Question about FreeMotion Exercise & Fitness
I have a freemotion xtr90. It has been in storage for 6 months a) the incline is not working - goes 0-12 but doesn;t raise b) some of the led lights are not working anymore.
I have tried to read the manual and search on line. i have tried to run the motor and go up and down with the controls.
  • jordan
    jordan Dec 10, 2014
    I have also tried to re-calibrate the device by going through the methods found in this forum. Now it won;t jump from 0-12 and will show it increase with each press of the incline, however the platform will not raise.
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
  • 40 Answers
SOURCE: the incline is frozen in about 6% inclination
Try calibrating the incline. That almost always fixes that problem.
SOURCE: I have a pro-form 550 XL treadmill its in #10 deg.
i ran into the same problem today with another proform model. i shut the machine off and lifted the platform to the stow position and brought it back down, turned it on. it worked fine during a workout. i was using an ifit sd card when it got stuck. were you? just wondering.
Posted on Feb 06, 2010
SOURCE: I have a proform j8li treadmill, all 4 led lights
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
Posted on Feb 09, 2010
SOURCE: incline on treadmill is acting strange
Open the motor cover. There should be a service sheet in there.
Read Option 2 & try it.
Posted on Feb 12, 2011
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
Aug 11, 2014 | Proform XP 580 Trainer Treadmill
Sole F63 Treadmill Incline Error
http://electro-medical.blogspot.com/. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience
Jun 26, 2014 | Sole Fitness F63 Treadmill
I have a Freemotion XTR90 treadmill that stops / resets after 5 min of use.
see the video attached, Lube the rollers bearing too Front+back. However you must test the main motor, measure the input voltage terminal at motor, if there ARE AND THE motor NOT run the motor is faulty. 2) test the output voltage terminal control board, for input voltage motor, if there ARE NOT the board is faulty. see the diagram attached.
Nov 26, 2013 | HEALTHRIDER R60 SoftStrider Treadmill
Tt30 is stuck at 3% incline and will not speed up or slow down. It also beeps continually and displays SB for about 5 seconds when first turned on. I tried the recalibration procedure and it does not...
please RUN the software calibration for easy diagnostic and fix it.
go to HOOD cover motor, and follow the steps, or ready your owner manual
God bless you
Oct 15, 2013 | FreeMotion Tt30 Incline Trainer
Incline not working
The Trainer is reading; Serching for motor controler
Sep 09, 2012 | FreeMotion I7.7 Incline Trainer Treadmill
Freemotion xtr90 treadmill will start and run, but belt stops abruptly.
please LUBE the deck belt inmediately.
2) LUbe the rollers bearing too
3) test the input voltage motor , if there are the motor need repair.
4) Test the output motor board,if there are NOT voltage the board is faulty.
God bless you
Aug 26, 2012 | FreeMotion Xtr 90 Treadmill By Free Motion
How to safely move a freemotion x3 incline trainer to different location
please the video and proceed according:
God bless you
Jul 11, 2012 | Exercise & Fitness
My treadmill belt doesn't move at all
Contact the seller for help or send it back if it's only a month old, it must be under warranty.
Jan 25, 2012 | FreeMotion Exercise & Fitness
How do i raise nordic track treadmill?
if that is where it catches then that is how far it goes there is no adjustments. Make sure the incline is the whole way down
Aug 01, 2010 | Nordic Track Nordictrack Exp 1000...
Freemotion treadmill incline not going all the way
The problem is either in the lower control board or the lift motor. I would start by replacing the lift motor. Then if that does not fix it, replace the lower control board.
Apr 06, 2010 | Icon Exercise & Fitness
Exercise & Fitness Logo
74 people viewed this question
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
