Question about Honda Garden
How to test the starter system on a honda 40 hp 2003 tiller outboard which won' t start
    Top Expert:
  • Honda Master
  • 50,305 Answers
While cranking test for spark if not spark check for kill switch being in place. if spark is there then check for fuel . if no spark then prossbily power pack has failed
Posted on Jan 25, 2015
  • 17 Answers
SOURCE: Mantis tiller will not start.
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
Posted on May 24, 2011
SOURCE: My Volvo s60 won't start
you will need to try to turn the engine manually to make sure its not frooze. if it turns then you might need to check the starter again.
Posted on Aug 30, 2011
ASEtech
  • 67 Answers
SOURCE: Honda Pilot 2003 won't start. batter is good.
I would be re-checking the battery. Make sure that when you have it tested they do a "load test". Sometimes a battery can seem good, but be bad when there is a large load placed on it. This test will reveal if that is the case. It could also be a starter problem, and it is possible (but unlikely) that it is a wiring problem.
Posted on Sep 23, 2011
airjer995
  • 5332 Answers
SOURCE: dodge Grand Caravan won't start. Replaced ignition and starter tested fine but when I turn key and nothing happens
Check the neutral safety switch on the transmission. It should have three wires on the connector (if I remember correctly). There should be power on the Brown with yellow wire with the key in the crank position. If there is ground that wire and see if the van starts. If it does replace the switch. If it does not check the starter relay. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Posted on Jan 29, 2012
  • 5470 Answers
SOURCE: 1990 HONDA ACCORD WON'T TURN OVER TO START BUT IT WILL ROLL START. I HAVE CHANGED THE ALTERNATOR AND TESTED THE IGNITION SWITCH STARTER RELAY SEEMS FINE CLUTCH SWITCH SEEMS FINE MAIN RELAY IS FINE
About the only thing you didn't mention was the starter itself. You could have it tested. But before that, try to see if you have power on the small wire to starter solenoid on the starter, when key is held in cranking position. Pull the small wire off and check for power with a multimeter or a testlight while someone holds the key in crank. This is the signal wire from ignition switch that closes the elec. contacts inside solenoid so the starter gets full power from the battery to spin. (This wire also is in the circuit with the clutch switch and the starter relay.) If you have power on this wire in crank, it is very likely the starter is bad. If there is no power, check that circuit out. It is losing power somewhere from switch to starter solenoid. Good luck.
Posted on Jul 06, 2012
40 HP 2 cycle outboard. Tilt works, but engine does not turn over. Yamaha outboard should mention.
So either the battery needs charging, the starter button / key are faulty, or the starter/solenoid is faulty. You need a test meter.
Dec 30, 2016 | Boating
Where can Iget impeller #16622B010 for a shur dri water pump
I can only help on a Honda 50hp 2003. Any Honda center or parts center. That's all I know. JMC
Jun 09, 2014 | Honda Water Pump Impeller Outboard 35, 40,...
Starter
pull starter off and take it to the parts store and have them run a free test on it. or get under the car and test larger power wire and make sure it has power with a test light. If it does have someone turn the key to the start position while you're under the car testing the small starter lead wire located right near the main hot wire on the starter. if they both have power and the starter still isn't working then you need to replace the starter
Mar 23, 2013 | 2003 Honda Element
1998 Honda Accord Won't Start
Park neutral safety switch maybe be the reason for the no crank ! Try putting the vehicle in park ,then try to crank the engine . Testing the electrical circuit is the best way to trouble shoot this problem , along with do a voltage drop test on the starter circuit ! This will test the battery cables an connections .
Starter Voltage Drop
How to voltage drop test starter motor circuit
Does it have a manual or automatic transmission ? Manual ? clutch switch . Looking at a wiring diagram I also see a starter cut relay !
http://www.bbbind.com/free_tsb.html Free wiring diagrams . Enter vehicle info. year , make , model and engine size . Under system click engine , under subsystem click starting . Then click the search button , then click the blue link ! Check the starter cut relay also . Videos on youtube showing how to test a relay controlled circuit !
May 29, 2017 | 1998 Honda Accord
2003 toyota tacoma won't start
What was checked/tested ?
Fuel pressure at motor & spark cranking?
Battery seems fine based on what kind of testing?
Won't Start
Won't Turn Over
Have to get your thoughts around what you say
Nov 29, 2012 | 2003 Toyota Tacoma
My 2004 Honda Pilot ran fine then a hour later won't start. At first thought battery so we charged up usig one of those chargers you plug in. Lights flicker, and clicking sounds but won't turn
Check batry terminals are secure & free from corosion, check security of earth strap to engine & main power wire on starter, if ok have the batry load tested to ensure it can perform under load as the starter needs a lot of current. Have you tried a jump start?
Sep 24, 2012 | 2004 Honda Pilot
Honda rebel cmx250 1986 won't start
Hi, Jenn before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Rebel 250 won start Need help advice
What Do Check When My Motorcycle Won Start Honda Shadow Forums Shadow...
Rebel CMX250 250 1985 2009 Motorcycle Service Repair Manual Download... $10
http://www.partsfish.com/page/oem-parts-for-honda
Honda CMX250C REBEL 2007 Owner Manual
Jul 03, 2017 | Honda CMX 250 Rebel Motorcycles
My lights, windows, and radio all work fine. But it won't start it makes a click noise but nothing. Then we thought it was the battery so we jumped it and now it won't even make no click noise at...
The "click" sound condition make us guess that could be a bad ignition switch or starter.
It turned out to be the starter. I first took the battery to have it tested and it was fine. Next, I took the starter apart and took it to Autozone to have it tested? and it was bad. It is not easy access to remove the starter. The intake manifold and exhaust system are in the way and need to be taken apart first. See instructions below:
- Take off Intake
- Take off Starter
Hope this helps (remember to rating this answer and leave some comment).
Sep 28, 2011 | 2003 Honda Element
Honda Pilot 2003 won't start. batter is good. seems to be an electrical issue because starter won't turn at all and there are strange clicking noises when key is turned
Sep 19, 2011 | 2003 Honda Pilot
Garden Logo
75 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
