Question about Kitchen Ranges
How do I remove burners from my barbeque?
I have got instructions which say to remove burners by simply removing a screw on the back of the burner with a Phillips head screw driver. Where is this screw? How do I gat to it?
  • 3,506 Answers
You need to lift off the grills first to find it/them
Posted on Dec 09, 2014
Amigaman
  • 248 Answers
SOURCE: cannot adjust flame on gas burner
Is this lp or natural gas? The screw you turned adjusts the low flame only. Did this just start, or has it always done this? Let me know.
Posted on Nov 20, 2007
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
SOURCE: Burner switches got wet, sparked, daughter put baking soda on them, and two front burners won't light.
I also got too much liquid into control switch area & had sparks. Mine needed a new electronic ignition system. I purchased my range in Jan 06 and they are covering it under warranty now, Nov 08. To open the top, unscrew 2 small screws inside the front top oven. Then unscrew all 5 burners (10 screws). Then you should be able to open the lid about 12". Repairman propped mine open with a screwdriver while he worked under there.
Posted on Nov 19, 2008
EllaWatson25
  • 725 Answers
SOURCE: back burner doesn't work looking to remove and
These burners are very simple to replace. Is yours a glass top or does it have coil elements on the top of your stove?
Either way, we can direct and guide you to complete this repair.
You will need to contact us with your model number and we can tell you exactly how to remove and replace the element. When you get your parts from us, here at Accurate Appliance & Parts Supplies, we send complete instructions when when we send the parts to you.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST Monday through Saturday.
We hope to get you cooking again soon and look forward to working with you. Thanks, Ella
Posted on Nov 22, 2009
tunde007
  • 2382 Answers
SOURCE: Hotpoint Model RGB745GET1WH, Mfg'd mid-90s. Oven
Hi, there is no way you can change the ignition coil without removing the burner pipe assembly. I would not even advise you to remove it even if you think you can because of the complex nature of the removal and installation. You need to get a gas kitchen range technician to help out...
Posted on Feb 19, 2011
I have a propane leak behind the burner control knob on my Barbeques Galore Turbo STS. Suggestions?
More than likely you will have to replace the entire burner manifold. To purchase the part, first contact BBQ's Galore 800-752-3085, to see if they have it. Depending on the age of your grill will determine that. If they can't help you try Cla Grills & Service http://www.clagrills.com/parts/barbeques-galore/barbeques-galore-parts-home.htm
I hope this helps you and thanks for choosing FixYa.
Sep 19, 2011 | Barbeques Galore Turbo STS 4-Burner with...
Need cover for Turbo STS barbeque built in grill, 32"
You can purchase it on line @ Barbeques Galore, Here's the link
http://store.bbqgalore.com/store/category/5/35/Covers
If link doesn't work when you click on it. Simply copy and paste it into your web browser.
Jan 27, 2011 | Barbeques Galore Turbo STS 4-Burner...
My turbo built in bbq has 4 burners. what do the
the burners need cleaning remove burners put them clr or clean out burner holes with a paper clip screws are air gas mixture best left as they are
Jun 21, 2010 | Barbeques Galore Turbo STS 4-Burner...
We have a Charmglow 720-0234 5 burner gas grill. Replacing the burners that rusted out but can't get the screws out of the back of the grill that holds burners in place. Ideas?
yes. These screws are literally rusted in place. Begin by squirting each one with WD-40 Penetrating Lubricant. Let that sit over night so the lube will indeed penetrate. The next day the screws may back out, if not and you can get a pair of needle-nosed locking pliers on them, back em out that way. As a last resort, drill them out. Joe
Mar 18, 2010 | Grilling
Need to find lpg jets for 6 burner aussie roaster bbq. (the australian barbeque company) Bbq roughly 6 years old.
BBQs Galore sell these in their DIY section (Aussie Roaster is no longer sold at BBQ Galore, but the burner component is a standard fit). If you have an Aussie Roaster remember there is a bobbypin on the underside of the burner locking the back end of the burner in place, a few smacks with a little hammer will push this out so the old burner can be pulled out and new burners can be put in place.
Oct 17, 2009 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Replacement of burners charmglow 810-6320B
The only way I was able to get the screws out was to use a 5/16" cobalt drill bit to drill through the center of each screw. Then, and only then, was the GrabIT screw extraction tool able to grip and remove each screw. Of course, I had to break off what was left of the burned out burners first to get easy access to the screws. To replace the burners, remove 3 screws (in an L shaped pattern) from the left side of the burner control panel. I did NOT have to remove the utility shelf to get to these screws. The control panel can then be moved forward about an inch, thereby enabling the new burner tubes to fit into their gas spouts. TIPS: It was easier for me to attach the back of the new burners before trying to attach the fronts. I used new 6-32 machine screws to attach them. You'll need to look from the bottom of the burner control panel when attaching the front of the new burners -- to see better.
Jul 13, 2008 | Brinkmann Charmglow Stainless Steel LP...
Burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Jul 04, 2008 | Ducane 30400040 Stainless Steel Grill
Replace burners
remove the cooking grates and the 5 pieces ubnder the grates covering the burners from the grill. Next remove the 4 screws on either side of the control knob panel pull it away from grill and pull the burners out from inside the grill. DO the reverse to install new burners
Apr 19, 2008 | Ducane 30400042 (LP)
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
