Took trap apart but dont know how to dissassemble
SOURCE: Need technical diagram of single hole faucet
Not sure where to find the diagram, but what type of faucet is it and where is it leaking? It it's a single lever, remove the hot/cold indicator to uncover an allen set screw. Loosen it and remove the lever, then the outer bushing nut. Now you'll have access to the interior parts around the cartridge (make sure you turn the water off to the supply lines before proceeding further). If it's the two handle type, remove the index buttons from the top of each handle to uncover a screw with either a slotted or phillips head. Remove the screws and remove the handles. You now have access to the valves and seats. If it's a 12-year-old faucet, the o-rings and seats will probably need to be replaced and this will fix your problem. If it's a single lever type, you'll need to replace the seats and springs and it will probably solve the problem.
SOURCE: Low hot water pressure on Grohe LadyLux.
1. If by replacing the flexible hose you mean the hose for the pull-out portion - you have more than likely kinked or bent the supply line to the hot (left) side of the faucet.
a) If this supply is braided, then simply shutting of the water supply, removing the braided line and either replacing or attempting to straighten it out will be your best bet.
b) If the supply is copper, you will have to cut the line cleanly and carefully. you will then most likely need a 1/4" or 3/8" compression/quickconnect BY 1/2" IP fitting to complete your repair.
2. Other possibilities include:
a) Failure inside the faucet body which will most likely be warrantied by Grohe if you push them hard enough.
b) A problem at your hot water tank, most likely the outlet side and *perhaps* you hadn't noticed the problem elsewhere.
c) The hot valve failing to reopen fully despite all appearances; applies if you turned off the water under the sink for your repair.
SOURCE: I have a Grohe Ladylux Plus and the water pressure
If it is just this faucet and no others then it is likely the filter screen in the tap head is clogged.
Remove the cover from under the tap head. Pries off from the tap head directly where the water comes out.
There is a metal mesh screen there. It will be full of white chalky deposits from minerals in the water supply. Clear that out and you will be good to go.
You will also want to clear the holes for the spray pattern. The same deposits will be there.
Good luck.
If this helped give you some direction please rate the answer for me.
Thanks.
SOURCE: Water flow from grohe ladylux kitchen faucet has
If it has a removable aerator screen, remove it and clean it out. If it can't be removed, try soaking the entire head in white vinegar for a couple of hours. You should see a big improvement.
SOURCE: How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
