Question about Kenmore Washing Machines
Kenmore washer model#110.24422300 not working. It suddenly stopped working. No cycle works: filling, spinning, agitating, etc. When turning on it just make a noise like trying to work and after 5-10 seconds the breaker of the house electric panel disconnects. It would seem to be an electric issue! ...Help please!
  • Kenmore Master
  • 1,249 Answers
Sounds like a mechanical problem. Seized drive, clutch, or motor. Or, it could be a leak: something has gotten wet that shouldn't. Or, it could be a chafed wire contacting the frame. No way to tell without digging in with test equipment and a brain. Decide if it's worth a hundred dollar (or more) repair bill. If not, time for a new one.
Posted on Dec 09, 2014
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    I have a Kenmore top loading washer model #110 and won't agitate
    First, see the Sears parts site for your washer.
    http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
    Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
    I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
    Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
    These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
    Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
    Nov 14, 2009 | Kenmore 22422 Top Load Washer
    Agitator not working 90 series model # 11026912691
    Hello aksward,
    Welcome to Fixya.
    Here are some suggestions for any Kenmore washers
    Let me know how it goes. I'm still thinking and searching my repair manuals!
    Huuum
    Please remember to leave a rating!
    KENMORE ELITE TOP LOAD
    Washer stops, won't fill, rinse or agitate
    • Check the following:
    Is the power cord plugged into a grounded 3 prong outlet?
    Is the indicator on the Cycle Control knob properly lined up
    with a cycle? Turn the Cycle Control knob to the right slightly
    and pull to start.
    Are the water inlet valve screens clogged?
    Are both the hot and cold water faucets turned on?
    Is the water inlet hose kinked?
    • Does the water level seem too low, or does the washer
    appear to not fill completely? The top of the agitator is
    much higher than the highest water level. This is normal and
    necessary for clothes to move freely.
    • Has a fuse blown or is the circuit breaker open? If problem
    continues, call an electrician.
    • Are you using an extension cord? Do not use an extension
    cord.
    • Is the washer in a normal pause in the cycle? The washer
    pauses for about 2 minutes during certain cycles. Allow the
    cycle to continue. Some cycles feature periods of agitation
    and soak.
    • Is the washer overloaded? Wash smaller loads.
    • Is the lid open? The lid must be closed during operation.
    Washer will not agitate or spin with the lid open.
    Oct 06, 2008 | Kenmore 22422 Top Load Washer
    Kenmore stack washer and dryer
    gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
    Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Washer fills/agitates and stops prior to draining
    If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
    Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
    Maytag Performa Washer spins fine but stops instantly
    Check the unit next time it is in the spin open the lid up does it do the same thing?? if so it is working ok that is the Brake in the unit doing it Job but if it is really loud it maybe going out??
    Jan 26, 2008 | Kenmore 22422 Top Load Washer
    98702 Washer Drain/Spin Dead.
    My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
    Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
    Kenmore Washer won't agitate, spin or drain
    It's not your exact model but does have some good information about the possible causes.
    http://www.shopyourway.com/questions/1099421
    Apr 07, 2017 | Washing Machines
    Agitator not turning during cycle
    Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
    Jul 09, 2007 | Kenmore 24032\24036 Top Load Washer
    Washing Machines Logo
    Sal DeAngelo
    fordexpert
    Ed Mac
