My Dayton 110,000 btu kerosene torpedo heater... The fan kicks on for a couple secs then kicks off it seems as it's not getting any fuel what should I do
    Sergeant:
  • 236 Answers
Could be the Flame out sensor cutting the power to the electrics and therefore the forced air fan. It forces the heater to shut off should the flame extinguish. It might also be the temperature limit control which also turns the heater off if the internal temperature rises to an unsafe level. If either of these two possibilities the unit may need a service.
Posted on Dec 13, 2014
  • 3 Answers
SOURCE: Dyna Glo Pro RMC-KFA70TDGP 70,000 BTU Torpedo heater not igniting
The main circuit board supplies ac power to the ignitor ( black transformer looking device) and the transformer increases the voltage that is supplied to the sparking device. Make sure the wires are connected to the sparking device and the ends of this device are approximately 3mm apart and that it is in the general position near the end of the nozzle. If you do not hear a "clicking" sound it could be the main board, wires or sparking device.
Posted on Dec 17, 2008
SOURCE: Dayton Model 1VNX5 Kerosene clicks like crazy but won't light
I have the same heater with the same problem. I took the top cover off, removed the ignitor and bent the probes slightly closer. Use two needle nose to prevent breakage of the holder. It has been working fine since.
Posted on Jan 31, 2010
Buffalo12980
  • 625 Answers
SOURCE: Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Posted on Dec 06, 2007
  • 288 Answers
SOURCE: older torpedo style kerosene 50,000 btu smokes
clean out the fuel nozzle and if it wont burn cleanly, replace it.
Posted on Jan 03, 2010
hardrocko
  • 1476 Answers
SOURCE: dayton torpedo heater 150 btu starts and runs
All these types of heaters use mostly the same parts and dealer for one brand carry parts for most brands. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to get the parts to fix your unit. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Posted on Mar 13, 2010
Heater starts, fan runs, injecting fuel but won't fire up
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 20, 2011 | Reddy Heater 60,000 BTU Kerosene...
My Master 110,000 btu heater won't start after plugging it in. The tank is full of fuel. Any recommendations .
heatman101
Dec 18, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Fan starts no ignition then cuts off
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jun 08, 2010 | Reddy Heater-75-125,000 BTU Variable
Ready hater 110,000 btu
replace the nozzle and check the fuel filter - if this is a kerosene heater. under the access plate is a round filter - remove it completely or change it.
Dec 18, 2007 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
