Question about Frigidaire FMT118EPB Microwave Oven
How to unlock FMT118EPB - Frigidaire FMT118EPB Microwave Oven
  • Official Brand Answer
  • 2,267 Answers
Hi rajnherc, thank you for your post!
Based off the information you have provided you would like to unlock your Frigidaire microwave, FMT118EPB. I was unable to locate any additional manuals for your microwave. If it is an older model, over 10 years old, manufacturers will not keep material on them. You may be able to perform a generic search online for any further information. Good luck. -Matt
Posted on Dec 10, 2014
I changed the fuse on a Frigidare #FMT118EPB Microwave and it blew again. I checked the micro switches with a meter and they seem to work. What else could be causing the fuse to blow? Thanks.
If you put in the correct size of fuse then what it needs is to go to a qualified service tech. What would be next requires removing the covers and if you do not know what you are doing you will fry yourself.
Dec 06, 2014 | Frigidaire FMT118EPB Microwave Oven
How do I determine if the fuse is bad on a Frigidare #FMT118EPB Microwave? Thanks.
Michael, if the fuse is bad, it will take out everything on the microwave. You will not have any lights inside or on your display. You can find the fuse inside of the cover by following where your power cord goes into the unit and following usually the black wire to the fuse. Hope this helps!
Dec 04, 2014 | Frigidaire FMT118EPB Microwave Oven
I don't know why my frigidaire gallery microwave FMT118EPB goes on but doesn't heat
the magnitron supply EHT isnt there
or the heaters connections inside the square metal box
have come loose
replace the magnitron is best and check the eht fuse {inline type usually}
Aug 13, 2014 | Microwave Ovens
I have a Frigidaire PLMVZ169 Over-the Range Microwave Oven. The two bolts that anchor it to the cabinet above keep turning but do not lift the oven upwards. If they are stripped can I replace them? ...
In the top of the microwave they have nuts with clips on them that snap into the outer cover. If the mounting bolts were not started carefully they could have been cross threaded and now those nuts are spinning in the cover of the unit. THAT may be a bear to remove. Can you take off the grill on the front of the unit above the door and see if you can see the bolts coming down into the unit?? If so, you may be able to grab the nuts to keep them from spinning to get the bolts out. Sorry , doesn't sound fun!!! Good Luck!!
Oct 31, 2017 | Frigidaire FMT118EPB Microwave Oven
Oven wont work unlock door meesage keeps flashing door unlocked
The model number would have helped us give you specific advice, but without it we'll give you generic advice and say it may be a door switch issue.
See our help file on door switches here.
Jan 16, 2013 | GE Microwave Ovens
Frigidaire FMT118EPB microwave - is about 13 years old - makes loud venting noise and won't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 22, 2011 | Frigidaire FMT118EPB Microwave Oven
My microwave oven locked and when I press the clear/off for 3 seconds, it unlocks. After one minute it locks itself again. I can't get it to stay unlocked.
The same thing that Locked it will Unlock it. It is a child proof feature. To unlock it:
  • hold the Clear/Off button down for 3 seconds, until it beeps and the screen will read "Unlocked"
Jan 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
I have removed the mounting brackets from the top of the microwave but still cannot get it to tilt forward for removal. I do not see any levers as suggested in the Solution #1 above. Any other advice?
Did you remove the 3 screws from the top that hold it to the cabinet. Here is a install manual so you know what screws to remove. also make sure the ducting is removed all the wat to tilt micro.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316495064.pdf
Good Luck
Nov 21, 2009 | Frigidaire FMT118EPB Microwave Oven
Microwave Ovens Logo
98 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
