Question about Refrigerators
How do I get the ice maker to start making ice again
    Master:
  • 706 Answers
Turn the water back on to the ice maker and also check the off/on switch inside the freezer door.
Posted on Dec 09, 2014
Jenn-Air JFC2089HES ice maker
Try letting it thaw out and re start it.
Jun 19, 2014 | Jenn-Air Refrigerators
My ge monogram ice maker randomly goes into cleaning mode
Your ice maker is electronic and the electronic board inside has failed. Not much you can do in this case except replace the ice maker. Your Monogram uses a=> WR30X10093 Ice Maker Assembly
and here=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Here is a Ice Maker Service Manual that may help should we have missed something=> HERE
Feb 28, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Ice maker not working
pour water in your ice maker. when it dumps ice cubes, keep filling it up again.after 5 or 6 times it should start working on its own
Oct 21, 2012 | Frigidaire Refrigerators
Ice maker is slow to make ice. It dumps sometimes. it builds a large mountain of forzen ice that mounds up under the tray. even though we remove it it always comes back. ice is also runnig down the...
Ice maker problems are almost always a problem. Sometimes I will locate an issue and fix it and then it will work for a short period and then break again. So, now I just replace the ice maker as a general rule. This is much more likely for success. However, the replacement ice maker is often not an exact match. And again, the this and the that sometimes causes problems. I will never accept a new customer on the grounds that I am going to fix their home ice maker. Make sure the ice machine is getter water like it is supposed to. Check the filter and the tubes. If the problem persists, get a new ice maker. If that ice maker angers you, get some ice cube trays.
Jun 11, 2011 | LG LSC26905TT Side by Side Refrigerator
KitecheAid Ice Maker Porblem
check the temperatures inside of the freezer. It has to be at least 17.5 for the ice maker to work correcltly
Feb 07, 2009 | Refrigerators
Ice maker not making ice. red light on control panel blinking twice.
Remove the ice bucket and inspect the ice maker for an ice cube stuck in the ejector. Hit it with a little heat of a hair dryer till it gets loose and the ice maker starts rotating. Replace the ice bucket. See if it starts making ice again amigo.
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice Cube maker stops making cubes as they are being made ....
Ice makers use a small heating element to release the ice from the mold tray..sounds like that isn't working and everything else is. Check to make sure all electrical connectors coming from the ice maker are properly seated into their mating connectors. If that doesn't solve your problem, you may be better serevd by just replacing the entire icemaker assembly.. Hope that helps...
Jul 25, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker leaks.
You have a bad switch in the ice maker need to replace whole ice maker or the switch
Jul 25, 2008 | Frigidaire FRS3R5EMB Side by Side...
My ice machine stopped making ice after the city shut off the water line for more than 8 hours. How do I make it start making ice again.
Apr 23, 2008 | Refrigerators
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
