Hi my washing machine is tangling up all the washing around the agitator then going out of balance, stops spinning, lights start flashing and beeping? Please help me...
Tried re-aligning the clothes. Tried cleaning the filter. Tried putting less clothes in.
    New Friend:
  • 71 Answers
Make sure the agitator is down as far as it can go on the shaft. If it has worked itself partially off the shaft it can cause a gap that will cause your clothes to tangle around the agitator.
Posted on Dec 09, 2014
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
SOURCE: ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Posted on Sep 03, 2008
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
BIKER T
  • 909 Answers
SOURCE: spin cycle is off balance washing machine is
i dont believe it is the agitator per say. Assuming this problem has just started and doesnt have transportation bolts still attatched. Two conditions cause the imballance. 1)(if unit is a top loader) Check if all 4 shock absorber springs are well lubricated and not sticking. 2)A more involved problem which often happens, Underneath the washer, is the drive motor. on the motor, is a round pulley. this pulley needs to come off and strip further until you see a long spring. If it is not broken, clean it up using a solvent and a rag. reassemble and test. (if spring is defective, it will slip instead of grip on a spin cycle.
Posted on Sep 17, 2009
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
Simpson agitator
I have the same problem, seems as if this washer always tangles the clothes, there is really no solution.
Aug 25, 2014 | Simpson Washing Machines
Simpson encore 605
Yes its a top loader and cloths are distributed evenly at the moment. My problem is it will not agitate. Its like the brake is locked on. It spins fine but niether the drum or agitator move. the motor is trying but its cant over come the brake (i think). I have had the brake arm off but I am unsure if it needs alinging with the brake tang when putting it back together ?
Jan 05, 2014 | Washing Machines
I have a SIMPSON ENCORE 555 heavy duty washing machine. It will do a normal wash cycle, but when it comes to the spin cycle, it doesn't distribute the washing around the drum and hence won't spin. any...
Hi just read your posting.Now does the washing tangle around the agitator?In your posting you mentioned the washing not distributing around the drum.Could you confirm that your machine is a top loader for me,because the word "drum and distribute" are terms for a front loader.If your machine is a top loader which I think it is then the problem could be your brake arm or spin coil is not operating.Please reply and let me know if the clothes are tangling around the agitator.Looking forward to your reply.
Sep 07, 2010 | Washing Machines
Hoover 500M0AUS stops very frequently due to off-balance
Hi there.I'm guessing you changed the (Spin Brake Solenoid) underneath,it attaches to the brake arm,the solenoid retracts with a normal loud clunk & pulls the brake arm away..I think what is happening is the clutch spring inside that white plastic cog is not binding like it's supposed to & it's not taking the drum with it.so the agitator is spinning independantly without the drum.the clutch spring tightens in one direction for spin & loosens in the other direction for wash.either way i think your problem is in that plastic cog & clutch spring,the spring is inside that cog & hard to see.it can be repaired if your up to pulling the entire gearbox out to get to it.I hope this was helpful,it's kind of hard to explain by this method.cheers Chris
May 29, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Whilpool washer Model # LXR9445JQO During wash cycle the motor stopped working, became hot (you could smell it). Now the motor just hums and starts to get hot, you can't turn the agitator or basket by...
STOP trying to run the washer you will burn it up!!
You need to remove the agitater and make sure nothing is tangled around the shaft. If there isn't anything tangled you will need to do surgery on your washer. You will need to remove the back access panel and remove the lines from the water pump on the back "one going in and one coming out" pull the pump off the shaft and make sure that it spins freely. Hopefully the motor isn't burned up to bad from trying to run it!! have a GREAT day!
May 10, 2009 | Washing Machines
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Hoover washing machine 550mb keep stopping on spin dry cycle.
Hi are the clothes tangled up around the agitator if so the gearbox may be faulty or the brake may be worn,is it washing in both directions
Oct 09, 2008 | Hoover Washing Machines
Spin cycle
The balancer spring are detached from spinning drum out of alignment /outbalance / replace balncer spring available in apliance center.
Jan 02, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
153 people viewed this question
Top Washing Machines Experts
