Question about Diamond Audio Car Audio & Video
I have one memphis 10 inch power reference 10 and one diamond audio d610 d2 and need wire them together
Just need to know how to wire them
  • 1,253 Answers
Red to red to black to red to black
Posted on Dec 14, 2014
2 Suggested Answers
  • 19 Answers
SOURCE: I was wondering if anyone could tell me how many
heres the stats for the whole Reference series. If you need help reading this then i suggest seeking a local person for advice on the specifics of your situation RMS POWER @ 4ohms RMS POWER @ 2ohms RMS POWER @ 1ohms BRIDGE MONO POWER @ 4ohms THD% @ 4ohms FREQUENCY RESPONSE DIMENSIONS (10"x2.3"x) 16-PR2.100 100 x 2 150 x 2 N/A 300 x 1 0.05 20Hz-20kHz 14.50" 16-PR2.150 150 x 2 210 x 2 N/A 400 x 1 0.05 20Hz-20kHz 19.70" 16-PR2.50 50 x 2 70 x 2 N/A 130 x 1 0.05 20Hz-20kHz 11.00" 16-PR2.75 75 x 2 100 x 2 N/A 200 x 1 0.05 20Hz-20kHz 11.60" 16-PR4.50 50 x 4 70 x 4 N/A 140 x 2 0.05 20Hz-20kHz 15.30"line_bottom.gif
Posted on Sep 16, 2009
I need a manual for Diamond Audio's D971 component speakers, I need the thiele small parameters of these speakers
General •Speaker type car speaker Manufacturer Diamond Audio Technology Inc. Features •Amplification type passive •Driver configuration 2-way •Woofer size (inches) 7" m, 30mm m •Nominal (RMS) output power 200 Watt •Max (RMS) output power 400 Watt •Response bandwidth 35 - 30000 Hz •Input impedance 4 Ohm •Sensitivity 92 dB •Connectivity wired Compatibility ' Accessories •Included accessories mounting hardware Cutout & Mounting Dimensions •Diameter 6.3 in •Depth 2.7 in General •Manufacturer Diamond Audio Technology Inc. Thiss should help you out.
Jan 05, 2015 | Diamond Audio Car Audio & Video
Need a wire diagram on diamond audio m612d2
run possitave to possitave and negative to negative on speaker an 1 side only to amp
Nov 11, 2013 | Diamond Audio D610D4 Car Subwoofer
My speaker stop workin and the amp is fine and everything is hooked up right
Looks like the speaker is blown , or the wiring inside the speaker is broken. To test if the speaker is working, simply hook up the terminals to the ends of a AA, AAA or C battery. Speaker should make a noise, and the cone should push outwards ( or pull inwards, if the polarity of the battery is reversed). Also test the wires that are hooked to the amplifier with a speaker that you know is good working order, just to make sure that there is nothing wrong on the wiring, on that particular channel in the amp.
Feb 03, 2010 | X-10 Memphis 15-PRC41 Power Reference 4" x...
Just want to know if its wired in to 4ohm
Hello fla2ga1008,
To wire the D2 voice coils for 4ohms, you simply jumper the positive side of one coil to the negative side of the other coil (series). Connect the remaining terminals to the amp for a 4ohm load.
If you wire both positives and both negatives together and then to the amp terminals (parallel), the impedance seen by the amp is 1ohm.
Hope this helps.
Jul 31, 2009 | Jl Audio 12W3v2-D2 Car Subwoofer
.4 times 10 to the 4th power
Hello lilzizia,
I'm not really sure what this has to do with the Memphis PRC41's, but just multiply .4X10X10X10X10 = 4,000.
Hope this helps.
May 04, 2009 | X-10 Memphis 15-PRC41 Power Reference 4" x...
Is a 15 w3 d-4 better then a jl audio w3-d2
All of the JL W3 subwoofers are essentially the same. The "d2" and "d4" suffix refers to the voice coil configuration. "d2" = dual two ohm coils, "d4" = dual four ohm coils. Depending on the number of subwoofers in your system and the amplifier(s) you are using to power them, one or the other of the configurations may be "better".
Generally, you want to have the load on your amp to have the lowest possible impedance consistent with the amps capability to operate properly with that load. It's normally referred to as "impedance matching". Greater power (watts) is produced, and louder sound, when the amp can deliver power at a lower impedance.
If your amp is only capable of supplying power at 4 ohms, you want to make sure that the configuration of your sub(s) represents a 4-ohm load. If the load is higher, say 8 ohms, then your amp can only deliver about half the power of which it is capable. It would be OK to run them a 8 ohms, but they would not be as loud. On the other hand, if the load was lower, say 2 ohms, your amplifier would soon overheat and go into protect mode.
So the trick is to first decide on how many subs you want. Then choose an amp/sub combination that "matches".
The DVC or dual voice coils just gives you more options in selecting and configuring. Say you want 2 subs and you are going with the 15w3 d-2. Your amp is the JL Audio G-MAX monoblock. The amp puts out 1200Wx1 Chan. at 2 ohms or 600Wx1 Chan. at 4 ohms. You would wire both of your subs voice coils in series making each sub 4 ohms, then wire the 2 subs in parallel to your amp making the final load 2 ohms, the best "match" for your amp.
Mar 29, 2009 | Jl Audio 15W3-D4 Car Subwoofer
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
ELA 500.I
While I don't have any first-hand experience with either Bazooka amps or Memphis subs, this review pretty much says what I initial thoughts were. The amp will do the job without much fuss, so it mainly depends on whether you can get it for a good price.
BUT........
There could be a issue with your sub. According to Memphis, your sub (assuming it's the single voice coil version) is only good for about 250W RMS (let's ignore peak power for now). The ELA500.1, on the other hand, puts out 375W RMS at 4 ohms. You could very easily overpower your sub with that amp.
Mar 13, 2008 | Bazooka (EL10190PP) Car Audio Amplifier
Car Audio & Video Logo
Top Diamond Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Diamond Audio Car Audio and Video Expert? Answer questions, earn points and help others
