I have a Gibson gas furnace model gl1ra072c12a, the middle two burners flame are blue both end burners are yellow . All were cleaned. as well as jets what could be the problem?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
If the flames are yellow AND lazy, not acting like the two blue flames are, the problem sounds like excess carbon build up within the heat exchanger ABOVE the two yellow burning burners. If that is the case, the yellow burning flames are contributing additionally to the carbon already in there. Eventually, the lazy flames will roll out into the furnace vistibule and possibly burn wiring creating a major problem. There are looooong wire handled bristle brushes 30" long that must be used to thoroughly clean the heat exchanger after the burners have been removed. A shop vac will help greatly in reducing the nasty carbon mess.
Usually, the vent collector hood and flue is removed to brush down from the top and up from the bottom alternately. If there are air shutters on the burners, make sure they haven't been throttled too far down limiting the combustion air causing the original problem.
You need a certified HVAC service tech to look at this issue.
Posted on Dec 10, 2014
  • 41 Answers
SOURCE: yellow pilot on heater
soleman13au
Rank:master_s.gif Master
Rating: 90%, 19 votes
Hi mitalee1
All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this. If you can get to the top of the pilot light it may help to give that a blow out too.
To clean it out internally you only need to remove the front panelling. Just follow the screw configurations *** you go. I asm not familiar with that type of heater so thats about the best I can do. Regards Bryan
Posted on May 07, 2008
  • 9 Answers
SOURCE: furnace flame goes low fan stays on
if the gas pressure is good on inlet and outlet of valve u might wanna chk the burner trays and manifold for flakes, dirt, spider webs ect... once u kno the passages are clear from obstruction you can focus on the mechanical. (sounds like gas valve may be getting weak and not able to open fully)
Posted on Mar 22, 2009
  • 189 Answers
SOURCE: Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Posted on Apr 10, 2009
co7196
  • 3433 Answers
SOURCE: I have a Goodman GMPN120-5 furnace that has flame
I hope this helps you_Ned
http://www.fsti.com/rollout.htmd
Explains flame roll out. :)
Posted on Oct 07, 2009
  • 221 Answers
SOURCE: furnace howls when burner lights for 30 or so
Hi, the howling you describe is pretty common as gas heaters first come on. NG or LP gas is delivered at a pressure much higher than appliances actually use, step down regulators lower the pressure as the gas flows. So, when you first turn your heater on, the pressure is a little high until the flow causes an equalization of pressure. You could contact your gas supplier and ask them to check your pressure and tell them you suspect a building regulator. If the pressure were to build too high it could cause leaks or damage the appliance controls.  Good luck.
Posted on Jan 10, 2010
Flame on main hob of range master 110 is yellow and smelly also black sooty deposit left on jets
Ream out all the orifices and air venturi holes on the burner, adjust the air-ahutter, the air-shutter is usually nearer the valve/knob than to the burner. Yellow flame is an imbalance of fuel to oxygen and is creating Carbon Monoxide and not burning cleanly... this is the same problem that can make a furnace deadly. Blue flame=neutral flame.
Apr 25, 2016 | Rangemaster 110 (Gas) Kitchen Range
How do I get my furnace to stop smoking and make my burner flame turn blue
This is an oil heater with a wick, or an oil furnace?
Wick
If it smokes the wick is too high and the burner is not burning all the gases produced by the hot oil in the wick.
Use the wick trimming tool and then relight it. Light the wick and then lower the flame until it is blue.
Furnace
With a furnace, you need to open the front, clean out any soot and clean the spinner in the middle. You may need to regulate the air mix intake to get a blue flame. If it is yellow, you need more air.
If it's gas, you need an engineer.
Feb 01, 2016 | Heating & Cooling
One of the 4 burners has a LARGE, YELLOW flame (right rear burner). It just started today. Other 3 have a BLUE flame. Using Propane Gas Is this a fuel/air mixture problem, and if so, how do I fix...
The yellow flame suggest incomplete combustion is taking place and on a flueless appliance Otis very dangerous, check for dirt/greese that has accumulated aroroud the gas jets ( this will dercrease air available at the primary airport) if this is clean then your gas jet may be worn and become larger allowing more gas than air as they mix, in this case you will have to replace the gas injectors
Jul 12, 2011 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Rheem gas furnance makes a boom when lighting, after being off for a while
Two things come to mind right off. The first is to make sure that all burners are clean, The second that I would find the most likely if this only happens after furnace has not been ran for awhile is the duct work is expanding rapidly and this is what making the noise. I would observe the burners when the furnace come on and see what flame looks like. It should be igniting quickly when calling for heat with the flames setting close to top of burners and have sharp pointy flames that are mostly blue with just a little yellow.If the flame is drifting off of the top of burners they need to be cleaned. I hope this helps you. Thanks
Jan 12, 2011 | Stoves Heating & Cooling
Furnace seems loud when burners ignite like a small "woof" didnt always do that seems to be something new. Checked all venting nothing obstructed. Had gas presure checked it is LP input is 10...
Depending on the age of the unit the gas pressures should be fine. The first thing I would do is to give the burners a thorough cleaning and make sure pilot is clean if so equipped. I would shut furnace off and remove the burners for easier and better cleaning. Use a wire brush to lightly clean openings on the burners,and gently tap inlet end of burners on soft wood block or thick cardboard pad to clean soot and rust from inside the burners. Also blow out with air if you can.
I always do one burner at a time and put them back in the order they were removed in. When you get everything back together and furnace lit then you can loosen retaing screws on air baffles if needed to get the best looking cleanest flame possible.Flames should be tight on the top of the burners with nice blue flame with sharparrow points with just a little yellow on the very tip.
I hope this helps you. Thank you
Jan 10, 2011 | Heating & Cooling
Just recently our 10 year old stove started smelling funny only when its on. the burner burns but the flame is yellow and was normally blue. I understand the air fuel mixture could be off, how Do I fix...
Gas flame on all gas appliance should burn clear blue.
Yellow flame means you need to clean the burners.
This applies to stoves, oven, furnaces, water heaters
I did a google search for: clean burners on gas stove.
There was more information and helpful tips on those links than I can honestly repeat here, including how-to videos.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on appliance.
Jan 03, 2011 | Hardware & Accessories
My ge gas stove works, but the flames just don't seem big enough. even on high, it takes forever to bring a covered pot of water to a boil. The flames seem even, mostly blue with some orange/yellow. any...
There can be poor air mix ( oxygen) for the flame to grow up. so remove the burner and use a good metal brush and air jet to clean off allt he crust and dirt of food lodged into the burners.
Now if the regulator gas fflow is down then your jet is blocked. If so you might have to remvoe the regulator to see that the jet is cleaned out . use a thin pin and airjet to clean.
Sep 16, 2010 | GE Spectra JGBP35 Gas Kitchen Range
My surface burners are burning with a yellow flame. How do I adjust to get a blue flame. Model # FGGF3041KFC
yellow flames indicates blocked gas jets... must be cleaned or replaced before using for safety reasons
Mar 20, 2010 | Frigidaire Kitchen Ranges
Lighting the pilot light
The steps involved can vary slightly depending on your furnace model and pilot valve type, so if possible try and find the instructions inside the furnace door cover or in the instruction manual. This is for a gas fired furnace, but applies to any gas-fueled appliance including water heater. Two of the most common types of pilot valve body assemblies either have a red reset button and a gas valve or no reset button and a valve knob that can be depressed. But whichever type you've got, if you have an older model furnace with a standing pilot (flame is lit all the time) then this is the basic procedure.
  • Turn you thermostat to 80 degrees or to a setting that will demand heat. Make sure the thermostat is in "Heat" mode.
  • Go to the furnace and find the pilot valve. The pilot valve body is a box shaped device into which the main gas line will run and is located near the gas burners. It will usually have a gas **** or valve knob that reads "On, "Pilot" and "Off." Locate this gas **** or knob.
  • Turn the knob or gas **** to the "Off" position and wait about 3 minutes for any residual gas to clear away.
  • Find the pilot. It's located near the gas burner tube assembly in the furnace.
  • Get your match or lighter ready. Sometimes the pilot is hard to reach. If possible, try and use a long fireplace match when you light it. If you don't have a fireplace match then a butane BBQ grill lighter works well too. If you don't have that, then you can fasten a match to the end of a stick when you light the pilot
  • If you have a pilot with a red Reset button, turn the gas valve from "Off," to "Pilot."
  • If you have a pilot with no red button, turn the knob from "Off" to "Pilot."
  • Place the lit match or ignited lighter tip at the pilot and depress and hold the button or depress the knob as appropriate. Depress the button or knob for about 30 seconds. This maintains gas flow to the pilot until the thermocouple gets hot enough to open the main gas valve.
  • Once the pilot stays lit, slowly release the button or knob and turn the gas **** or knob from the "Pilot" position to the "On" position. This will ignite the burners and keep the flow of gas supplied as required for the burners as called for by the thermostat.
  • If the burners fail to ignite then it may be because the thermocouple did not get hot enough to open the gas valve. Wait a few minutes and then repeat the above procedure. This time hold the red reset button or depress the knob for about 45-60 seconds.
  • Once the main furnace burners ignite, adjust the thermostat to the desired setting.
  • If you've followed the previous steps on lighting the pilot and it still does not light after, or will not stay lit, then you probably have a problem with the thermocouple or an adjustment needs to be made to the pilot. You'll need a furnace service technician to replace or repair these parts. You may find that the pilot lights, but it is an anemic looking flame. That's a different problem we'll look at in the next section.
  • If the pilot lights but the flame is a weak yellow flame, it will not get hot enough to heat the thermocouple to its set point allowing the gas valve to open.
    A natural gas flame should be a bright blue with the tip of the flame having just a tinge of yellow. A propane flame should have a bluish green flame with a tinge of yellow at the tip. The flame should be strong enough to hit the thermocouple tip about 1/2 inch from the tip end. If the flame is weak or shaky looking, check to see that a breeze or draft is not blowing on it. Adjusting the Flame
    There is usually a small screw on the pilot valve body that will adjust the flame. You may have to refer to the manufacturer's instructions to find the screw. Turn the screw as needed to adjust the flame throw. Yellow Flame
    A yellow flame is caused by lack of air and incomplete combustion. It can be caused by a dirty pilot tube tip. Split Flame
    This is caused by dirt in the pilot tube. Take a needle or small nail and gently clean the tube. Flickering or Wavering Flame
    A flame that flickers is usually caused by a draft.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 18, 2009 | Water Heaters
Flame way too high and yellow-Frigidaire Model #FGF328GM
call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Mar 11, 2017 | Kitchen Ranges
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
