How to fix
Set will not turn on initially. Pressing the on button on the side of the set repeatedly will eventually turn on the set it will then go off 2 or 3 times. It will finally stay on. Is this a power board problem?
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Dec 09, 2014
SOURCE: samsung model lnt5271f cycles on and off 7 times when turned on
Im writing this as a public service announcement. Im seeing more and more of these posts, and I thought I would let everone know my experience.
Samsung televisions (and a few other brands) built in mid to late 2007 had a bad batch of capacitors from China. Two of these 10 volt capacitors were installed on their power boards.
When these capacitors blow, they dont hold enough juce to turn the TV on. However they tend to blow slowly. People experiencing this problem, will see thier TV taking longer to turn on, Then it will cycle off and on a few times before finnaly turning on. And lastly, when the capacitors completely blow, the TV will not turn on at all.
The capacitors are cheap, about 50 cents each. People were origonally repairing these themselves because their sets are out of warranty. It is chepaer to solder in new capacitors, because a new power board costs around $150.
However as of Feburary 2010, Samsung has recognised this as a global problem to their sets. If you call 1-800-SAMSUNG, they will set up a service technitian to come to your house and solder in shiny new 25v capacitors. They will not charge you for this, even if your TV is out of warranty. Mine was 17 months old (well out of the 12 month standard warranty).
Its a cheap fix for Samsung, and much cheaper than buying a new TV.
I would suggest registering your TV on the samsung website if not allready, waiting a day, and then calling 1-800 samsung.
They should take care of it. They have a Service Level Agreement that you should have an appointment scheduled within 48 hours of your call. In fact. I called Samsung on a Sunday, and the technitian was there by monday morning (he had a free slot), so I was very pleased with my customer experience.
Stinks that it happend, but at least its being fixed.
Posted on Mar 15, 2010
milkburp
  • 416 Answers
SOURCE: 52 inch hdtv lcd tv LN-T5271F problem turning on
You TV need some capacitors changed on the power supply. I have a tutorial on this repair published in my Tips & Tricks. You can save about $170 by doing this yourself, it's fairly simple if you can use a screw driver and a soldering iron. I hope this was helpful.
Posted on Mar 28, 2010
freelance-au
  • 131 Answers
SOURCE: I have a LCD TV SAMSUNG LNT5265F 52 and when I
Hi
A very common problem with these sets are bad capacitors that cause this problem.
If you are ok with electronics then remove the back from your tv and look towards the power supply.
Check the power supply for any Swollen or bulged capacitos on top, they may even leak a brown like liquid substance and are usually valued around 1000uf / 10v.
Replace any that you see suspect on the power board, I have fixed a lot of these and its fairly easy to do, I would however always increase the voltage of the new capacitors but ALWAYS keep the same uf.
Lets say 1000uf / 25v
Please comment and rate if this helps.
Thanks
Posted on Apr 07, 2010
  • 2318 Answers
SOURCE: My LG Plasma 42PC3D turns on and off repeatedly. I
Your plasma TV has a power supply 6709900019A. These power supplies failed due to defective capacitors. See the picture below and check the capacitors mark with the red lines. There are 10 capacitors that should be replaced even if they do not show signs of bulging/swelling on top.
The value of the capacitors is 3300uF/10V but you can use 25 volts as long as they fit in the space provided by design.
Posted on Sep 24, 2010
  • 8457 Answers
SOURCE: High voltage snap when set is turned on in the
U have tools like a soldering iron,desoldering pump or desoldering braids,solders?Can u do basic soldering and know basic electronic.Check the power supply board for dying capacitors,these capcitors alway bulges up on it tops or puffing up on it tops.These capacitors are leaking gases and dying.Replaced these capacitors are bulges up on it tops or puffing up on it tops.The tv,power will be stable and power on wright away.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Oct 18, 2010
My ws 5531 mitsubishi wont turn on I had no luck on resetting it whats the next step to turn it on
If the green light (power) comes on for a few seconds and goes off do the self check this set has.
At that time press and hold both the menu and input buttons (ON THE FRONT OF THE SET--NOT THE REMOTE) for at least 5 seconds and release both buttons.
Power light on the set will blink a 2 digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
If you have unplugged the set it clears the error buffer and you will get 1,2 error code---try if that to unplug and turn set on and when if fails repeat the check.
2,2, is most common and the easiest to fix.
Let me know by pressing the "make a comment button" here what error code is found and I will assist you.
Mar 25, 2012 | Mitsubishi Televison & Video
How do I set time on a 4Gb Sansa Fuze?
Press the MENU button to bring up the main menu. "Turn" the command wheel to select "Settings" and press the central button. "Turn" the command wheel to select "System Settings" and press the central button. "Turn" the command wheel to select "Date & Time" (it's not initially on the screen, the screen will scroll when you hit the bottom) and press the central button.
Select the desired field by "turning" the command wheel and either press the central button or click the right side of the command wheel. Change the field by "turning" the command wheel. When you have the field set properly, click the left side of the command wheel and you can then select another field.
When done, repeatedly click the left side of the command wheel to back out of the menu system.
Apr 26, 2011 | Audio Players & Recorders
The tv was working fine. Pressing the button to turn it on only turns it on briefly (sound but no picture) then it turns off. The standby/timer light blinks six times repeatedly.
I had a similar problem. I had a 52" RCArear projection tv. It would do this when I initially turned on the television, but then after a few "on/off, on/off, on/off" cycles it would stay on. Eventually it started doing it more; until finally there was a spark and that was it. The tv was dead.The bloggers called it "the blinking green light of death" (because of green light on the panel).The power board is going out.ALSO holding down the Input and Menu buttons afterward will give you some diagnostic information via 2 sets of blinking indicator lights.
You may very well have issues with capacitors on this set being that it is or very similar to the V26 chassis. Since I have spare test lamps laying around, I would normally try that first. If the lamp still would not stay lit, I would then suspect the electrical chassis (capacitors). When I suspect the chassis, I can usually verify it by pulling it out and partially disassemble it and find blown capacitors
Jan 12, 2011 | Televison & Video
Casio edifice EF534D, The seconds hand does not come back to 00 on pressing the reset button. what is the problem, how do i solve it??
Have you solved this yet? I have a reset process that sets the starting position back to 12 o'clock. Pull the crown to the second (outmost) position and then start pressing the start-stop button repeatedly. Each push will set the starting position by 1 second, until you get to 12 o'clock, then push the crown back to its normal position. Let me know if that works.
Sep 18, 2010 | Watches
HOW DO YOU SET THE CLOCK ?PIONEER DEH-P49001B CAR FM/AM/CD/MP3
See instructions below:
Initial Settings
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press FUNCTION and hold until function
name appears in the display.
3 Press FUNCTION repeatedly to switch
between the following settings:
CALENDAR (date and clock)—
WARNING TONE (warning tone)—AUX1 (auxiliary
input1)—AUX2 (auxiliary input2)—
DIMMER (dimmer)—S/W CONTROL (rear
output and subwoofer controller)—
DEMONSTRATION (feature demo)—
EVER-SCROLL (ever scroll)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down FUNCTION until the unit turns off.
Setting the date and clock
Use these instructions to set the clock.
1 Press FUNCTION to select clock.
2 Press c or d to select the segment you
wish to set.
Day—Month—Year—Hour—Minute
As you select segments of the clock display
the segment selected will blink.
3 Press a or b to set the date and clock.
Pressing a will increase the value of the selected
segment. Pressing b will decrease the
value of the selected segment.
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/415128381DEHP4900IBOperationManual0216.pdf
Aug 20, 2010 | Pioneer DEH-P2900MP CD Receiver...
My niece decided to push a rather odd sequence of buttons on the sound system and now nothing is setup correctly. while i have fixed the niece problem, i have yet to figure out why i cant fix the sound...
It's in the manual on page 59.
1 Press STANDBY/ON on the front panel to set this unit to the standby mode.
2 Press and hold
TONE CONTROL and then press STANDBY/ON to turn on this unit.
The advanced setup menu appears in the front panel display.
3 Press PROGRAM l / h to select “PRESET”.
4 Press
STRAIGHT repeatedly to select “RESET”.
Select “CANCEL” to cancel the initialization procedure without making any changes.
5 Press STANDBY/ON to confirm your selection and set this unit to the standby mode.
• This procedure completely resets all the parameters of this unit including the set menu parameters.
• The initial factory settings are activated next time you turn on this unit.
To cancel the initialization procedure at any time without making any changes, press STRAIGHT repeatedly to select “CANCEL” and then press STANDBY/ON.
Aug 14, 2010 | Yamaha HTR-6130 Receiver
My flash on my sony cybershot will not turn on. the button doesnt want to work it just beeps, but everything else works fine. Can I fix this?
Set camera on auto (green mark) and turn on flash by pressing flash sign button.
Or initialize camera by going into menu.
Aug 27, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
How do I adjust date of my watch bought from GAP
I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
Nov 12, 2008 | Watches
How to set a deh-p4000ub car radios clock
try this:
from this unit.
turns off.
2 Press SOURCE and hold until function
3 Press FUNCTION to select one of the initial
settings.
Press FUNCTION repeatedly to switch between
Clock—AUX (auxiliary input)
particular setting.
down SOURCE until the unit turns off.
Setting the clock
2 Press c or d to select the segment of
the clock display you wish to set.
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
You can turn the clock display on or off.
! Even when the sources are off, the clock
display appears on the display.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Aug 05, 2008 | Pioneer Audio Players & Recorders
Time setting
Make sure unit is off by pressing and holding the 'Source' button. Wait 3 seconds, and then press and hold the 'Source' button. Do Not Release the button! A display reading "Initial" will show. Then use the arrow buttons surrounding the 'Source' to set clock. The 'Function' button isn't involved, dispite what the manuel states.
Nov 28, 2007 | Pioneer DEH-P3900MP CD Player
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
