Question about Plumbing
What size drip is correct on a faucet in cold weather
What size drip is correct on a faucet in cold weather, tried the size of a pencil
  • 15,557 Answers
That should be enough.
Posted on Dec 09, 2014
5 Suggested Answers
  • 37 Answers
SOURCE: tub faucet drip
Hi, You have to replace the two rubber cups in the hot&cold faucet lever. Let me know if you need more info.
Posted on Nov 09, 2008
  • 297 Answers
SOURCE: 806 series Georgetown bathtub faucet -- drips a
this is the way most price pfister products work,it is not broken.no matter what you do you will end up with the same solution.don't spend any money on this project.
Posted on Jul 22, 2009
  • 299 Answers
SOURCE: Blanco 2.2 GPM Faucet/Side Spray#157-013ST Via Google NO PRESSUR
Try unscrewing the aerator and cleaning the screen that you'll find there. If that doesn't work then you should check the pressure under the sink by removing the cold water hose from the cutoff valve (turn it off 1st!). If the pressure there is good then try removing and cleaning the cartridge by soaking it overnight in white vinegar or consider replacing the whole faucet if it's old. You can also call Blanco and see what they'll do for you as it has a "Limited Lifetime Warranty." If the pressure at the cutoff is low it's time to call a plumber!
Posted on Jul 15, 2010
  • 122 Answers
SOURCE: new Faucet drips for several seconds after it is
some of these new faucets are "soft off" which means the will drip or run for a second or 2 before the water stops. I know this can be annoying, but it is how some of them are made
Posted on Aug 09, 2010
How much water to drip in cold weather
drip 1-2 drip 1-2 drip no less then that or its liable to freeze how cold is it getting ?
Feb 19, 2015 | Price Pfister Plumbing
Tip
Prevent pipes from freezing
when the temps are low say around 3-10 degrees ,just open the bathroomand kitchen upper and lower levels if so of yore home faucets cold water side only to a drip about the size of a pencil=the drip
on Jan 24, 2014 | Plumbing
Moen 6410BN drips
one of you cartridges is bad you neede to go under the sink and turn off the stops one at a time to determine weather its th hot or the cold
May 04, 2014 | Moen 6410BN Eva Brushed Nickel 4"...
Both hot and cold faucets do not shut completely off anymore and the tall gooseneck constantly drips. I had a handyman come in but he could not remove the handles
Sounds as though you need new rubber washers. Remove both hot and cold handles, replace rubber washers, ( bring to HD or hardware store to match up size ) and problem should be solved. Over time washers wear out on all faucets. They are very inexpensive. Hope this helped and good luck.
Jan 08, 2014 | Plumbing
HELLO THE FAUCET DRIPS AT THE HANDLE AND THE HOT AND COLD SEEM REVERSED
On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
Aug 15, 2010 | Price Pfister Universal 0X8-310A Pressure...
Jul 14, 2010 | Blanco Classic Single Handle Faucet with...
Trying to fix drip on cold water. Removed screw
I don't know what type of faucet you have. If you try to pry start from the back of the faucet. That way if you mess up the chrome (or other finish) it won't be so obvious. And make sure the water is turned off.
Mar 10, 2010 | Plumbing
I have a slow drip on my bathroom faucet. how do i repair it. p-f 8" w/separate hot & cold faucets
Full instructions with diagrams here:
http://home.howstuffworks.com/home-improvement/plumbing/how-to-repair-a-faucet1.htm
very detailed and should help you stop that annoying drip..drip...drip
Hope this helps, if so please leave feedback. If not let me know and I'll try and help some more
Feb 03, 2010 | Price Pfister Plumbing
DRIPPING OLD BEVERAGE AIR FAUCET
New faucets are easily had from many places like beveragefactory.com, northerbrewer.com, austinhomebrew.com, micromatic.com, etc. You should also be able to find replacement washers/o-rings for your current faucet, but it may require an email or phone call to one of the sales reps to locate one. If you decide on a new faucet consider a Ventmatic (Shirron) forward sealing faucet. Much better design that drips less and doesn't stick after sitting a few days. The only issue I've seen is that the machined grooves in back of the faucet may not mate up with your current shank requiring a machined (as opposed to cast) shank to match.
Nov 01, 2007 | Beverage-Air MT27 Beverage Cooler...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
