Question about Video Game Consoles & Games
My wayne decade 2400 isn't working. it has zeros across the screen. what do I do?
Casio te 2400 cash tender will not work, pre
Try programming 8 zero's into the cash key in program 3 and program 1.
Aug 19, 2013 | Casio TE-2400 Cash Register
I have a Admiral freezer Model F1053. I was wondering how old it is and what you thionk it is worth if I sell it? I works fine.
I don't know how old your freezer is. These freezes can run for decades. About the only thing that will go wrong with them are, leaky freon which isn't producted anymore. It a against the law to own, product, distribute, black market it and freon based the R series, such as, R12, R16 etc. If this happen to your Admiral Freezer I don't think the make a retro-fit kit for it for modern day coolent 134a and some others.
If the conpressor is working and no rattles an it keeps food item frozen to about 14 or 16 below zero and it appearance is striking. I would it's awesome!! $50 to $125 max... GB stewbison
Aug 20, 2011 | Freezers
SAMSUNG V20 SCREEN WONT RESPOND AFTER I OPEN IT TO FIX A PROBLEM WAT SHOULD I DO NEXT
I have come across this issue before. I believe it was with a dell or Gateway laptop. The screen had been stepped on. I wanted to check the computer out before I replaced the screen. I connected an external desktop monitor. It worked fine. You just have to hope that the dual monitor feature is enabled. There's no way to do it without a monitor or active screen. I hope that helps.
Feb 20, 2011 | Samsung V20 XVC 2400 Notebook
I want to install c&c but ive lost the back of the manual. can i get a copy of the codes?
Here is a list of serial number that are sure to work.
S/N: C&C 4 Yuri_s Rache 042934-592829-117683-6047C&C Renegade 057292-943234-456307-2763C&C Generals 0850-3204838-2585127-0520C&C first decade 2SRR-T77D-WK2C-AEMI-RRORC&C zero hour 5PHR-7Z12-QKQS-L2MI-RRORC&C 3: Tiberian Sun 010688
Hope it was helpful?
Feb 05, 2011 | Electronic Arts Command & Conquer: First...
Lost install code for the first decade
RD4D4-B94XK-QVWFP-K9PJD-GVRV3
Generals: 8024-0694917-9155643-3730
Generals - Zero Hour: FDZ9-N4ND-2003-FGTI-G0IH
Red Alert 2: 025385-595761-836257-3121
Red Alert 2 - Yuris Revenge: 050033-901179-226773-2532
Renegade: 064723-604696-387942-5347
Tiberian Sun: 927314-304785-100746-0417
Glad I Could Help.
Nov 29, 2010 | Electronic Arts Command & Conquer: First...
My curser is stuck in the middle of the screen
change the mouse .If it works same as before after change the the mouse format and install.Again it same as before think your HDD has bad secter.so zero fill by dm
Nov 21, 2010 | Dell Dimension 2400 PC Desktop
I do dot have installer key coment & concuer tiberium twilight some body give to me???
By Beber :) First Decade:2SRR-T77D-WK2C-AEMI-RROR===Tiberium Sun: 011656-054475-265652-4285==Red Alert 2:020753-382048-832797-1403 Yuri: 043930-288237-966022-4511===Renegade:056894-929488-118387-9679 ===Generals:1234-1234567-1234567-6455 == Zero Hour: PWTT-SYTN-KAXX-33TF-AM38 By Beber :)
it should work..
Apr 04, 2010 | Electronic Arts Command & Conquer: First...
Turn tv on, shuts immediately off.
Same problem with my 28 inch 16:9 CRT Sanyo. I usually fix it by cutting the power to the outlet and then it works fine. Had it into the repair shop - and of course it never acts up there...
Jan 27, 2009 | RCA 27V520T 27" TV
Help
i had the same problem, so i took all of the batteries out (including the back-up battery) and then i hit the on button a few times. i then proceeded to reinstall all of the batteries, AAA first, and then the back-up battery after the calculator was already on. it works great now.
Jul 09, 2008 | Texas Instruments TI-83 Plus Calculator
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
