Question about Akai PT4799HD Rear Projection Television
Akai pt4799hd have no picture or sound and red flashing power ?
Type CM4202 Serial # 39ZX851711K - I did get power light on then it blinks - I do not have a manual so not sure what to do?
    Welcome Back:
    Visited the website for 2 consecutive days.
I had the same thing. I found that you buy a replacement lamp. See your owners book for instructions on hoe to replace the lamp. You can purchase it on AMAZON cheaper than having a repair mn do it. hope this helped.
Posted on Jan 09, 2015
Silverado1st
  • 8 Answers
SOURCE: No power to the television
Dont know if this will help, try leaving it unplugged over night, thaught I saw that solution in a blog somewhere a while ago.
Posted on Jan 28, 2008
Jon865
  • 6 Answers
SOURCE: akai pt5492
This could be one of many different issues. Main flaw with these units are as follows:
Blue picture tube leaks coolant onto neck board and mainboard causing problems.
Posted on Mar 11, 2008
ladywinn
  • 5138 Answers
SOURCE: akai pt4799hd service code
STK392-110s Do Not hold up some get so hot the pins fall off of them, USE STK392-180s always replace Both of them!
SERVICE CODE - Press Mute-1-8-3 with set on !
OK now use vol- and vol+ and ch- ch+ to adjust up&down-------- mute to stop where you need to ajust Press menu to adjust When done with alinement Press ADD to save your adjustments/ to change colors (7)sets RED (8) GREEN (9) BLUE.
Posted on Dec 23, 2008
  • 32 Answers
SOURCE: won't show picture but has sound
You can have numerous problems. I have the exact same television in my shop awaiting parts because they are extremely hard to find. The service manual is useless unless you have the diagnositc software adn operational software to properly test the television, so do not attempt to buy a manual online you will waste your money. The television is actually pretty easy to check if you have a multimeter, T10 torx screwdriver or T10 socket, and a philips screw driver. First of all remove the back cover from the television, do not worry about the screen assembly, it is flimsy but it is mounted on the inside to not go anywhere when the back cover is removed. Next remove the black voer that is mounted by 4 torx screws, the cover that has the projector part of the engine assembly sticking through, be careful not to damage the black foam rubber that is around the projector head. Once you have those two covers off, unplug the ballast power supply wire which is the white and black wire on the bottom of the ballast, the ballast is the cicuit board that is mounted in front of the big fan on the right side Also has two wire coming from the top that plug into the lamp housing. With a multi meter check to see if you have power going into the ballast (TV has to be plugged in and turned on to do this step). If you have power going in then turn the television off and unplug it and and plug the power supply wire back into the ballast. Next remove the lamp which is secured into place with the one screw on the left side. See if you have power coming out. If you have power coming out than replace your lamp. If you do not have power going inot the lamp than replace the ballast. If you do not have power going into the Ballast than replace the power supply which is part number DVL-U2830XC good luck in finding that part. If you have power going through to the ballast, and to the lamp and have replaced the lamp than replace the video board Part Number B0001, good luck finding that part. If you have replaced the Video board, ballast, lamp, and power supply and it still fails part your television out and make parts available for other people because the last thing is the engine assembly which costs 2999.00, yes that number is right Two Thousand Nine Hundred and Ninety Nine Dollars. Again, parts are very hard to come by for that model and unless your a customer like that one I have that actually wants it fixed don't bother with it.
Posted on Mar 01, 2010
  • 418 Answers
SOURCE: Where can I get the manual for my akai television pt4799hd?
Get chassis # off back. if P55A, use Samsung HCN4226W
Posted on Apr 14, 2010
Red light blinks
This issue is cause by power supply defective, need to replace it.
Dec 18, 2010 | Akai PT4799HD Rear Projection Television
TV went out and will not come back on. Power light shows red but no sound or picture. It's about 4-5 years old.
I have a akai tv, the tv went out but won't come back on. i'm still getting a red light but the tv just beep when I press the power button.
Sep 18, 2009 | Akai PT4799HD Rear Projection Television
Where can i get a convergence chip for PT4799HD akai tv?
I'm fairly certain that particular Akai model contains Samsung parts. You can contact Samsung at 1-800-726-7864 to check pricing and availability of the part you seek.
Jul 12, 2009 | Akai PT4799HD Rear Projection Television
BLINKING RED LIGHT AND NO PICTURE OR SOUND
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
May 27, 2009 | Akai LCT2701TD Television
My akai pt4299hd tv stopped working. it will not come on.
On AC power supply board there is 2 thyrisitor poor solder ,I have repair several of these with that problem.
Nov 20, 2008 | Akai PT4799HD Rear Projection Television
I have an akai 27 lcd tv which shut down while watching. No sound no picture but the power switch is flashing red.I don;t know if it is a power supply problem or a burnt out backlight.I haven't opened the...
I would suggest to start by measuring the voltages from the power supply to the main/back light circuitry. If the voltages are low or jumping up and down, that means a defective power supply.
If the red light is blinking, the power supply has a shorted component.
Let me know if you need further assistance.
Sep 05, 2008 | Akai Televison & Video
Akai pt4299hd
replace your STKs big black Ics STK394-250 there is 2 of them thses are your convergence ics.Also ck resistors and pico fuses.
Jul 22, 2008 | Akai PT4799HD Rear Projection Television
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
Akai PT4799HD Rear Projection Television Logo
94 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
