Question about Morphy Richards Accents One Cup 43931 Hot Water Dispenser, Black
Have been using this for about 6 weeks, live in very hard water area so cleaned after 4 weeks as per instructions. Since then have had problems, either it doesn't stop pouring water so have to press
Have been using this for about 6 weeks, live in very hard water area so cleaned after 4 weeks as per instructions. Since then have had problems, either it doesn't stop pouring water so have to press button, then it will not work again until following day (I use this at night) or will start dispensing water stops after half a cup continues boiling and then few seconds later more hot water comes and overfills the cup.
2 Suggested Answers
  • 173 Answers
SOURCE: Why does the water giving out less than a full cup?
WHAT IS A FULL CUP FOR THE MACHINE? Just because "your" cup isn't getting filled up doesn't mean the machine is broke. You may be using too large of a cup.
Posted on Jun 13, 2014
Testimonial: "No, David knows nothing about the full cup!! There's a measurement small cup or medium cup or full cup. The small cup just less than half, half cup and full cup. I pressed full cup, but comes out only small amount like small cup. Got nothing to do with mug being too big.!!!!"
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
Lasko 5160 heater
it is necesary to clean the filters about one time per month ,with watter and soap,but if in your area is too many dirts so you can clean one time per week.you can see that when the power of the fan is too low.
Dec 10, 2013 | Heating & Cooling
KEURIG B31
The exit tube at the top that penetrates the Kcup has debris from the minerals in the water you are using. Clean as per Pg 18 and use Distilled Water to avoid the problem. Change Filters 6-8 weeks periods, also.
Feb 10, 2013 | Keurig B31
How often do you change the water filter
The answer to this question is not curt and dry, water quality varies with different area's, by quality i mean dissolved mineral, so if you live in an area with hard water (lots of dissolved minerals) then change it about every 90 days on continuous use, if you live in an area with soft water every 6 months is more than enough. Also change the filter is the flow is diminished, this indicates a filter that is clogged with particulate material like pipe rust or heavy mineral from hard water. Please rate my help for Fixya.
Jan 30, 2012 | Hotpoint HSS25GFP Side by Side...
How do i set my aquafine water softener for 4 people I'm not sure how to set the dials ...gallons , regeneration ? Could you provide a photo showing the dials?
I will simplify it. Your softener has a given capacity (IE: 30k, 40k, 45k 60k) Determine the capacity.
Water hardness x # of people x 75 = Total hard water used per day.
Example: 20gpg hard x 4 x 75 = 6000 grains per day
45k capacity - 6000 (1 day capacity in reserve) = 39k capacity
Set to 1950 gallons @ (12lb salt dose)
System regenerates every 6-7 days
RJ
Apr 30, 2011 | Plumbing
Regarding the Vigoro Electronic Water Timer, Model 196 036: How do I program the timer to water every day, in the early a.m., then in the evening? Is the greatest hourly spread per day 12 hrs.? In...
I think you almost have it right, you can program how many hours apart.
4=6 x per day
6=4 x per day
8=3 x per day
12= 2 x per day
24=1 x per day
Then you set how long you want it to be on, but that can't exceed your hour setting. I believe these are the same timers as Melnor. You can go to their web site for manuals. http://www.melnor.com/instructions.php. If you really want exact timing, I'd get a quality electric timer, and then buy a electric valve such as you'd use for a sprinkler system.
Jul 13, 2010 | Garden
How to clean air-o-swiss humidifier?
Gererally according to the booklet in the box.
If you no longer have those instructions, simply clean out the
basin, make sure no mold, dust, hardwater or calcium is deposited.
Use a 10% bleach water solution to kill bacteria, and thats is basically it.
Just dont miss any spots, but humdifiers should be cleaned every few uses.
Feb 19, 2010 | Air-O-Swiss 7133 Humidifier
How much salt should you use in a refill of a dishwasher in a hard water area
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Water hardness is measured in either European °E (clarks) or in the German °dH ( Deutsche Härte) you will find this on all Bosch Dishwashers here is the comparisons for the two.
If your water is Very Extremley hard then you will need to program your Bosch dishwasher using the Code
H:06 to give you maximum protection here is a comparison table for the codes and the Clark and Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Deutsche Härte with the standard Bosch codes.
I suggest that you use Calgon Dishwasher ( Sodium Carbonate formula Na2CO3.) tablets in the dishwasher every week this is a brand-named water softner that is essential to be used in areas of hard water which causes calcification and catastrophic failure. Use both the salt and the Calgon to suit your hardness.
If you live in a soft water area then set code H:01 as the extra is not required and only use Calgon tablets once a week use normal salt or tablet for the other washes.
Hope this helps
Sep 30, 2009 | Bosch 24 in. SGS43C12 Classixx...
Dishes in top rack not getting clean
If you live in an area with 'hard' water (having more than 5 ppm) you may require a whole-house treatment system to eliminate the mineral content that will wreak havoc with any water-related system (including your water heater).
If that is not the case I would have a service call to check the upper level service arm, which must be pushed in to a hole in the back of most units in order to get the water to flow in.
Oct 01, 2017 | GE 24 in. Profile PDW9880JSS Built-in...
Morphy Richards Accents One Cup 43931 Hot Water Dispenser, Black Logo
42 people viewed this question
Top Morphy Richards Kitchen Appliances - Others Experts
Mike
Ruth summersides
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
