Question about Tracrac 2003 Ford F-250 - 8 long bed - T-Rac Truck Bed Rack
How do i find out why my snow plow controler has no power
Checked fuse
My Curtis snow plow is all wired up but won't send power off solenoid if I you screwdriver to jump it the plow trys to lift but thats it
I had a plow that would work and we thought it was the controller. But I finally made a new controller with Radio Shack switches and diodes for $5 and it worked great and then I determined that I had a bad connection at one of the bolt connectors.
Nov 22, 2017 | Garden
Plow lights work OK, but why is there no power to joystick?
Bad connection in plug,bad wire, fuse or fusible link, faulty joystick.
press the helpful button and check link below
western plow problem Snow Plow Forum Let Talk Snow Discussion Forums
Jan 14, 2016 | 2002 Ford F-150
Boss v plow won't lift. Replaced motor and valve control. Lifted twice and quit. Now what do I do?
Check electrical connections to the Lift Pump. I'm not impressed with Boss's wiring
Jan 13, 2016 | Boss V-XT Poly Snow Plow
Does new 2014 4.3 engine with 285 hp have enough power to plow snow with?
According to snow plow review sites, there have been no issues with that size engine and an 8 foot plow blade.
Feb 19, 2014 | Chevrolet Cars & Trucks
Pump motor runs all the time
I would check for a damaged power relay for the pump. then check the wiring from the controls to the relay
Mar 28, 2013 | Curtis Sno-Pro Home Pro 3000 Snow Plow
I have an 88 chevy blazer with a myers snow plow when i raise the plow all the lights go out and the motor gets real sluggish i have been trying to figure it out but cant can you help me please
snow plows use alot of juice check state of battery if battery good check altnernator output may need to go with higher amp alternator or add a second battery
first thing to do is clean all connections leading to plow power and grounds (all of them ) and make sure there tight clean battery cables as well
next thing i would do is have battery load tested as this is probley the main cause as alternaotr working so hard to keep up it takeing all power from motor
if battery test out ok replace alternator with higher amp alternator
if still have problem after all that add a second battery to truck
Jan 29, 2011 | Chevrolet Blazer Cars & Trucks
Sno-way plow will not go up or down
I just bought a Snow-way series 22 plow 3 months ago and the remote has lost signal and get it back to responding, any ideas
Dec 13, 2010 | Ertl Snow Plow Toy Trucke
Western snow plow when you try to angle to right it goes up does same thing if you try to angle left
This is a control valve problem. From you comment, it is
clear that the control valve flows to one direction only.
Please check the control valve of the snow plow that
execute the angle to right or angle to left. Also check
the pipelines before and after the valve. It must have a
free flow of the fluid.
Oct 30, 2009 | Plumbing
Tracrac 2003 Ford F-250 - 8 long bed - T-Rac Truck Bed Rack Logo
70 people viewed this question
Top Tracrac Boating Experts
Lawrence Oravetz
Timllfixit
Are you a Tracrac Boating Expert? Answer questions, earn points and help others
