How do you replace the wick on a comfort glo kerosene heater?
    Master:
  • 993 Answers
Open the vent of wick, turn the knob clock wise to dismantle the wick from its fixing hole,after completion to out the wick,then try to insert the wick in its hole from below side,push gently the wick in &
rotate the adjusting knob to set the wick in
Posted on Dec 11, 2014
  • 3 Answers
SOURCE: kerosene heater
Dyna Glo 95 c4 Manual
http://www.owneriq.com/mdownloads/8979e0af-dfee-45f1-a8ba-c05c2f5ed4a8.pdf
Posted on Dec 07, 2009
SOURCE: dyna glo kerosene heater
smoking problem
Posted on Nov 23, 2008
wilsodfarm
  • 986 Answers
SOURCE: i have a dyna-glo rmc-95-c2 kerosene heater, i
when you replace the wick did you set the control all the way down
Posted on Feb 11, 2010
  • 30 Answers
SOURCE: Changing Wick in Kerosene Heater
http://www.ghpgroupinc.com/heaters/manuals.aspx
Here is the complany website..parent group name is GHP group..crazy they don't link DynaGlow more easily in a web search
Posted on Nov 06, 2010
SOURCE: My Dyna GLo kerosene heater has excessive smoke and yellow flame
I'm wondering the same
Should a duraheat, etc., cylindrical convetion heater's flame be bright yellow, blue , or what? With the old wick the flame was blue, with the catalytic converter glowing red hot. Now with the new wick, I can't even see the CC, because the flame burns a bright yellow. Also I have to really fine tune it now. A wee bit too high, I get smoke and soot. A wee bit too low, same...smoke and possibly flame out.
Posted on Jan 03, 2011
Need to see pictorial instruction on how to replace wick in a Dyna Glo RMC-95-C2 kerosene heater
I think the Dyna-glow RMC95 series of heaters are equivalent to DH2300 series heaters.
In any event, the wick you purchased should have ahd the installation instructions included with the wick.
If it didn't or you tossed it, Here's a link to the DH-2300 series heater's Owners Manual, which may help you.
http://www.yourheater.com/DH2301-3%20owners%20manual.pdf
Good luck. Be sure to wear rubber gloves when you try to install the wick. Particularly, if you still have kerosene in the tank.
Feb 11, 2011 | Dyna-Glo RMC-8001SS Heater
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
Jan 31, 2011 | Dyna-Glo RMC-8001SS Heater
Need to know how to replace the wick
The first thing you need to determine is the correct model number of your heater. Once you've done that, go to the GHP Group Inc, website listing the heater manuals and locate the appropriate manual for your heater model and click on the link for your heater.
After you've selected the appropriate manual, you can either download it to your computer or print it out. Inside the manual you'll find the instructions on how to replace the wick. The kerosene heater manual I reviewed listed an incorrect phone number to call to order a replacement wick. I suggest you use the new GHP Group's number to order your replacement wick: (877) 447-4768.
If you have a different Dyna-Glo heater than a kerosene one, you should still be able to locate the appropriate manual on the GHP Group's heater website.
Hopefully, you'll have your heater up and working again in no time.
Jan 12, 2011 | Dyna-Glo (PPH16-LP) Utility Heater
Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Jan 02, 2010 | Dyna-Glo Heating & Cooling
Wick not burning properly and smells
You need to use pure kerosene do not use died or color kerosene it depletes the wick faster and causes a distinct odor. Pure kerosene should be clear.
Dec 16, 2009 | Heating & Cooling
Can not location a source for igniter plugs for my Dyna-Glo RMC 95 kerosene heater
Below is a link to eBay where you can purchase an igniter for you heater:
http://cgi.ebay.com/Kerosene-Heater-Replacement-Wick-Igniter-1183017-NEW_W0QQitemZ390095252633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5ad37d2c99
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Dyna-Glo Heating & Cooling
Kerosene heater
Jan 31, 2009 | Dyna-Glo RMC-8001SS Heater
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
