Question about Home
Jacuzzi will not turn off - Home
My client buy jacuzzi whit light and water jets but is not working the main control not turn on curse water in the plug all connections and not working..not guide any instructions
Jacuzzi Is STILL a viable SPA / Whirlpool Entity...
If you know the age of the equipment...
It may actually date back to when Jacuzzi
headquarters was right here in the San Francisco Bay Area.
Now SFSpas.com ... 510-527-5547
Paradise Valley Spas The Bay Area Top Hot Tub Retailer
Richmond, California (to be specific... (on Jacuzzi Street)).
((I was sad when they left).. but am still a happy customer).
Air "switches" remain their most popular trouble...
and if you know what yours LOOKS like... you
can VERY LIKELY still buy the parts from eBay...
I
recommend going to Jacuzzi... (opinion).
Carnac the Magnificent
Aug 09, 2017 | Jacuzzi Home
Jacuzzi spa pump turns on after a power failure
keep a seperate re-chargable battery
Aug 05, 2012 | Jacuzzi Home
Can not turn jacuzzi on or off
What type of jacuzzi tub are we talking about? indoor bathtub or outdoor hot tub?
Rod
US Parts Center
888-521-6183
Jul 04, 2012 | Jacuzzi Pool & Spa
Jacuzzi 1hp hums won't turn on
If your motor is turned on and just hums then it is bad and will need to be replaced.
Rod
US Parts Center
888-521-6183
May 29, 2012 | Jacuzzi Impeller, L - 3/4 H.P
When I try to turn off my Jacuzzi tub it will not turn off. I pushed the gfi and it went off. I then reset it a few days later and the tub would not turn off and this time the gfi would not shut it off. ...
You will need to have a technician from the store you purchased it from install a new switch.
To be up to code, you should have a GFI for your Jacuzzi to plug into and a GFI circuit breaker dedicated only for your Jacuzzi. I
If you already have it, that's great, but if not check with an electrician for installation.
Regards
Apr 05, 2011 | Jacuzzi Mito, 5 Soaking Bathtub -...
Why does black slimy film come out of my jacuzzi everytime I use it even though I clean it? and now my drain is clogged
black slime come from not using regularly..fill jacuzzi and pour a cup of dishwasher detergent and turn jacuzzi on for a while..
Nov 21, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Feb 22, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My Jacuzzi won't turn off or heat
The heater will only fire if it has water in it. If you just got the house, make sure the gas/electric to the heater is on. Turn off the pump and turn it back on.. See if that works. good luck
Jun 05, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
