Where do i find a door seal for a woodchief model wc3-78 auto wood heater
Looked on line
    New Friend:
  • 3 Answers
Door gaskets for wood burning stoves come in a verity of sizes ranging in different diameters for round gaskets, and thicknesses for flat gaskets. First determine which type you require, then measure the diameter (round) or thickness (flat) at a point that has not been compressed by the door. If you search the make and model of the unit online, you will likely find the measurement that you need. Many hardware stores and lumber yards (Canadian Tire in Canada) carry an assortment of sizes and kits that also contain the high temperature adhesive.
Posted on Jan 02, 2015
    Sergeant:
  • 236 Answers
If you are in the US then this link may be useful. WC3 78 Suburban Wood Stove Parts
Posted on Dec 13, 2014
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
I have century wood stove , how do I keep the seal on the door to stay in place. The seal looks to be in good shape, do I need to glue it in, using what product.
You need Gasketing Sealant and Stove Sealer which is a Red Devil product. Good for 2,000 degrees. Don't buy the cheap stuff, read the lable, as some is only good to 550 degrees and will deteriorate rapidly and fall out.
Nov 22, 2014 | Century Heating Wood Stove Fireplace...
Woodchief stove
It could be a draft issue . In order to work properly the stove needs to be able to draw air in to replace the airgoing up the chimney along with the smoke from the fire. In old houses this was not a problem be cause they were loosely constructed and replacement air could be drawn in around windows and doors and gaps in the walls. Newer homes are a lot tighter therefore no replacement air can get in. In some cases the house is so tight that running an exhaust fan or dryer actually creates what is known as a negative pressure situation if this is the case air can be drawn backwards down the chimney and into the house bringing the smoke from the fire with it. To check for this try starting a fire with a window or door partly open. If the fire drafts correctly you may have to install a make up air for the stove. Hope this helps.
Dec 08, 2013 | Heating & Cooling
Mildew in woods refrigerator
If it is being used, it should be too cold for mold (Mildew) to be able to grow. Upright refrigerators already have a circulation fan in them. Mildew won't form in an environment that cold unless the fan is not running and there is a small air leak around the door seals. The picture above looks like a commercial box. If so, the fan is normally mounted and easy to see, mounted on the top panel, inside of the box. If its a residential model, the fan can be berried behind the back inside panel and difficult to access. If there is a switch visible around the door frame, pushing it in should start the fan. I'm guessing that the mildew is present on the door seal? Try sliding a stiff dollar bill between the door seal and the refrigerator all the way around the door. If it makes it in any where, the seal is leaking at that point. If I am way off with all of this advise, let me know in detail how this is wrong and I can go from there. Hope this is good advise for you. Let me know. Good luck.
Dec 02, 2013 | Woods Freezers
Trying to find piece of heat resistant fabric (don't know name - something like old asbestos) to replace degenerating fabric on light fixture gasket on otherwise perfectly working caloric electric wall...
If it would help you to find the model number, I would look for a way to remove the oven door. Usually there will be a release near the hinge bracket that you push in or push to the side to allow the bracket to release and you can remove the door to see the ID plate. Otherwise, I would suggest going to a wood stove dealer and looking at the door gasket material they have in stock. They usually have rolls of heat resistant gaskets for sealing doors and glass panels in wood stoves. Last idea would be exhaust gasket material available at Napa Auto parts. Good luck!!
Nov 04, 2013 | Ovens
We installed a Woodchief wc 100c woodstove and i
Hello, I have the same model. The plate on the back say's,install with min installation clearance's side and rear wall 18 inches fire door end 36 inches front 48 inches above 51 inches flue pipe 18 inches install on non combustible and non conducting base of 9/32 inch min thickness that extends 6 inches beyond the sides and 18 inches beyond fire door side. circulating fan type FF-100
Feb 23, 2010 | Heating & Cooling
Door gasket icing
Icing is caused by warm, moist air hitting cold air. Either your gasket is not properly sealing to the frame or the door frame heater is either off or not working. Some units have an off/on switch for that. The heater is usually referred to as an "Anti Sweat" heater. Make sure the door is closing and sealing. The door frame should be slightly warm to the touch. If not, look for no power to the heater or the heater could be damaged/ burned out.
Good luck and hope this helps,.
Mar 21, 2009 | Freezers
Replacement door seal for walk in freezer
First, call Restaurant Parts and More (1-888-814-1110) and ask for Rick. He can help either get you the seal or have one custom made. I've used him for 15 years with great success. If you have model and serial, it would be even greater.
He can do the same for the heaters that go around the door frame.
Don't understand which "Line" you are referring to. In alot of cases, the drain on the drain pan is clogged. This causes water to overflow onto the floor. The drain can be clogged from trash getting into it. Most of the time, the drain heater is either not working or not ever installed. Water refreezes in drain line and causes the overflowing problem.
If this does not help, let me know. Clear up the "Line "question and maybe I can go alittle deeper into this.
Aug 16, 2008 | Freezers
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
