Question about Philips Televison & Video
Why won't my tv turn on,even though the green light is on and not flashing.
Tried different power supply,isolated from other electronics.tried different controls.
    Top Expert:
  • Philips Master
  • 74,251 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Posted on Dec 09, 2014
ButtFuzz
  • 463 Answers
SOURCE: No power. Possible power supply issue.
If the repairman guarantees that the problem is the power supply and will agree not to charge you if that is not the problem, then by all means go for it. Most TVs it is what is called the Power supply Unit, or PSU, and the part alone costs well over $100...
Posted on Mar 16, 2009
  • 1156 Answers
SOURCE: I own an HCT model hld-420hcb and the tv will not
Hi,you might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections.
The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad.
This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced.
The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off.
This is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will help in solving the problem.......
Posted on Jun 19, 2011
diodeic
  • 1622 Answers
SOURCE: We have a 46 inch sharp tv model number 46SB54U
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout ......
Posted on Jun 25, 2011
SOURCE: my panasonic TH42PX60U won't power up. No red light flashing. Completely dead. I tried unpluging and using different power outlets. Still nothing. Any help?
it was the power board and the tech said about 500 to fix. replaced it for about 700.00
Posted on Jan 10, 2012
Slinteriors
  • 8617 Answers
SOURCE: My tv the light is flashing red green an won't
replace the power supply board. You can get replacement power supplies from www.tvcircuitboards.com
Posted on Mar 07, 2012
Dec 08, 2014 | Philips Televison & Video
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
Green light blinks three times but T.V won't power on
Power supply probably fried. You will have to take the TV apart to test.
Jun 23, 2012 | Televison & Video
Green flashing light on receiver of pioneer elite 434pu tv won't turn on
most likely a bad power supply and boards or service info for these sets is hard to come by. Not a do it yourself fix for most people.
Apr 22, 2012 | Televison & Video
Mar 07, 2012 | LG Televison & Video
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
We have a 46 inch sharp tv model number 46SB54U won't turn on. The green timer light is flashing. We just replaced the power supply board thinking that was the problem. TV still won't turn on...
Jun 25, 2011 | Sharp LC46SB54U 46 in. LCD TV
My RCA L42WD22 flat screen will not power on after being turned off for an hour. When I tried to power it on the green light comes on, and I have a flash of a picture, then a black/blank screen & a...
Take the tv apart.The tv power supply board,that the board,have power a/c cord plug into it.That the power supply board,check component parts like capacitors,see if it leaking gases,these capacitors are dead.Capacitors they'll alway bulges up on it tops or puff up on it tops.Have tools like soldering iron and solders?Know basic electronic and soldering?Replaced these dead capacitors will get power to ur tv back.Or tries websites like Shopjkimmy.com to buy a whole refurbish power supply board for the replacement.
Jun 15, 2011 | RCA L42WD22 42 in. LCD Television
Televison & Video Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
