Question about Whirlpool Heating & Cooling
I have a whirlpool air conditioning unit and on the display screen have E4 on it and it is not working i tried resetting it i tried switching off the breaker and still nothing i read the manual and th
I have a whirlpool air conditioning unit and on the display screen have E4 on it and it is not working i tried resetting it i tried switching off the breaker and still nothing i read the manual and there is nothing about E4 in it what should i do
  • 101 Answers
WHAT IS THE MODEL #???
Posted on Dec 11, 2014
bobotfel
  • 236 Answers
SOURCE: WRAC has E4 on display
E4 means return air sensor error, if the error cannot reset may be the return air sensor is out of range or defective. But if the sensor is ok you need to replace the control board itself. The reading of return air sensor is 8k to 10k ohms @ 25deg. C temperature.
Posted on Jan 13, 2008
burzerko
  • 254 Answers
SOURCE: air-conditioning; error code: 425
Try Samsung.com
Posted on May 30, 2008
SOURCE: WA 903 and WA 10000 Portable Air Conditioning Units
http://docs.google.com/fileview?id=0B_eH0pjdeVdkYjE4ZTI1NTAtN2NhMS00NjVmLWEyZjYtZWQyNDQ3NmNiNjUw&hl=en_GB
Here's a link to the manual.
Hope this helps.
Regards, Davy
www.SidelightPhoto.co.uk Wedding | Event | Lifestyle
Posted on Feb 26, 2010
SOURCE: E4 error code on AUX mini-spit a/c unit
E9 Showing on my split unit a/c
Posted on Mar 19, 2010
toy_ladi
  • 484 Answers
SOURCE: i have waves split air condition its cooling is
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Posted on Jul 09, 2010
My portable goldstar airconditioner is showing E4 .What does this mean
E4 is a Display panel communication error.
Might have been something as simple as a Power Surge.
Power unit off for 30 minutes and then restart.
~Eddy
Air Conditioning Repair Tamarac FL
Jun 14, 2017 | Goldstar Heating & Cooling
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
My Soleus Air HM2-15R-32 displays an E4 LED when turned on. How do I reset the code.
try unplugging it from the wall for 15 seconds and then plug it back in.this normally works for me.if it doesn't work then let me knoe
Jan 23, 2013 | Office Equipment & Supplies
Error code Df and e4
E4 Outdoor activation of low pressure switch/ less suction pressure.
Check back pressure, which should be 60 PSI when ambient temp 98 degree.If not Short of gas- find leak and arrest. And do gas charging. Even due to indoor coil dust blocked also e4 arise. Clean the coil and reset it.
Nov 25, 2010 | Napoleon NHPS12 Air Conditioner
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
Take care
Jul 09, 2010 | Heating & Cooling
E4 trouble condition comes up on screen after power up
Error #4, You probably need to reset the phone by unplugging the main unit from the power source then plugging it back in abd re registering the handsets by setting them in the main cradle for about 10 seconds each. if this doesn't work try the manual if you have it still and see what E4 error means. Good Luck. Sometimes with electronics all you need to do when they wont work is unplug then and plug them back in while holding the power button on. This is amazing trick that no one wants anyone to know about. it works great on VCR's and DVD players.
Feb 11, 2009 | Uniden Cordless Phone
Base reads e4
Base unit display flashing "8" and "88" repeatedly and then after several minuteseventually displays "E4" steadily. none of the keypad inputs register - unit is basically non funtioning with the exception of the display. no dial tone on base unit or on any of the handhelds. Manuall trouble shooting guide has no suggestions for this conditions nor does it contain any error code definitions. Have unplugger and replugged unit power source (to see if it would possibly reset) with same results. Would appreciate any assistance or suggestions you could offer.
Thank you.
Jan 05, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
E4 ERROR MESSAGE ON SCREEN OF GE PORTABLE AC MODEL APE08AJM1
WATER BUCKET IS THE FAULT
the switch is more likely the cause try removing bucket and pressing lever manualy by hand then start it up again if it works you know the prob as this was mine the plastic connection aint the best
Sep 26, 2008 | GE APN10AA Portable Air Conditioner
Jan 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
219 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
