Question about Air Tools & Compressors
I have a prime mk246 compressor. i need the manuel guide and what is the price of it.
The air compressors is prime mk246 it's a twin tanks portable
Owners manual for Fini air compressor mk246 2.0 HP 4.3 gal twin stack. Year 2007
say try asking the mfg. here is a link to them. if thye can't help in there rply ask them if they can direct you to a site that can help you out. if service fails you go to sles they are most always willing to help becasue it may mean another sale for them. i get tons of help from sale jsut and fyi.
http://www.finicompressors.com/en
or try this usa site and the same thing try service then if no help go for the juggler and ask sales. good luck
http://www.nuairusa.com/
Sep 24, 2017 | HP Air Tools & Compressors
MK246: Is the 15 amp rocker switch a manual reset? My compressor started then stopped and can't restart.
if this ,Circuit Breaker
Part Number: 5134583-00 doesnt reset,it is under the cap,see pic,then,check pressure switch,
Pressure Switch
Part Number: 5130311-00SV
replace with this switch,the old switch is not made anymore,here is the parts list too
Jan 03, 2014 | Dewalt D55155 Emglo Air Compressor
Dewalt Mk246 won't run. , It's Brand Nu was
This is a common problem with this compressor and still is a problem in 2014.It is under powered and trips the reset
Apr 21, 2013 | Air Tools & Compressors
Air leaks continuously from bleeder valve on my rolair pancake compressor is it the bleeder valve or pump switch?
It will be the "Bleeder Valve" or it is more commonly known as the Check Valve, this valve is normally located going into the tank or connected to the tank, the pipe goes from the tank to the pressure switch, it normally sounds like air is coming from the pressure switch but its actually the check valve i mentioned.
First of all, make sure the tank is totally drained of air and the compressor is not plugged in. Next, unscrew the check valve top, and remove the spring and valve. Have a look at the seat of the valve, to see if the seat is damaged, clean it (if necessary replace it with a new one) then check inside the housing itself to make sure there is no dirt etc inside, clean it, then put it all back together again.
That should do it, this happens a lot on these smaller compressors
Mar 14, 2013 | Rolair Rol-Air Fc116022038 Valve Mk246
I need a pressure regulator fo a AC0205TT/03902 compressor
Pressure regulators are somewhat universal and can be replaced based on the pipe fitting size and or the pressure cut-out if you are talking about the pressure switch. No need to use factory parts. In many cases, the generic part will cost much less. To get an idea about sizes and prices, search ebay for regulator that looks like may fit and handle the pressure and volume needed. Lowes sells a line of pressure regulators that may work.
Dec 01, 2012 | Magnum Air 2 HP 5 Gallon Twin Tank Air...
How to get more hp out of a honda 5.5hp engine
Your compressor was designed to produce 11.8 acfm at 90 psi turning neer max rpm (depending on pully combination between 800 ~1100 rpm ) with max pressure of 135psi. At 3600rpm the engine is producing max hp of 5 to 5.5. More power would not really produce more air without potentially destroying the compressor pump by over-reving. If your compressor is not functioning properly you will not get good air flow. Check instruction manual for time period to fill tank from empty. Could be 2 ~3 min. It is takes longer then problems. You can tell how your pump is doing by periodocally checking the length of time to fill tank. The next size range of gas compressor is about 8~9 hp with four cylinder pump and will deliver about 17 cfm.
Mar 15, 2011 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Air Tools & Compressors Logo
244 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
