Question about Water Heaters
HAVE AN OLD MODEL #45-552701 ON DEMAND HEATER NEED TO KNOW HOW TO HOOK IT UP IN CABIN
    Master:
  • 552 Answers
In general, it requires power and water.
power and fusing is relative to KW rating of unit
install seperate circuit in fuse panel
run appropriate size wire to location
connect cold in and hot out water lines
connect power, run water to bleed air.
turn on breaker sw.
Posted on Dec 09, 2014
How do I get the back heaters to turn on, I would like to find a manual for my sauna
Natasha, honey, I don't know your make/model; but go to their web site and download it.
Oct 13, 2014 | Eacon Far-Infrared Sauna Cabin - 3 Person
Why is my hot water heater is using too much power?
It almost sounds as if someone is hooked into your electrical system check for outside cables or extensions cords going into a window or even at the fuse box
Sep 05, 2014 | Water Heaters
I have a Bosch Tankless Water Heater Model WR 400-1 KV1 P32 S3100. The water valve has cracked and I need to know where to get a replacement. Thanks
Before calling service technician, open following link for Bosch troubleshooting resources including parts, contact, possible manual, possible service bulletin covering replacement:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 24, 2011 | Bosch Water Heaters
Want to replace 17 years old water heater that is problem free but want to qualify for fed. rebate. what do you recommend? Rheem, AOSmith Select? etc
If I understand the wording on the max rebate you will need to go with one of the high effiency on demand heaters such as bosch or whirpool .There are several more manufactures that will qualify for up to 1600.00 on taxes and some dealers offer there own incentive programs. Most of these heaters are going to cost in excess of 2000.00 plus installation but they will save operating expenses. Hope this helps. Thank you
Dec 28, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Back flow of fumes
your on demand water heater is supposed to be on a seperate vent, directly outside,and not closer then 60 inches from any other vent, the on demand pulls cold air in on the outer side of the vent and blows the hot air out the center of the flue
May 25, 2009 | RTO X-40 High Output On-Demand water...
On-Demand Water Heater
An on-demand, or tankless, water heater is a system for heating water as it passes through the pipes, usually very near the point of use. Traditional tank water heaters bring the water to approximately 140 degrees Fahrenheit (60 C), in order to ensure the water supply lasts long after the heater turns off. Since this is obviously far too hot to be pumped out of a shower of faucet, cold water is added to the mix in the pipes. Coupled with the loss of thermal energy over time, the average tank heater has an efficiency of approximately 80%. On-demand water heaters have a number of advantages over their tank-using counterparts. While tanks often degrade over time and begin leaking, the apparatus used in an on-demand water heater is much less susceptible to the burdens of age, and will often outlive the house they're installed in. The amount of energy used is a fraction of that used in a tank water heater, due to increased efficiency and a much smaller window during which a heating source is in use. While tank hot water heaters can, and often do, run out of hot water after a number of showers, on-demand heaters provide a never-ending supply of hot water, ensuring that warm water is always available when needed. A tankless water heater can cost between $500 and $1500, and they most commonly use either electric or natural gas energy to heat the water. Most mid-sized households report an energy savings of approximately 25-45% for a gas or propane heater, and up to 50% with an electric heater, over using traditional tank heaters. Water is usually set to a maximum temperature of 120 degrees Fahrenheit (49 C), though many heaters allow for custom setting of the maximum temperature via remote control. Outflow rates range from 8-14 gallons (30-53 litres) per minute. Installation for most tankless water heaters is incredibly easy, involving simple plumbing. In the case of electric heaters, all that is required for a fuel source is to plug the heater into an outlet and begin heating your water. Some modern on-demand water heaters can incorporate a solar preheating system. This system uses a traditional solar heating system and tank to bring the water nearer to the desired temperature, saving substantial energy use in the final on-demand heating. A solar preheating system costs between $500 and $800.
Aug 27, 2008 | Stiebel Eltron CK20E Electric Tankless...
Water Heaters Logo
78 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
