Question about Kitchen Ranges
New burner switch
The switch to the burner took on some water and fried. Is it hard to replace
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 142 Answers
Not to hard. Remove knob and retaining but diconect wire and install new one. Now the ignitor may have got wet and not generating a spark. Just let it dry it probably will start working again. Give it some time.
Posted on Dec 09, 2014
  • 1,249 Answers
Not at all. Just google your model number and add 'control'. Youtube works the same way. Don't forget to unplug the unit before you work on it.
Burner light stays on when burner is turned off
Each burner has a sensor in it. These sensors will STICK and stay on even if the burner is off. Usually occurs with the burner that is used the most such as for chicken frying and such. If the burner eye is not the problem then the switch that controls the burner would be the next thing to check. An interesting video that show switch failures:
Jan 11, 2013 | Kitchen Ranges
Burner will not get hot enough
When the burner arced out it probably also ruined the switch. Most switches on a standard electric range have 5 wires. 2 wires to the burner. 2 hot wires from power and a smaller wire which connects to the indicator light marked P. It is easy to test the switch Unplug the stove. Turn the suspect switch on wide open. Check for continuity between the 2 terminals going out to the burner marked H1 and H2
If you cannot get a reading then the switch has failed. Note: when replacing the switch usually on most stove the replacement will not be or look like the original HOWEVER it will still have L1 and L2 H1 and H2 and P but the terminals are not always in the same order. If you fail to correctly connect the new switch you will fry 2 switches when both get turned on. Ouch!
Aug 30, 2012 | Kitchen Ranges
I have a 1960's 40" GE double oven range. Both large burners quit working (the ends of the elements are melted in the sockets) the clock and the accessory plug as well. All of this happened at one time....
No the switches need replacing. This training video shows how those switches work and will give you a better idea of what to do: HERE
Since you might have 2 switches gone bad and the originals will not be available the new parts even though ordered from GE will be generic in nature, (so you might want to find the old 5500-200 robertshaw control (that is what GE uses shhh don't tell nobody) When using the generic switches pay attention to the wiring. L1 and L2 won't be in the same location and when connected both switches will blow(not good) The old switch has 2 wires to burner (H1 and H2) and two wires from source (L1 and L2) and P for pilot to turn on a light on the top telling burners is on. Get em right so your honey will think you is a brainiac! LOL
Jan 15, 2010 | Kitchen Ranges
Infinite switch sparking!!!!
You have a short somewhere between the switch and the burner connector. Probably a wire's insulation has worn away or melted and is allowing the wire to contact the metal housing somewhere. You will see arc marks wherever the short is located. Look carefully where the wire passes through any holes or where sharp turns are encountered.
Aug 12, 2009 | Jenn-Air SVE47100 Slide-In Electric...
My oven made a buzzing sound,and and smoke came out form the oven. Now it wont heat up, but the top stove still works...Any ideas? Thanks
fryed switch or fryed burner
if smoke came from inside stove likely the burner is fryed
try setting oven to broil and see if it heats up
if it does replace lower burner
Jul 31, 2009 | Ovens
13 year old firemagic -- rusted burners and grid. can i get replacements?
yes you can look up Atlanta Grill Services on the internet call them they can get the parts for you.
Jul 14, 2009 | Fire Magic FireMagic (LP) 14-S000C-0 Grill
Six burner gas cooktop
My husband figured it out.....when we took the knobs off, I, of course, washed the area they had been sitting on, thereby spilling some water into the open part which contained the wires leading to the igniters.  A short time with a hair dryer sorting things out.
May 06, 2008 | Jenn-Air JGD8130 Gas Cooktop
Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
Jan 19, 2008 | Kitchen Ranges
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
