Question about Iomega 1TB Desktop USB 2.0 Hard Drive
What color should the light be on my iomega hard drive when it is plugged to my laptop?
    Genius:
  • 1,552 Answers
Green is good.
Yellow is cautionary.
Red is bad.
Posted on Jan 01, 2015
Beni S-P
  • 1006 Answers
SOURCE: iomega hard drive micro mini 8 gb
I know how to fix it but i dont know how to tell u couse my englisht is not so good..But we have another way:
be a (free) memmber of logmein.com and i need email adresse u have registred on logmein password and access windows password and i will fix it..I dont see other way to help you
Posted on Nov 05, 2007
firesnake09
  • 2923 Answers
SOURCE: Weird clicking sounds
Clicking sound on an external hard drive is an indication that it's quiting to work. You mentioned that it's just stopped working, you may need to check the Disk Management of your computer to see if you could still reformat it. To do this, please follow the steps below:
FOR WINDOWS XP AND VISTA:
1. Make sure that the HD is properly connected to the computer.
2. Right-click 'My Computer' or 'Computer' folder and then go to "Manage".
3. Locate and click Disk Management.
4. Then, take note of the drive letters that will appear on the screen.
5. While the Disk Management window is opened, unplug the HD and check which drive letter will disappear.
6. If a drive letter disappears, then that is your external 250GB HD. You may reformat it to make it work again.
NOTE: Reformatting the HD will erase all the files saved in it. You may want to bring your HD in any data recovery center to retrieve the important files. If the HD didn't show up under your Disk Management, then there's nothing that we could do but to bring your HD in to the Data Recovery to save the files.
FOR MACINTOSH OSX:
1. Connect your HD to the computer.
2. Click 'Go' (located near the Apple icon, Finder, File, Edit and View).
3. Select Utilities and then click the Disk Utility Icon.
4. Take note the drive letters and then unplug the HD.
If a drive letter disappears, that's your HD. If nothing disappears, then the computer no longer detecting the HD.
Posted on Jun 01, 2009
  • 29 Answers
SOURCE: Iomega large external hard drive doesn't show up
Well this is a tough one. I am assumeing that you have done all the normal things.
Most external hard drives are just a standard internal hard drive with a case and a IDE/SATA to USB adapter built in. When you plug in the drive and it powers up listen to the drive if you hear a clunk. Not a the happy ticking of a normal drive but a bad clunk. This can mean that the controller on the hard drive itself is bad.
If everything sounds happy then I would try replacing your power adapter. I know that the blue light goes on but most of that runs off the 5 volt leg of the power supply (I have has some hardware manufacturers actually pull the power light voltage from the USB port Grrr) most of the Large sized external hard drives use a 12 volt adapter and it can have no problem with the step down to 5 volt it may have a problem with the 12v.The 12v is what it uses to spin the drive. Unless you have one of those little drives. They use a laptop hard drive that works of a lower voltage. Most of the time you can get an adapter from Radio Shack. Be sure to bring the old one so they can get the Volts, amps, poleartity and the type of connector. It is worth a try and keep the reciept. If it is just bad I am sorry but the only way to get the data off is to break into the unit and pull the hard drive out. Then use another USB to IDE/SATA adapter to pull the data off.
Hope this helps a little.
Posted on Sep 13, 2009
Damilare
  • 358 Answers
SOURCE: dropped an Iomega 500gig external hard drive...
From what I can deduce here, it seems that you the hard drive probably has a bad sector on it.
That clicking sound that you are hearing from the Hard Drive is coming from the read/write head inside the hard drive.
In this case, what I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Posted on Nov 23, 2009
ic0729
  • 212 Answers
SOURCE: solution CD for Iomega Network Hard drive 250Gb
You get the drivers at Iomega.com and look under support to get your drivers.
REMEMBER you need to install those drivers to ONE pc and then have all your computers networked to it thru your network neighborhood. Any other questions, please write back to me, ok?
Posted on Mar 16, 2010
Laptop no longer recognizes my iomega external hard drive
How old is your OS maybe driver needs for that device for that device is corrupt try to localize and reinstall driver for external HDD
Apr 17, 2012 | Iomega Computers & Internet
Hey i brought a iomega select desktop 1.5 tb hard Problem with the Iomega 1.5TB Desktop USB Hard Drive hey i brought a iomega select desktop 1.5 tb hard drive from argos got home and transferd all info...
  • Plug your Iomega hard drive into one of your computer's USB port.
  • 2
    Click the "Start" button and go to the "Run" field. Type "Devmgmt.msc" into the Run box and press the "Enter" key.
  • 3
    Go down to the bottom of the device manager to the "Universal Serial Bus Controller."
  • 4
    Click on the little + (plus) sign to expand it. Look for an entry with a yellow exclamation point and click on it. Click the "Install the software automatically (Recommended)" button and then click the "Next" button.
  • 5
    Click the "Finish" button when the installation has finished. Go to the "My Computer" folder from your "Start" menu and locate the Iomega hard drive icon. Double click the icon to gain access to the external hard drive.
  • Mar 10, 2011 | Iomega 1.5TB Desktop USB Hard Drive
    I have an Iomega Desktop Hard Drive. Usb 2.0. 2TB. When I plug it in, the laptop does not register it. In My Computer or anything. I have rebooted the computer, tried multiple USB ports, and nothing...
    2 things that you can try is, download and run the BIOS update of the mainboard and the other is to download the software and drivers for your hard drive from their web-site...click on the link below.
    https://iomega-eu-en.custhelp.com/app/home
    Feb 23, 2011 | Iomega Computers & Internet
    Is the Iomega 1TB eGo Helium Portable USB 20 Hard Drive compatible with the sony vaio laptop???
    Yes, because it is a Plug-and-Play device, and because Windows supports Plug-and-Play.
    Dec 23, 2010 | Iomega 1TB eGo Helium Portable USB 20 Hard...
    Bought a new computer desk, shut computer down correctly, turned off all power and moved. Plugged everything back in, powered up - and everything but the iOmega Select Hard Drive is working. - It has...
    Since it doesn't show up in both pc's then the iOmega is faulty - it must have suffered a shock during transfer and this is terminal. Your only hope of recovering what's in it is to dismantle it, take out the hard disk and put it in the desktop - if even there it doesn't show up then it's dead, junk it.
    Sep 12, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
    Having saved files onto my iomega harddrive - how do i re instate files onto laptop
    if the hard drive you saved the files to is separate to your laptop you can use a usb portable drive to copy these files to then plug the usb drive into your laptop to finish installing them by selecting the file right click to open
    hope this helps
    Sep 03, 2010 | Iomega eGo160GB External USB 2.0 Portable...
    Iomega Select Desktop Hard Drive 1TB not decteted by pc
    Try Control Panel, Administrative Tools, Computer Management, Storage, Disk Management.
    Check there to see if the drive is listed, "online" and has a "Healthy" Partition.
    Dec 17, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
    Iomega Prestige 1.5TB external hard drive won't start-up properly
    Try replacing the power supply. Especially if all you get is a beep and no drive motor noise. The power supply is 12 V, 1.5 A, center positive polarity. Iomega may even replace it for free if the drive is still under warranty. But don't use the phone. Use their free chat-live service. Again, assuming the drive is still under warranty, which is a year, I think.
    May 15, 2009 | Iomega 1.5TB Desktop USB Hard Drive
    I have got a 500gb iomega hdd. I have got it plugged in to my laptop but my laptop will not reconise it. It has a blue power light flashing on the front. I have also tried it on the home desk top and its...
    I had the same problem with this hard disk. I have installed paragon disk suite 2009. I ran the software and left it running after sometime it recognised my external hard disk automatically. Dont knw how it happened but worked for me.
    Dec 19, 2008 | Iomega (33654) Limited Edition 500 GB USB...
    Iomega hard drive micro mini 8 gb
    Nov 04, 2007 | Iomega (33222) 80 GB Hard Drive
    Iomega 1TB Desktop USB 2.0 Hard Drive Logo
    98 people viewed this question
    Top Iomega Computers & Internet Experts
    Owen Barnes
    Martin Murray
    Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
