Question about james zhang Submarine animals wallpaper
Can i get one of yalls usersnames and passwords for aniaml jam.
Nothing
Forgot my password and usersname
try ophcrack to get back your password....
Sep 13, 2013 | HP Pavilion DV8225NR Notebook
How to view usersnames and passwords in xp winds?
For "username" you can check in the control panel:
Start > Control Panel > User Accounts
But about the "password" I suggest you try 7 software as suggested in:
http://pcsupport.about.com/od/toolsofthetrade/tp/passrecovery.htm
Hopefully this helps.
- Rocky
Nov 28, 2011 | Microsoft Windows XP Home Edition English...
I son has changed my username and password, i still have the password to get into the bios screen but has no option to boot in administrator or change the user/passwrd. HP MINI 110 1081TU
Restart the system let come usersname screen,press CTRL+ALT+DELETE key press on the keyboard same time.on the username u can type administrator and login,then right click on my computer-click on manage-computer management screen appears then leftsidepane you can see Local users&Groups,click there,on right side pane doubleclick on users,u can see there ur usersname,which userpassword u forgot rigtclick on the same user click on set password then proceed and reset or u can put there as new password.then log off and select the user.
May 20, 2011 | Computers & Internet
Turn on oven and temp stays at 75. No gas comes on and igniter does not glow. Replaced igniter and still have same problem. Have 120 volts in and out of igniter and it does not glow. Help?
Lets take a look at yer wirin diagram.
You have 4 components in the oven heating circuit. The control, the ignitor, the safety valve, and the sensor.
Ignitor has been replaced with no help right? Did you check for continuity of the gas safety valve?
themobilian_1659.jpgIf yall have nothing (open circuit) between the two terminals then the valve is bad. Won't no ignitor glow with an open safety valve. Next thing:
Sensor: 1100 ohms @room temp. Erratic or open sensor and the oven won't KNOW what the temp is. themobilian_1660.jpg
Finally and I say finally because yall want to replace the most expensive part which is the control last, after yall know for sure it ain't all of the above mentioned components.
I have some service manuals and more HERE
Mar 03, 2011 | Maytag CWG3100A Gas Single Oven
I try unlocking my phone i1 by putting a wrong pattern too many times and is aking for my usersname and password
Hi, You may contact to your service provider Motorola i1 Unlock Code, they will supply you a code fast. You may visit Motorola Unlock Code site, they will provide an accurate code with easy to follow instructions on how to unlock your phone. Once your phone is unlock, it will work with any network worldwide without sticking to one network only.
Hope this is helpful.
Thanks.
Feb 05, 2011 | Motorola Cell Phones
I forgot my password and my usersname for my apple laptop
If you have the osx install disc, start up from the disc and when you have selected the language select the utilities menu from the top toolbar. In here you will find a utility for resetting the password.
Mar 29, 2009 | Apple MacBook Mac Notebook
D-link
I'm afraid your only option is to reset the unit to factory defaults & then login as username "admin" with no password. You will then need to reconfigure the unit. This is covered in the manual which you can download from a link on the following page: http://www.dlink.com/products/?pid=316 Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 18, 2007 | D-Link AirPlus DI-524 Wireless Router
james zhang Submarine animals wallpaper Logo
398 people viewed this question
Top james zhang Apps Experts
Are you a james zhang App Expert? Answer questions, earn points and help others
