Question about Kenmore Front Load Washer
My normal cycle is at 1.50 in time for washing i tried to reset to factory setting but would not work. what can i do?
Tried to reset factory by pushing opt and phase at the same time didn't work this has happen before and it worked then
Drain the machine
turn off the mains
hold in the buttons
turn the mains on
retry wash
make sure the drain filter is fully clear and clean
and the intake valves filters are clear
and also the driain waist system isnt slowed up and blocked
at any U bends etc.... if it is washes and drains will take longer
and the machine may detect this blockage as a bad pump etc...
Posted on Dec 09, 2014
Maytag bravos mct washer keeps filling with water on drain and spin cycly
first thing to do is a reset. unplug it for 5 min and plug back in to see if it resets to factory settings.
Jan 21, 2018 | Maytag Washing Machines
Model number KUDS30IVBL0. When in the normal wash cycle the machine will go through the first wash cycle then drains. But the pump keeps running even after all the water has drained from the unit.
if you just let it go will pump shut off by itself after a few more minutes ?? or do you have to intervene as it will go that way all day long ?
Sep 02, 2015 | KitchenAid Dishwashers
Whirpool quiet partner 3 gold. panel lights work and say it is wasing but doesn't start
The timing circuit may be defective and the circuit board needs replacing. Have an authorized serviceman do a continuity test on the board and have it rest to factory specs.
Feb 27, 2014 | Dishwashers
F13814978
Try this diagnostic cycle operation to reset.
To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
Heated Dry, Normal, Heated Dry, Normal
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Feb 14, 2014 | Whirlpool 24 in. GU3200XTP Built-in...
Does my whirlpol du1145xtpb1 dishwasherr need to be reset
SERVICE DIAGNOSTICS CYCLE
Read more: http://forum.appliancepartspros.com/dishwasher-repair/261055-whirlpool-quiet-partner-ii-clean-light-flashing-have-reset-still-flashing.html#ixzz2UOcsE2Yg
May 25, 2013 | Whirlpool 24 in. GU3200XTP Built-in...
Can't cancel cycle without it starting
you have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
Sep 16, 2007 | GE 24 in. Profile PDW7800 Built-in...
Kenmore Front Load Washer Logo
54 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
