Question about Maytag MHW6000XG Maxima High-Efficiency Front Load Washer
How do I get to the pump
Taking off the door and trying to get the front panel off of the front loading washing machine.
  • 125 Answers
Through the back of the machine
Posted on Dec 09, 2014
Horible smell comingfromthe drum, took the filter out to clean it, now it is leaking, what can I do? ps smell still there, have tried 1 95o wash with no joy
For the pump try taking filter back out and putting back again for smell clean out the rubber door seal with soapy water after the door seal is clean clean the despencer draw fully by taking it out. When you washed the seal and draw get washing machine clean for local super market and do a 95oc wash it should smell nice now if not could be drains hope this helps.
Jul 29, 2011 | Hotpoint Aquarius WF220 Front Load Washer
We have a load in....it is full of water....it wont drain and spin...the cancel button doesnt work and door wont open....I checked for kinks in drain hose...none. I took off top panel and front lower...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 12, 2010 | Kenmore Washing Machines
Duet GHW9150P Front Load Washer: front load whirlpool washing machine runs fine unt...
You can try this:
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
Top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front loading commercial washer door will not opne
You need to get access behind the front panel, taking the top panel off is probably best. Then you can see the the door release mechanism and release it.
Feb 09, 2009 | Kenmore 43042 Front Load Washer
Frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Oct 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Maytag MHW6000XG Maxima High-Efficiency Front Load Washer Logo
145 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
