Question about KitchenAid Dishwashers
My Kitchenaid KUDS25 dishwasher will not fill with water. This started right after I had shutoff the water supply to fix a kitchen faucet problem. I started the dishwasher and forgot to open the wat
Turned the water supply valve off and back on in case there was blockage. I have started the dishwasher several times and then ran the cancel process.
  • Greg Rodenbeck
    Greg Rodenbeck Dec 09, 2014
    The drain cycle runs when I cancel the wash cycle; however, it does not run when I start the wash cycle.
  • 125 Answers
You may have kicked your drain hose when you were fixing your faucet. The dishwasher starts with a drain cycle before it fills
Posted on Dec 09, 2014
  • 1 more comment
  • Greg Rodenbeck
    It sounds like it is running the drain cycle once I cancle the wash cycle. It does not run the drain cycle when I start the wash cycle.
  • colinjhought Dec 09, 2014
    I would agree with brad
    try dumping some water in and then try a cycle to see if it drains out
  • KitchenAid Master
  • 17,323 Answers
If you forgot the water supply and ran the unit, there is a chance that the valve has burned out or seized.
Why does my kohler 78061aa limit the amount of hot water coming out of faucet
Blocked inlet.
Supply shutoff not open all the way.
Debris in shutoff valve. This happens in older valves with washers.
Jul 06, 2014 | Kohler K-10430-VS Fort½ Single Lever...
The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
Oct 10, 2009 | Whitehaus Kitchen Single Handle Faucet...
Portable dishwasher won't stay connected to the kitchen faucet
it the faucet connector has a lever u push in order to latch on to the faucet, just jam something under it so it maintains upward pressure and wont come unlatched when the water starts flowing
Jan 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
Kitchen Aid dishwasher does not fill up with water.
yes, the problem is usually dirt in the valve or the water valve under the sink .
Nov 09, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Oct 19, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Dishwasher doesn't want to fill
Hello Dianne...I'll take a shot here.. chances are that the door interlock ( switch ) is disabling the dishwasher from starting.. it may be damaged or disconnected.. and as long as you are sure you have a water supply to the dishwasher,.. that's where I would start...If that switch is NOT made.. the dishwasher will not start... Hope that helps
Aug 16, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Kitchenaid dishwasher
Motor bad. If you are getting power to the motor then the motor is bad.
Mar 31, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Dishwashers Logo
181 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
