Question about Retail Supplies
The cash register powers up but keys not responding
I hvae tried to power off and on.. tried clear key all in reg mode.
  • Retail Supplies Master
  • 1,648 Answers
Did you sort out this problem?
If not, please let me know the brand and model
Posted on Jan 02, 2015
  • 100 Answers
SOURCE: Casio PCR-T2000 Cash Register
select all the data by pressing ctrl+a and press shift+delete to delete ur data
Posted on Jun 16, 2008
flexion1
  • 737 Answers
SOURCE: My Sharp Cash Register (ER-A410) won't turn on in manager mode
Hi.
It is usually caused by a faulty or dirty mode switch. The first thing to try is squirting a bit of electrical lube down the key hole (WD40 or similar works fine), then turn the key back and forth a few times. Otherwise, the contacts inside the switch may have failed. I have also had a loose connector on the main board cause this in another model, so you could try pushing the connectors inside and make sure they are tight.
Hope this helps. You can set the void button to work in REG mode if you don't want to get the MGR mode fixed. Just let me know and I can look up the codes for you. You should be able to refund items as well (unless this has been set work in MGR mode also).
Mark
Posted on Dec 11, 2008
flexion1
  • 737 Answers
SOURCE: TEC MA 1640 Cash Register
Hi.
How do you know the clerk code is 1001. Is that what you programmed?
Mark
Posted on Mar 30, 2009
jackcity
  • 33 Answers
SOURCE: Casio TE 2000 Electronic Cash Register doesn't work.
u mean no power at all?
If yes, try to reset it. (NOTE: This method will RESET all of ur programmed data!)
1. Off power
2. Take out the AA size backup battery
3. On Power
4. The machine should show "0000000000"
5. Fix the AA battery in
6. Program the Date & Time
7. Ok
Posted on Sep 15, 2009
flexion1
  • 737 Answers
SOURCE: sharp cash register (er-a470) won't turn on.
If the machine is dead, then you probably have a bad battery. It should be changed every 3 to 5 years by the dealer. If it has been left too long, then this is a common symptom and the machine loses all programming. Otherwise, you may have a faulty power supply or mode lock unit. It sounds like you need to see a dealer about it. ------------------------------------------------------------------------
If anyone is looking for a Sharp ER-A470 manual, see here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
Many more available at
Posted on Mar 28, 2010
My sam4s er-180t cash register wont respond it just beeps and comes up with E00
try to do an 'initial clear'
turn power switch on right side of reg to OFF pos
turn control lock to P position
press and hold SBTL key and turn power switch to ON pos
should print 'Initial clear ok'
might need to repeat a couple of times
Jun 22, 2014 | Sam4s ER-180T Cash Register
How to fix E00 sequence error
To clear the error code do the following:
Turn key to P mode
Turn power switch off
Hold Subtotal key down
Turn power switch back on (while holding the subtotal key)
Wait for print out
Turn your key back to Reg position.
After you do this it will "Close" the register so you will have to log back on.
Jun 07, 2014 | Samsung Sam4s ER-5240M Cash Register
Casio te error 01 On normal reg selection all buttons are non responding to anything. On all other mode switches an error code 01 appears. What do I do?
Try this:
Turn key to PROGRAM mode.Turn power off at wall.Hold RECEIPT FEED down - keep your finger on it.Turn power on at wall.Wait 5 seconds, then let go of RECEIPT FEED.You should see "FFFFFFFFFF" on display.Press SUBTOTAL.Now turn back to REG mode. You may need to sign a clerk back on
Oct 18, 2011 | Casio Parts Cash Register PC Desktop
TEC MA-1650 Cash Register It appears the register has been put into a sub programming mode somehow and we are unable to get register functional again. When Register is switched to Set there is a P...
Perform a status clear.
turn key to blind(must be S key not mgr key) while holding zero key down turn reg on with power switch on right side.
reg will beep once & print reciept saying status clear.
this wil not clear programs or totals.
Dec 12, 2010 | Office Equipment & Supplies
What does an error eo46 reg buffer mean on a casio te2200 cash reg. The troubleshooting guide simply says it us full but indication of how to clear it :(
it means you have entered too many items into a single sale. Try this
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL. Now turn back to REG mode and try it. You may have to log in if you see error 8
Oct 05, 2010 | Casio Parts Cash Register PC Desktop
I used the PCR-T2000 casio cash register for 3yrs but it suddenly died ,comes on but the keys dont respond.
The standard flag clear should work on this model. Try this first (won't lose data)
Jan 25, 2010 | Casio Parts Cash Register PC Desktop
Casio tk-1200 stuck on error E-04
Firstly, try a flag clear. This will not lose any of your data:
Turn key back to REG mode and try it
Nov 30, 2009 | Casio Parts Cash Register PC Desktop
Casio tk 3200 cash register as stoped responding
Hi.
Try a flag clear:
Press SUBTOTAL.
Now turn key back REG mode and try it.
May 08, 2009 | Casio Parts Cash Register PC Desktop
Casio ce-3700 e01
Hi. You have turned the key before you finished what you were doing in another mode. A flag clear will jump you back to reg mode. Try this:
Turn key to program mode.
Hold RECEIPT FEED button down.
Turn power on at wall and let go of RECEIPT FEED after 5 seconds.
You should see 'FFFFFFF' on display
Press SUBTOTAL
Turn key back to reg mode and try it.
Mark
Sep 11, 2008 | Casio Parts Cash Register PC Desktop
E1 error message on a casio 220 ER cash register
Hi. Youv'e turned the key before you finished in another mode. Turn the key to each mode, and press clear, then try it back in reg. If that doesn't work, press CASh in each mode, or SUBTOTAL in each mode.
Mark
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
66 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
