Where can I download a manual for my indoor fireplace with blower; Model No. xDVR6-CMNS? It's 14 years old and was installed by General Contractor for MI Homes. And they did not leave the manual behin
Circuit or valve not receiving enough power to open the vent or valve? Had someone look at it, but I'm not literate on furnaces and forgot exactly what he called it. All I know is that the fireplace pilot did not light. Now it does, however, the pip with multiple openings do not light up as they once did.
  • 56 Answers
Try this website
http://www.whitfield.com/owner-resources/literature/?pcid=1&archive=1&or=1
Posted on Dec 09, 2014
machtcl1
  • 61 Answers
SOURCE: Furnace will not heat.
Most of the Lennox G-16s that I have repaired were having problems with the gray Penn-Johnson Piggyback igniton control module.
This is best repaired by replacing the spark module. Sometimes it may be neccesary to replace the gas valve also. Lennox updated to a ROBERTSHAW ignition system. Honeywell can also be used.
Also check that there is no water in the pressure switch or tube.
Hope this helps.
Matt
machtcl1@verizon.net
Posted on Jan 15, 2009
farfield
  • 462 Answers
SOURCE: I have a coleman furnace with a pilot light that
Remove the burner and gas valve from the furnace and use compressed air to blow the area under the pilot area ans all around it. The dust and stuff usually cause a condition called "Lazy Pilot" and the flame is probably not going in the designed directions. While you have it out Id replace the thermocouple with a new one reassemble and re-lite and note the difference. The flame should be mostly Blue and no yellow (or vary little at the top end of the flame only) Orange in the top area indicates a good burning flame and the closer to the base the bluer it gets.
While you have the burner out look inside and inspect the inner heat exchanger for cracks or rusted open holes there should be none. Turn on your fan while inspecting and see if you feel the steady blow of air from it inside the heat exchanger indicating a hole. Don't confuse the air that may come down the flue with the air from the blower though. A little breeze is expected from this.
This will take care of over 90% of the problems with the "Blow out" symptom.
If you still have problems you can try and "turn up the pilot". Usually a screw close to the pilot tubing is covering the adjustment screw. Put some soap bubbles around it so you can see if it leaks or not and turn the screw out for more flame (CCW) and in (CW) for less.
Hope this helps Please grade me accordingly and good luck.
Posted on Mar 11, 2009
heatman101
  • 43501 Answers
SOURCE: Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Posted on Nov 12, 2009
  • 52 Answers
SOURCE: where can i find a manual for an old comfortmaker
Tie red and white wires together after removing thermostat from wall, if unit comes on replace thermostat, if not check limit controls for continuity, Good luck.
Posted on Mar 07, 2010
  • 308 Answers
SOURCE: Furnace blower won't turn on... Forced air gas
If it indeed started that one time for a short period then cut out, the first place that I would start would be the capacitor located in the blower compartment. The capacitor gives the motor the need kick to start, and often times stays in the circuit to help the motor run more effeciently. This could very well be the problem.
If you have the option to run the fan from the thermostat, turn the fan to the "on" position and see if it starts. If it does, then it is not the capacitor.
Hope this helps
PS Your are correct about the "sensor" turning the furnace off, it is called a high limit switch and is there for safety. It is an automatic reset device, and will reconnect power once it has cool suffeciently.
Posted on Nov 17, 2010
Testimonial: "Thank you so much for this help. We discovered a wire had worn through from the vibration of the motor, replaced the wire and good to go. Phewwww! "
Looking for a picture diagram of a Bm36Hc fireplace
[PDF]deluxe 36 manufactured home fireplaces - Hansen Wholesale
www.hansenwholesale.com/images/fireplaces/.../Intertherm_BM36HCII.pdf
36" Wood Burning Fireplaces. P/N 800,019M REV. B 04/2002. BM36HC. BM36HCD..... Refer to the minimum system height chart. WARNING: DO NOT PACK ...Missing: picture
Intertherm BM36HC Installation Instructions Manual
www.manualslib.com > ... > Indoor Fireplace > BM36HC
View and Download Intertherm BM36HC installation instructions manual online. DELUXE 36. BM36HC Indoor Fireplace pdf manual download.
Dec 20, 2015 | Heating & Cooling
MANUAL FOR HAMPTON BAY FIREPLACE
Try this website and look for your manual. Free Indoor Fireplace User Manuals ManualsOnline com I find all sorts of old manuals that people have uploaded here. Otherwise you can go to this website for the Hampton Bay customer service contact information to ask them to email or snail mail you a manual for your fireplace. Hampton Bay Customer Service Hope this helps.
May 07, 2014 | Home
I have a contractor that wants to install a 36000btu outdoor unit(model # mh080fxca4a) and two indoor 18000btu indoor units(model #mh052fnca). What would be the output of the outdoor unit? The contractor...
Yes it rated for a maximum out put of 36,000 btu (3 ton) with the right indoor fan coil units which based on the model numbers should give the 36,000 btu's combined when both fan coil units are on, otherwise 18,000 btu's (1.5 ton)per fan coil.
Aug 23, 2011 | Samsung Heating & Cooling
Have a contractor with a AWS18THX & AOS181HX In his own house & 1 year after installed the contractor is shut down. He is showing a code F1 (communications?) How can I get a manual for this? Thanks...
Mark,
Your problem lies with the communication wire from the outdoor unit to indoor unit ("S" terminal). Make sure the connections are tight and all plugs at the outdoor unit are plugged in. Also the communication wire should be 14 awg. If it too small, errors could result. Worse case send the Aquaman there.
Apr 04, 2011 | Heating & Cooling
I'm looking for a user manual for a Superior Gas Fireplace model FAK 1500. I want to know how to take off the front glass as it has become covered in a white residue.
The fak 1500 number is for the blower assembly. I found this manual for a fireplace using the blower assembly. hope it is what you are looking for. Lennox has bought out the fireplace company and there are no manuals available under superior.
Feb 11, 2011 | Heating & Cooling
Need user manual for Temco Model ADL36-2 Vent Free Gas Fireplace
need a fireplace log for temco fireplace, serial number 10807, model number adl 36-2. middle log is missing.
Dec 21, 2009 | Computers & Internet
I have a monessen LPG fireplace and the blower motor has seemed to stop working. it has a variable rotating switch on it. dont know if anyone knows where this problem is on most models like this?
The problem is likely the fan motor for the forced air blower, which means the entire blower needs replaced. The description of the problem is the same problem we had approximately two years ago when our motor was still under warranty (less than a year old). In our case the motor was replaced without charge. However, the same problem has happened this year which is extremely disappointing since we only run the fireplace from December to April intermittently because it is only a supplimental heat source for the house. You can either look up the model number and part number and order a replacement over the web (less expensive if you are DIY and know what you're doing) or see if the local LPG supplier can repair the part or replace. Good luck.
Dec 06, 2008 | Stoves Monessen Variable Thermostat...
Need Help
I have a 14 year old GTI fireplace the pilot is lite but when i push the button to turn it on , the fire place does not come on help please
Apr 03, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
