Question about KitchenAid Washing Machines
My kitchenaid Supurba washing keeps stopping, I have to push on the lid to get it to start again.
When the washer stops during a cycle I have to go in and lean on the lid to get it started and stay there until the washer finishes.
  • 682 Answers
Sounds like door switch has dislodged or has foreign material inside it preventing full closure.inspect clean or replace.
Posted on Dec 09, 2014
Washing machine would not start
On the lid is a switch that turn off the washer when the load pushes against the top. You may have over-loaded the machine.
Feb 26, 2014 | Indesit Washing Machines
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Top Loader stopped during spin cycle and now won't work
The lid switch cuts off power to the washer and will cause the washer to stop and not to start at all when it fails or when the lid switch strike breaks. Check the lid switch strike located on the middle right side of the lid. Replace the lids witch strike if it is broken with part number 3950298.
Push and hold the lid switch, using a screwdriver, through the hole on the right side recess of the top cover and start the washer. The lid switch actually clicks when activated.
Check the continuity of the lid switch when activated if the washer still doesn't start when the lid switch is pushed and held. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Remove the screws at the front bottom corners of the console then slightly pull the console forward to clear the console tabs from the slots on the cabinet, and then flip the console to the rear of the washer.
Disconnect the wiring harness connecting the timer to the lid switch wiring harness connector on the cabinet then using an ohmmeter, check the continuity of the lid switch while it is being pushed. Set the ohmmeter to XR1 then touch the test leads to the right and left terminals of the lid switch connector. Replace the lid switch when the resistance reads open.
Apr 06, 2010 | Washing Machines
Agitator no longer moving
sounds like you may have burned out the lid switch. if it is not working the timer thinks the lid is not closed and will not advance.
Oct 04, 2009 | KitchenAid KAWS850L Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
My washer stops working during a wash cycle leaving the drum full of water and sits there until it decides to start again. I just changed the timer and it didn't fix a thing.
sound like the lid switch put timer to spin cyc open lid pull the timer knob out and the opening that will get depressed by the lid actuator push it with a pen/pencil if works replace the lid switch
Aug 19, 2009 | Whirlpool Washing Machines
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
KitchenAid Washing machine stops mid-cycle and stays stopped
sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
May 12, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Washing Machines Logo
37 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
