Question about LG Audio Players & Recorders
Unable to get fm radio reception on lg home theatre
None so far
    Renaissance:
    An user who is expert in 3 categories / brands.
  • LG Master
  • 924 Answers
You may have weak FM signals in your area. Do make sure you have the FM antenna attached.
Posted on Aug 10, 2015
5 Suggested Answers
SOURCE: Unlock LG home theatre model LH-SW5100
at "no disc", press "pause" and enter "314159". when it shows CODE__, enter "0" for all code, press "pause" and the power button.
Posted on May 19, 2008
SOURCE: WHY CAN'T I GET AM RADIO RECEPTION - ONLY FM??
You need a seperate AM antena for your AM radio to work. If you look on the back of the system where the FM antenna is connected you will see a AM hole for an antenna. I had same problem hope it helps!
Posted on Nov 08, 2008
CaliBoy380
  • 11 Answers
SOURCE: We have a RTD259 RCA 5 disc home theatre system
Fist off, do you have Satelite TV or cable box? if so you need to run you audio wires from the audio out on those devices. If not from your TV should be audio out L&R to you audio input on your RTD259, now you may have a specific input for your TV, or you may not. If there is no specific inout for TV, there should be at least one AUX audio and video input open on your unit. Hope this helps, Cali
Posted on Jul 25, 2009
SOURCE: i have a LG ht502 home theatre , black and white only
Sir avservice, I have also posted a problem about an HT502 DVD receiver + Home Theater. The sound won't come out of the speakers but only of the Plasma tv. But was working before. And the word "PROTECTION" is appearing on the display screen of the dvd receiver. But good quality picture on the plasma tv. Please help
Posted on Jan 25, 2010
Have a bose wave and live in a metal building. Can't get hardly any am fm radio recept. 3.5 mm antena jack. Can I get an am fm antenna? And do I need to mount antenna outside?
The Bose has the option for external antenna, but uses the AC cord as the antenna, so first try stretching your AC cord to its fullest extent in a straight line, then in different directions to see if that improves the situation. This is for FM only. The AM uses an internal ferrite rod antenna, and this is sensitive to direction, so try rotating the radio in different directions to see if signal improves on AM, and place unit as near a window as possible.
If none of this helps, you will be able to use an external antenna, and no it is not mandatory that they be mounted outside ... as long as you have room indoors. In fact, several manufacturers market indoor antennas for apartment dwellers and others under restrictions against mounting antennas outdoors.
But, logically, the best way to improve reception is the largest antenna mounted as high up and as far away from obstructions between the antenna and transmitter as possible.
Good luck.
Don Miller, CET
CET Services
Bose Wave Radio Repairs
don.miller60@outllook.com
Apr 30, 2016 | Bose Audio Players & Recorders
Unable to get fm reception
Make sure you have an FM antenna connected. If that doesn't resolve your issue, you may have a damaged component in the tuner circuit.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
Dec 08, 2014 | LG Stylish DVD Home Theatre System HT306SU
I have a LG Record reciever home theatre model is LH-RH9691 and im having a problem with the volume only when the radio is working. It can only turned up slightly when set to max volume. But when...
in lg home theater system in video mode the complwte speaker will work and in mp3 only two will word .the radio get only a min volume in lg due to the range of antina
Apr 25, 2011 | LG Audio Players & Recorders
Good connection with tv, dvd ok, All cables properly connected but ..radio Tuner is not responding
You need to connect the radio antennae properly using the coaxial or the ribbon wire to the antenae so to get the best FM reception.
If this is not connected do so from the rear of the tuner/amplifier.
Feb 23, 2011 | LG LH-RH360SE Theater System
Installing a LG Network Blu-ray Disc/DVD Home
YOU NEED TO CONNECT OPTICAL CABLE (NOT INCLUDED) TO OPTICAL1 CONNECTION ON YOUR HB405 AND OPTICAL OUT OF YOUR TV. IF YOU ALREADY HAVE DONE THAT TRY PRESSING SIMPLINK BUTTON ON YOUR TV REMOTE NAD CHANGE THE SPEAKER OUTPOUT FROM TV TO HT(HOME THEATER).
Jun 19, 2010 | LG Televison & Video
Technika fm/digital frozen
Possible shorted power supply capacitor or bad diode.
Rod
Apr 20, 2010 | Audio Players & Recorders
How do I turn on the FM radio?
The headphones are the antenna, you may have to walk around to get better reception. I've never found the radio reception to be great on t. A full manual is available for this product on Sandisk's website.
-Tha Mp3 Doctor
Dec 02, 2008 | SanDisk Sansa Clip MP3 Player
Oct 20, 2008 | Bose 3·2·1 II System
139 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
