Question about Copystar Kyocera Taskalfa 420i Multifunctional Printer, Cop
We have two Kyocera 420i's that report a jam first thing in the morning. there never is one. they open the front panel and close it and the "jam" clears and is OK for the rest of the day. Seen anyt
Two machines in same building, different floors. No other equipment is affected, so it seems specific to these two machines.
The answer is to put a thick sponge 1.5 inch x 1.5 inch on the front door to hold in the bypass jam access. it will back out and not cause any problem until the next day at power on
Posted on Mar 03, 2015
    Problem Solver:
  • 4 Answers
Clean the sensor at the back in the paper pathway.
FixSumo Find anwers ask about IT software and hardware products
Posted on Dec 09, 2014
How to fix error c2250 in kyocera taskalfa 420i?
You need to replace the charger, the charger is stuck and doesnot move, or if you have tech experience to remove the clip that locks the charger.
Feb 16, 2016 | Kyocera Office Equipment & Supplies
SAYS offline, HOW DO I GET IT BK ONLINE?
This is a network communications issue, most likely. If re-booting the copier doesn't change it, try rebooting the switch or hub it is connected to. I have seen Kyocera's take several minutes to report they are online following things as simple as being out of paper or a jam. Repeatedly trying things may cause it to stay in offline mode longer. If you are certain all panels are closed, paper and toners are in place, etc. and there are no codes or error messages, the machine should eventually be OK. If nothing works, it may be your cat5 cable or the socket in the machine. If the machine was moved with the cable still in, and it got a hard pull, there could be damage on the main board connections to the cat5 socket. that is sad and calls for board replacement.
Dec 11, 2014 | Copystar Kyocera Mita FS-C2126MFP Copier...
Eeprom TaskAlfa 420I
did u change or fix clean the efrom check the board
Feb 20, 2013 | Kyocera Mita TASKalfa 420i Maintenance Kit...
Kyocera printing black pages
Quite sure this is the main charger. Replacing it is best fix, but you must have heard this already.
Jan 22, 2013 | Copystar Kyocera Taskalfa 420i...
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
The printer is showing that paper jam but there is no paper in the printer.
Open the tray in the front and remove the toner cartridge, open the back panel and make sure that is is clear as well, and then slide open and closed the paper tray. Now reinsert the toner.
For some reason when this thing jams, if there isn't an actual paper jam then you have to check every panel before it will let you move on. You don't even have to remove any paper half the time...just open and close each panel and remove-reinsert the toner.
May 12, 2010 | Brother MFC-8220 Fax
Kyocera FS2000D. Paper jam reported occassionally
this is problem with sensor you have to check all the sensors like
registration sensor
duplex jam sensor
paper exit sensor
face down tray paper full sensor........
easy way to solve this problem is remove Durmunit and toner box and rear unit then clean it useing a blower and refix all the componet and try...........
Oct 06, 2009 | Kyocera FS2000DN Laser Printer
Kyocera FS-920 RED LIGGHT IS BLINKING AND GREEN LIGHT IS OFF
There are 2 possibility to cause your printer acting like this:
1) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
2) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
If it is condition 1) then just remove the jam paper then open and close the Top Cover to clear the error.
If it is condition 2) then insert some paper in the paper tray.
YBC (/\)
Jun 05, 2009 | Kyocera FS-920 Laser Printer
I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Mar 21, 2009 | Kyocera FS-2000D Laser Printer
Kyocera Mita 4230
it could be lots of things but for starters check to see if the other paper sources cause the same problem. try using the bypass one sheet at a time at first. second, there is a sensor shortly after or around the drum unit, if it doesn't activate it within it's specified time it will stop the machine, causing a jam.
thirdly is may be the transfer/ seperation issue, there also a couple of transport belts that may not be turning. check everything at let know if those things solve it.
Thank You,
Mikey
Apr 06, 2008 | Kyocera RI-4230 Black and White Copier
Copystar Kyocera Taskalfa 420i Multifunctional Printer, Cop Logo
113 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
