Question about Global Industries Irola 7" Android 4.2 DX752 Tablet PC Capacitive Multi-Touch Screen 4GB Memory 512MB DDR8
How do i get a replacement adapter for my tablet
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 142 Answers
Amazon will have it
Posted on Dec 09, 2014
I have a nobis nb1022c 10.1"tablet with a/c adapter for charging. The tablet will not charge. How can I tell if my problem is the charger/adapter or the tablet
You can have it tested with a simple voltmeter. As for replacement check ebay or amazon or contact the manufacturer
Sep 01, 2016 | Tablets & eReaders
I cannot get the tablet to charge. I am trying using the USB port, as I cannot be sure the a/c adapter I have is correct. Thanks
If your not getting any indication lights on tablet could be wrong USB adapter transformer. It could also be a bad wire from adapter.
You did not indicate type of tablet or adapter you are using. Worst case you have a bad battery in table and would most likely ha e to be sent in for repair. However if you have a cell phone USB charger for a car try plunging in tablet in and see if it charges. If it does get a new adapter with higher amp than the one your using. But beware the batteries can only be charged to a max amp see web site for you tablet for recomindation.
Jan 02, 2016 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
Nextbook 10.1 touchscreen tablet. How do I determine required polarity of replacement power adapter if original adapter is missing?
unless you have a very way out machine all power adapter charges are wired the same way
all you need is the correct fitting to go into your machine
Nov 02, 2015 | Nextbook Tablets & eReaders
How do I get a replacement power adapter for my 9" Proscan tablet?
perhaps from the maker . I saw something today at a home improvement store today. sounds like a power adapter.small (micro) usb on one end and regular usb on the other .
Jan 13, 2015 | Tablets & eReaders
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Acer a501 will not charge and i have tried re-setting it but i still get nothing even with a usb it will not charge
Some Acer tablets have the following issue. You may need to contact Acer directly to resolve:
Issue:
AC adapter part numbers AP.0180P.002 and AP.0180P.003 built before week 33 may not charge the tablet. This occurs if the spring becomes deformed and no longer makes contact. Not all adapters built in this timeframe exhibit the issue. The issue may be caused if excessive force was applied to the adapter to deform the spring.
You may reference the week number (digits 12 and 13) on the adapter SN to verify if it was built before or after week 33.
SOLUTION:
If the adapter is not charging the tablet, replace the adapter like for like. The vendor designed an improved spring solution. This solution was phased in production week 33 for both AP.0180P.002 and AP.0180P.003. The part numbers have not changed.
Source(s):
http://support.acer.com/us/en/product/default.aspx?modelId=3849
Jun 08, 2013 | Acer Tablets & eReaders
Tablet has not been used for long time. It was given to me. Battery is empty for sure. When I connect PC to the power suppy it does not show any sign of life. No light - nothing. I tried the same without...
The power adapter may be faulty.
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.
Apr 28, 2011 | Compaq tc1100 Tablet PC
My tablet will not turn on ?
time to replace the adapter, you can take it to a best buy or a electronic store to be sure. ask then to test the laptop, with and adapter they might charge a fee, better to be safe than sorry
i figure an adapter last about 1-2 year depends on how you treat them.
If you do not take care of your electronics, your electronics will not take care of YOU!
Jul 24, 2008 | Averatec 3500T60 Tablet PC
Global Industries Irola 7" Android 4.2 DX752 Tablet PC Capacitive Multi-Touch Screen 4GB Memory 512MB DDR8 Logo
62 people viewed this question
Top Global Industries Tablets & eReaders Experts
Are you a Global Industries Tablet and eReader Expert? Answer questions, earn points and help others
