Question about Refrigerators
Samsung side by side rs26tkapn cube selector not switching off
Can't change dispenser selector
seems defective control panel in front of fridge
Dec 06, 2013 | Maytag MZD2667HE Side by Side Refrigerator
My icemaker won't deliver cubes despite switching from crushed to cubes on selector, what's a guy to do
you have to take apart the complete ice maker from inside the freezer as it has to be cleaned on a regular basis to operate properly. check with your owners manual, it tells you how to clean it.the ice cube shoot is the first to freeze up & block your flow of ice. it's not hard to do. all the best.
Dec 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The buttons that select water, crush or cube do not function. I can get crush or cubed ice but the water button does not work. I have tried turning off at the mains and starting again but still there is a...
remove the front cover off this selector panel(if equipped) and replace the interface board in behind here as the little switches are bad and theres no fix to these boards
Jul 02, 2011 | Admiral 26 cu. ft. Side-By-Side...
My icemaker won't switch back to cubed ice. all i keep getting is crushed ice. HELP
If you select cube and hold open the door and push in on the light switch and have someone push the lever for ice you should hear a loud click this is from the selector switch in the back that engages a long brass colored rod under the ice maker if you hear this loud click you probably have some crushed ice in the crusher keeping it from switching back open the door and push in on the light switch and have someone push for cube ice it will kick ice out the bottom so dont be alarmed. (sometimes you have to do this a couple times) good luck
Aug 16, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Ice crusher will not run
It is run by an auger motor that is energized by the switch when you press the lever with a cup on the door. Open the door and find the auger drive.....it is usually behind the ice bin. try to turn it by hand. You should be able to turn it....if not it is either frozen or locked up. A lot of times I just take them out and run hot water over them till they defrost. Another thing you did not mention is if the cubed is works. If the cubed ice works but not the crushed then the problem is the selector solenoid. There is a solenoid that switches from crushed to cubed. Usually you can see it next to the auger drive. It should freely move up and down....if not, it is frozen and needs to be thawed. The last thing it could be....but rule this out if the cubed ice is working.....the switch that is energized by the lever on the door could be bad. The auger motor and the selector solenoid are located in a white box behind the ice bin. Pull out your ice bin and you will see a box with the drive sticking out and the selector solenoid to the left. try to move the selector up and down with your finger......if it wont move or if it moves itself back up then it is probably frozen. If you look towards the bottom of that white box you will see 2 screws on each side of it, remove those and the box will come out and you can defrost it. You will have to take the icemaker with it on most of them. Just remove the screws and lift it out. Hope this helps
Sep 10, 2009 | KitchenAid KSCS25FKSS Side by Side...
My icemaker, a ge profile is only making crushed ice, no cubes,
There is a selector for crushed or cube and is usually at the dispensor.or above it. good luck
May 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker is crushing ice when cubed ice button is on
The problem is in the selector switch itself. If it is a touch pad, you will have to reset the control board by unplugging the until for 3 min. if its a physical switch, it may be faulty and will need to be replaced.
Good luck. please rate my answer as a fixya!
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Door ice dispensor will only dispense crushed ice
Pull out the ice drawer and close the door switch the crushed /cubed button put the ice drawer back in and switch the selector button again. You might have to repeat the process I had the problem this week and by jiggling everything around and running a good bit of ice thru it started working again. Good luck
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
