Question about RCA Televison & Video
How do I program my RCA LED48G45RQ HDMI to digital channels
I have tried Channel scanning, but TV only pick up Analog channels
  • 23 Answers
Several things to check. First go in the menu where u are doing the channel scan and see if there is a separate line that says digital and if so select it so it can add those channels. Next look also on the remote and see if there is a button that says ANT or Input and press it to see if selects the digital side. Next see how u are hooking up the set from either cable, SAT, Antenna, etc, and are u going thru the antenna connection/the screw on cable input. Cause if going thru hdmi or any other input will not allow u to scan channels. Next the tv may not have a digital tuner in which some new sets don't, look in owners manual and read on channel programming and it should tell u. Maybe something here will help.
Posted on Dec 09, 2014
  • 16 Answers
SOURCE: TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Posted on Dec 07, 2008
  • 10 Answers
SOURCE: RCA L37WD22 not receiving analog
The problem is on the signal board. Same problem and fix for L42wd22, and L46wd22 models.
I can fix this board for a FRACTION of what a repair tech will charge you. Email me at aplusrepairs@triad.rr.com
Posted on Dec 22, 2008
  • 362 Answers
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth. http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Posted on Jan 13, 2009
  • 3 Answers
SOURCE: Digital channel signal blue screen only
Press the "INPUT" button and make sure "TV" is highlighted.
Posted on May 18, 2009
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
My VCR not recording after the switch to digital tv signal
The answer to this question can get a little complicated. Lets tackle it in two parts. First the last part; the part about picking up channels as decimals. With analog TV transmission, it took the full television broadcast channel to transmit one standard definition TV program. The newer digital transmission system uses some advanced video compression and audio compression technology to reduce the data needed to transmit the pictures and sound which allows the same bandwidth to deliver either High Definition Television programming or MULTIPLE channels of Standard Definition programs. So in your example above, you use to watch one channel of programming on TV channel 4, but now the TV station can broadcast multiple channels of programming on channel 4, sot they delineate the programs with a decimal point. So 4.1 it the first program on TV channel 4, 4.2 it the second program on TV channel 4..... Well, I hope you get the idea.
Now for the hard part of your question. I believe that before the transition, even with your new digital TV, you were still enjoying the analog broadcasts from your stations. Your VCR picked them up and recorded them and your digital TV could tune them in and you watched as you had always done in the past. After the transition you noticed that your VCR could not record anymore and your digital TV had discovered the digital channels that replace the analog channels. To remedy this situation, your VCR will need the aid of a DTV converter box to tune channels, and you may have to reconfigure the way your TV and VCR are connected. The best resource that I can give your for the reconnecting is the website http://www.fcc.gov/cgb/consumerfacts/converterbox_vcr.html. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Scroll down to the Normal 0 false false false MicrosoftInternetExplorer4 section about “Set-up #2: Watch One Channel while Recording a Different Channel”.
Hope this helps
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
No tv signal on my olevia 232-s12
Jun 19, 2009 | Syntax Olevia 226T 26 in. LCD Television
WHY MUST I RESCAN ALL THE TIME?
You may have several problems. If you are using a indoor antenna, upgrade to a outdoor antenna. The indoor antenna has to be adjusted every time you change a channel. If you plan to sit in a chair and never move when watching tv, you may be able to pick up a channel or two. Get a UHF/VHF antenna from a home improvement store. The big box electronic stores are selling a digital antenna. There is no such thing. The antenna doesn't know if the signal is digital or analog, it just picks up uhf and vhf signals. The other problem could be that the box is bad if it is not saving the scan. I would check the antenna first from what you said though.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
Rca 14" truflat
This set was made before it was required to have digital tuning built in. You would need a digital converter box if you want off-the-air reception. (The federal program at www.dtv2009.gov that is giving $40 coupons toward purchasing a converter is out of money right now and is only putting people on a waiting list. It also looks like the changeover to digital is going to be delayed again, so you might not need to worry about it for a while longer.)
Feb 06, 2009 | RCA 27F534T TV
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Televison & Video Logo
435 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
