Question about Frigidaire Refrigerators
Where I can get parts for my Frigidaire FDL 5051? one of the AP1 or AP2 card may be defective?
Fan run fine, Compressor is in good condition and can run if directly connected to 115V. No visible alarm or damage to components.
  • Official Brand Answer
  • 2,267 Answers
Good Morning Yves Lelu, I appreciate your post!
I understand that you would like to get parts for your Frigidaire dehumidifier. You should be able to reach out to the manufacturer to purchase any parts or there may be a parts distributor within your area to help assist you with parts. Hope this information is helpful. -Matt
Posted on Dec 10, 2014
  • 10 Answers
SOURCE: kenmore frige model 59658692890 evap fan will not start
It won't run if unit is stuck in defrost.
Posted on Jan 25, 2008
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
  • 210 Answers
SOURCE: Refrigerator not cooling.
If the compressor is extremely hot, it could be seized, if this is the case you would have to have a new one installed.
Sgt 48
Posted on Jun 03, 2008
peyton32034
  • 410 Answers
SOURCE: freezer/ fridge not cooling, compressor not running
this refig has 2 independent temp controls one that operates the freezer side (this one also operates compressor, condenser fan and evporator fan) and one that controls the temp for the fresh food side this one operates a damper and evaporator motor.
I looked up you model number and you need to check the control that is located to the left side of the control panel or the freezer control. if it is 60f in the unit then if this control is good it should read infinity on a ohms meter. if its bad you will get no reading at all. alternatley you may try hitting the control solidly with the **** of a screwdriver sometimes the contact will hange open. message me back if you need further assistance. peyton...
Posted on Jan 28, 2009
Healeyman
  • 1198 Answers
SOURCE: Compressor and Compressor Fan Not Working
Rotate the dial on the defrost thermostat, a big click is when it goes into defrost, a little more and it should turn the compressor back on. By overload protector, do you mean the one under the compressor cover?
Posted on May 03, 2009
I have and Frigidaire model Number FRS3HR5J80. WHat wrong when a refrigerator will not stay cool buy if you unplug it for a day it will start back keeping cool and freezing?
depends on how long its running good and cooling and freezing but it does sound like a start relay or defective fan motor defective run capacitor can you remove the cover on the back. I need you to keep an eye on the condenser fan because sometimes they run fine for a while and then they stop running or they Slow way down and feel the top of your compressor to tell me how hot it is I want to know if its warm if it runs all the time or if it's too hot to touch or keep your hand on it. let me know what you come up with and I'm going to list out the parts that I think it is in my next comments
Appliance 911 Appliance 911 Sea Breeze
Aug 03, 2015 | Frigidaire Refrigerators
My Gree hansol split air conditioner wall mounted model gwh18tc-d3dna1a says it has a "Error U5" what does this mean
U5 Malfunction of current detection for the complete unit. A/C status, During cooling and drying operation, the compressor will stop while indoor fan will operate; During heating operating the complete unit will stop operation. Possible Causes, Therese a circuit malfunction on the outdoor unit control board AP1, replace the outdoor unit control panel AP1.
Mar 06, 2015 | Heating & Cooling
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
RED LED 2 BLINKING TX-32LE75C1
Likely the power supply board, here is a comment from another expert here regarding this set:
Check or have a repair tech check connectors AP1 and AP2. Vibration rattles the power supply board (a crappy design, as the board is almost "floating") and causes the wires in the connectors to break, and may make intermittent contact. Heat may also cause intemittent contact. A very common flaw.
May 02, 2012 | Televison & Video
My frigidaire is not getting cold. Is there a way to troubleshoot to detemine if it's the compressor gone bad?
Good day,
Here is a basic checklist any qualified tech would use to isolate why a refrigerator won't cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer or electronic defrost control.
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see, there are multiple reasons a refrigerator won't cool, or cool properly.
To zero in on the compressor might take you away from the true non-cooling reason.
However. The compressor might have a defective relay or thermal overload that would prevent it from starting or running. Theses items can be removed from the compressor and taken to any appliance parts houses. Most all would be glad to test them for you.
As well, the compressor could have a bad valve internally that would prevent the compressor from pumping refrigerant, or there could be a restriction in the refrigeration lines preventing the refrigerant from circulating properly, or the windings in the compressor could be burned out or shorted, or lastly, the system could have developed a leak. All of the above compressor related issues, except for the first one could only be checked by a qualified tech.
I would treat the problem as a whole with the compressor being one of the potential issues.
Not to throw a monkey wrench into this but a refrigerator is like a car.
9 out of 10 times the problem and solution are obvious. It's that last 10% that take all the training and experience.
May 19, 2010 | Frigidaire FRS26H5AS Side by Side...
Inside fan never shuts off. Freezes fine.
The fan is controlled by the by the electronic control located in the back by the compressor.
If the fan is running all the time there is something we need to determine before replacing parts.
Is the compressor also running all the time? The inside fan should run at the same time as the compressor, if they are both running then check and clean the coils behind the freezer. If they are clean and both running then check the door seal to make sure it is not broken or torn. If all these are okay then the compressor is just wearing out and getting inefficient.
If the compressor is not running and the inside fan is running the problem is within the control board down by the compressor, this is a replace only component and runs about $180.00
Apr 22, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
My frigidaire refrigerator does not cool? what should i buy for it
Good day.
12. Excessively dirty condensor
Thank you for using FixYa
Jan 17, 2010 | Refrigerators
Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Apr 22, 2008 | Frigidaire 9 cu. ft. / 255 liter Chest...
Refrigerators Logo
47 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
