to your computer and select the PSR S710 as an input in your recording program.
Mar 10, 2010 | Yamaha Music
I want to plug in a sustain pedal to my very old yamaha psr 300 keyboard but there isnt a slot. the only slot it fits into is the headphone slot, but then you get no sound! can I get an adaptor for this?
Sorry to bring the bad news but the PSR300 does NOT have a connection for a sustain pedal.
It will however recognize a MIDI command for sustain so if you had a MIDI sustain pedal that emitted controller 64 code, you could use that.
It is UNLIKELY you would want to do this as such devices are not readily availablle. If you slaved this from another synth that had a sustain pedla capabilty you could play booth together and use the sustain of the other synth.
Dec 26, 2009 | Yamaha Portable Keyboard with 61...
Nov 30, 2009 | Casio Music
Music Logo
44 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
