Question about 1986-1989 Honda Trx350 Standard Seat Cover Gray Manufacturer Saddlemen
The motor stop when get in gear - 1986-1989 Honda Trx350 Standard Seat Cover Gray Manufacturer Saddlemen
    Genius:
  • Saddlemen Master
  • 1,028 Answers
Vacuum leak, dirty air/fuel filter.
Posted on Dec 20, 2014
My whirlpool 6th sense azb7570 has stopped turning?
If it is belt driven, the belt has come off, stretched out, or has broken. If it motor/gear driven, the gears are stripped or the motor has died..
Aug 04, 2016 | Whirlpool Dryers
KitchenAid Mixer struggling to spin?
Check everything you have done for a mistake, the pin through the planetary, the pin through the fuse gear and the pin in the main shaft that drives the bevel gear. That's the gear that pinion gear on the fuse gear shaft mates with. After that you are left with a fuse gear fault. I am assuming that the motor is turning at normal speeds and not somehow binding up, no reason why it should as motor stays in one piece during gear changing procedure.
Apr 18, 2014 | KitchenAid Food Mixers
My electic chain saw works intermitently. motor goes, chain doesnt.
yes the gears can strip look at sears parts online for a break down
Mar 24, 2012 | Ryobi Garden
Kitchenaid Professional HP mixer, motor stopped while making dough. I let everything cool down and with no attachments it will not turn on. As soon as you turn it on the motor gets hot but no noise or...
Open the Transmission Housing and remove the two screws holding
the Motor. Lift it off the gears and test run it by itself. The motor
should run normally at different speeds. If it does, then you can move on
to the gears. Manually turn the Worm Gear and make sure nothing got jammed.
The Bevel Gear should turn smoothly.
Jul 18, 2011 | KitchenAid KP2671 Professional 6 Series...
Corvette Headlight Motor Problem
Corvettes have a gear box on that motor. It has plastic gears in it. You probably have a gear stripped in that gear box, that lets the motor spin free. You can get repair parts to repair it, or replace the whole motor and gear box. Its an easy fix if your handy. Read all the instructions before you start.
Dec 27, 2009 | 1989 Chevrolet Corvette
Thecutter stopped turning any ideas?
The cutter stopped turning..... did the motor stop turning.????
If the motor turns but the cutting blades don't turn then you have probably lost a gear/ or teeth in a gear.... open and check... you can call Royal at 1-800-524-0799 to get parts.
Nov 14, 2009 | Royal 160MX Shredder
Replaced wiper motor,twice, when i turn it on the arms move about two inches,then stop .then they.sound like there slipping .just move up &down about two inches. 88 celebrity
This doesn't sound like a motor problem but a gear stripped. The motor and gear are normally sold and installed as a single unit. See if you can move the arm manually. If you get a lot of slop it could be a stripped gear. Turn the wipers on and move the arm manually. It may catch and than stop at the broken part of the gear.
May 07, 2009 | 1988 Chevrolet Celebrity
Power window not working, motor and electric good, whats wrong?
Well either the gears aunt lined up correctly or the motor old and tired. Doesn't have enough power/torque to spin gears. might just need a new motor.
Apr 26, 2009 | 1991 Ford Explorer
Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
Jun 08, 2008 | Office Equipment & Supplies
Oscillation stopped working!
Sounds like the drive gear is stripped.
Nov 20, 2007 | Bionaire BAP1500-U Air Purifier
1986-1989 Honda Trx350 Standard Seat Cover Gray Manufacturer Saddlemen Logo
Top Saddlemen Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Saddlemen Vehicle Part and Accessory Expert? Answer questions, earn points and help others
