Question about Frigidaire Kitchen Ranges
How to put oven door on - Frigidaire Kitchen Ranges
  • Official Brand Answer
  • 2,267 Answers
I appreciate your inquiry, Jeannette!
From my understanding you would like to put your door back on your Frigidaire oven. Typically, you would need to align your door and place it back upon the hinges. Could you provide me with your model number please? With that information I could make sure to provide you with the proper instructions to install your door. You can find your serial tag (which lists your model number) on the lower oven drawer. I look forward to assisting you further. -Matt
Posted on Dec 10, 2014
Oven door closes but does not fit snugly against the face of body of oven. have taken door out and put back in/on with no joy, owner of oven thinks it has been like this since new.
It is like that on the bottom, of my own door of my oven.
Since new! On the older oven I had, you lifted the door and it's hinges up and out and the door came off to make the old way of cleaning the oven easier - when you put it back on, the door would pull up tight on all sides - new ones' seem to have a gap
Mar 12, 2015 | Ovens
Putting door back on but hinge wont release to put back on
Hi Susan, this is AP! Thank you for your post.
I understand you are having trouble putting the door back on your Frigidaire wall oven. Without knowing exactly how you removed the door I cannot say with certainty how to reattach the door. However, when removing the door did you pull up the lock located on both hinge supports and engage it in the hinge lever hooks? You might have had to apply a little downward pressure on the door to pull the locks fully over the hinge lever hooks. Then grab the door by the sides and pull the bottom of the door up and toward you to disengage the hinge supports. If so, then to reattached the door grab the door by the sides; place the hinge supports in the hinge slots. Open the door to the fully opened position. Disengage the lock from the hinge lever hooks on both sides. Make sure the hinge supports are fully engaged before unlocking the hinge levers. Then close the oven door. There are instructions with images to remove and replace the oven door in the owner's manual. I hope this information proves helpful for you.
Mar 14, 2014 | Frigidaire FEB30S6D Electric Single Oven
FIXING DOOR (DOOR IS COMING OUT)
The large oven door pull's off , and can also be pused back on the same way , if holding the door about 12" from closing pulled towards you to remove or push down to put back on if you pull it off the hinges it may take two to put it back on again
Jun 08, 2011 | AEG B2100-4 Electric Single Oven
Fire in oven. Fire Department had to force door
no,you need a new range or a new oven door depending on how bad the fire in the oven was.
Jan 28, 2010 | Hotpoint RGB745 Gas Kitchen Range
The oven door won't close JGS968
The hinges are sping loaded Take the door off to see how much he bent it maybe you can bend it back or the screws can adjust it.
Dec 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I can't remove the door on a whirlpool oven model RBS305PDB
I removed the oven door without putting in the door removal pins that I was supposed to use. Now I can't put the door back on.
Oct 22, 2009 | Whirlpool RBS305PD Electric Single Oven
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
The oven door are not closing all the way
spot, Maytag put out a service bullitin on this issue....TDC-0017B-B, They put out a new hinge kit...part #12002111 for single and 12002112 for double units. This may be covered under this service flash. Call Maytag service and inquire about the above mentioned service bullitin. Problem addresses doors not closing...Catriver..post back.
Sep 03, 2006 | Jenn-Air WW30430P Stainless Steel Electric...
Kitchen Ranges Logo
74 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
