Question about Logitech Keyboard. Wireless Keyboard K350 920001996
Anywhere mx mouse makes the keyboard k350 inoperable
New anywhere mx mouse renders keyboard unresponsive. How can I fix
Is there a mouse that works with the kindle fire 5th generation? Bluetooth maybe?
Jodi, Yes, you can pair it with Bluetooth mouse and possibly through mini port. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Connect to Bluetooth
Kindle Fire Wireless mouse and keyboard on ICS
Using Qwerty Keyboard Mice and other USB device on Amazon Fire 2015 via...
Can you connect both bluetooth mouse and keyboard to Kindle HD Fire 6
May 03, 2016 | Tablets & eReaders
Bottom row of letters has died/is suddenly unresponsive. Can this be fixed?
Your touch sensitive screen seems to be broken. This normally means it needs to be replaced completely.
Aug 21, 2015 | Apple Pre-owned A1359 Ipad Keyboard...
What type bluetooth do i need to use with a kindle fire hd
Make sure the keyboard is really blue tooth. Most are not. Look on the underside of the keyboard to see if the usb dongle is hiding there much like wireless mouse's have.
Sep 23, 2014 | Amazon Kindle Fire HD
How do use external keyboard with tablet
You have to use a Bluethoot Keyboard, and also you can connect a bluethoot Mouse.
After that power on your keyboard/mouse and search in bluethoot for near by devices you will see your keyboard/mouse.
That simple.. I have a Perfect Choice (PC-200680) Bluethoot Keyboard with no mouse.
May 10, 2014 | Coby Kyros 716829701508 Tablet PC
The stylus for my gateway m280e is unresponsive, it is able to track the cursor across the screen but it can not select anything when double tapped, or write in one note? What could be the issue?
You can change the way the cursor functions. Here is how. From the "Start Menu", select Control Panel in the (right pane), next select Hardware and Sound, select, the "Mouse". In the Mouse, "Properties" (window) change mouse functions. "I hope this "Fix it"
Jan 24, 2010 | Gateway M280E
Logitech performance mx mouse does not work
Install set point and check if it works. www.logitech.com/download
Dec 20, 2009 | Logitech MX510 Performance Optical Mouse...
Both of shift key on my keyboard are always turn on..how to make it fix..?and i can't to restore the system..
i have the same problem.
I run the windows screen keyboard and i discovered that when i press both r+t keys and u+y both shifts are switching on. i'm not able to switch it off even using mouse on screen keyboard.
as temporary workaround i press fn key then i press shift on screen keyboard, then both shifts switches off.
i didn't fount full solution.
Jul 08, 2009 | Toshiba Tablets & eReaders
MX 510 freezing
Same problem been getting worse. Figured out that the mouseware driver is outdated and not compatible with win xp. Use logitech's setpoint for mx518 or uninstall mouseware. Now no more freezes
Oct 11, 2007 | Logitech MX510 Performance Optical Mouse...
Logitech Keyboard. Wireless Keyboard K350 920001996 Logo
32 people viewed this question
Top Logitech Tablets & eReaders Experts
Are you a Logitech Tablet and eReader Expert? Answer questions, earn points and help others
