Question about Westinghouse Televison & Video
We just purchased a 55 inch Westinghouse tv and I've notice with a full white screen what looks to be a plaid pattern. It's very slight with squares that are approximately 4 inches.
I gone through the User's Manual looking anything related to this issue.
  • 711 Answers
This is tiling which should disappear when you select a better resolution on display via remote.you should be at 720p so anything below that setting will pixelate or tile.
Posted on Dec 09, 2014
HOW CAN I FIX MY WESTINGHOUSE 22 INCH LED TV? IT HAS HORIZONTAL LINES COMING UP FROM THE BOTTOM 1/3 THE WAY AFTER IT HAS BEEN ON FOR 10 OR MORE HOURS.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 13, 2017 | Westinghouse Televison & Video
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Analog white-westinghouse tv has blue screen and no sound. Connected to digital converter. screen does not change and after 5 minutes the tv shuts off
the glitches could have fried part of the tvs main chip
i have had it happen to me a few times and or it was a fuse
Aug 06, 2012 | Televison & Video
Left half of screen dimmer than right
same issue with my 47le5900 - I have fixed it... if I look through the back panel I can see a circuit board on the right... coming out of this at the top are two flat data cables, each about 1 1/2 inches wide, one is labeled (L) the other (R), it seems the (R) one was a little loose, so I pressed it downwards with a small screwdriver, problem solved.
Jun 25, 2012 | LG 42LE5500 42 in. TV
Tartan Pattern on screen of 55 inch samsung led tv
Suspect main board that processes all signal in and to the screen.
If not tried do see if same problem when rear inputs for audio/video are used.
May 25, 2012 | Samsung Televison & Video
Line of distorion (or picture shift) on screen
Same thing happened to me but it was my cox hdtv/dvr box, I exchanged it and it resolved the problem.
Jan 04, 2010 | Televison & Video
Green Plaid lines on Samsung HLR5067wax/xaa-
These are the Tests that should be run to determine which board is bad.You should call a good TV Tech if you are not familiar with this TV.
- The DDP1011 on the DMD board has a feature to display internal test patterns.
- DNle, which is an end port in the digital board, has a feature to display internal test patterns.
- The analog board sends signals to ADV7402 on the digital board.
- The analog board is the first output and the digital board is the second one, followed by DMD, which is the final one.
■ Diagnosis By Module
1. Access Service Mode
(In Standby mode, press "Mute", "1", "8", "2" and "Power" to turn the screen on and enter service mode)
2. Check if there is an error in the DMD board
DDP1011 → TEST PATTERN → Press the right arrow key:
Options of FULL WHITE, BLACK, RED, GREEN and BLUE PATTERN are displayed on the screen.
If "Pattern" does not appear, this is a DMD board error.
3. Check if there is an error in the digital board before the DMD.
When the DMD board has been determined to be error free based on the test patterns:
FACTORY MODE → DNIe → TEST PATTERN normal display: no error in the digital board.
If "Pattern" does not appear, it may be from a DMD board or ATI error or there is an analog board malfunction.
4. Check if there is an error in the analog board.
Check for a power signal from the analog to the digital boards
Jul 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Televison & Video Logo
64 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
