Question about Vantec Computers & Internet
My Nexstar 3 drive will not load. Any Suggestions?
NexStar 3 external drive will not load. I tried on 3 computers.
    Scholar:
  • 59 Answers
Let's start with the basics:
1) Is the drive getting power; is the supply correct and the connection firm? Does the drive spin-up at all?
2) Is the data cable known to be good?
3) Is the port on the computer known to be good, mechanically and electrically?
4)Does the OS support this device, or does it require additional drivers?
If it worked before, 9 times out of 10 a bad connection somewhere is at fault. Even if software or data corruption is involved, the cause is almost always an intermittent connection.
Posted on Dec 09, 2014
Testimonial: "After trying it on 2 other machines I took the hard drive out of its case and hardwired it into the computer. It came up and I could read the files. I formatted the drive and its working fine. Thanks for all the help!!!!"
  • Joe McGuigan Dec 11, 2014
    The drive spins up. It appears to be loading. The green bar moves across the top but hangs at the end and does not finish loading. I've tried it on 3 diff. computers and it does the same thing. It had worked up until last month.
Vantec Nexstar 3 driver download
Vantec Nexstar 3 drivers can be found at driverupdate us.Take a look, and enjoy
Apr 04, 2010 | Vantec NexStar-3 External 3.5inch...
I have a NexStar 3 external hard drive that is not being recognized by my computer. It used to work now it gives an unknown device message
remove the hard drive restart your computer the plug the hard drive back into your usb port this should come up with new hard ware found and install the driver If not try a different usb port or your sata drive
Mar 30, 2010 | Vantec NexStar-3 External 3.5inch...
Windows 7 NexStar drivers and installation needed
No device-drivers are needed. Just connect this USB device, and Windows will recognize it. If there is a "one-touch-backup" button, it won't work, but you can still use drag-and-drop to copy files from your internal disk-drive to this external disk-drive.
Jan 01, 2010 | Vantec NexStar-3 External 3.5inch...
All of my applications are closed and I cannot eject my NexStar device. How do I safely eject it?
Occasionally this will happen... if you are not using the drive in any way, you can simply remove the usb cable from your computer and it will not affect your external harddrive.
Sep 08, 2009 | Vantec NexStar 3.5in External Hard Drive...
Can my Vantec NexStar 3 Hard drive SAVE?
You might want to take the drive out of the case and use and external drive connector to see if the drive still works.
https://www.amazon.com/Drive-Adapter-Converter-Optical-External/dp/B002OV1VJW
Sep 02, 2017 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
May 19, 2008 | Vantec NexStar-3 External 3.5inch...
Nexstar IDE to USB, Will Not Show Up
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Apr 06, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Nexstar
Its normal, and is the signal showing the drive powering/spinning up and down. The drive spins at 7200 rpms, when you power it up or down, its switches onto the speed that best suits  what it's intended to do.
Oct 14, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Nexstar External drive
If neither computers detect it, which is a good form of process of elimination, I would test the cable with a known working. I would then extract the drive from the enclosure. And try mounting into a desktop machine as a slave, or find another enclosure.
Oct 04, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Computers & Internet Logo
Top Vantec Computers & Internet Experts
Willem.
Willem.
Piyal Perera
Piyal Perera
David Payne
David Payne
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
