Question about Sharp AL-1631 Laser Toner Cartridges
Sharp 1631 copier toner drum seems to expell lots of toner into machine will not copy now puts black toner on paper splots all over paper
Cleaned machine then toner drum spills toner all over any idea whats wrong did not come on slowly it was all of a sudden Thanks
  • Sharp Master
  • 16,147 Answers
The corona wire is burned out might also be the fuser.
Posted on Dec 08, 2014
jimnfl
  • 17 Answers
SOURCE: Al-1631 Sharp copier
You could have one of several problems. Seeing as how you just replaced the toner, it could be a defective toner. Did you have the trouble prior to cartridge replacement? Did you replace it with OEM or after-market/refurbed stuff? You could also have a broken corotron wire. On the right side door is an assembly that has a very fine tungsten wire strung across it. This wire places a charge on the paper to "pull" the image off the drum. if it's broken, you will get blank (or almost blank) images). A 3rd possibility I have seen is that your scanner lock is on. Usually this will cause L1 codes, but I have seen cases where it didn't, and your scanner never moves from "home" position to scan your originals, again, resulting in no image being processed, and therefore blank copies. The scanner lock is under the scanner assembly (above the area where your copies come out) on the left side of the machine. It is a dial mechanism that can be turned to either the locked or unlocked position. It's hard to see, and you almost have to stand on your head to get a good view of it. It is not uncommon that in the process of removing copies from the "catch tray" area to accidentally brush it with one's hand, or watch, or ring, and spin it to the locked position. Certainly a bad drum can effect copy quality as well, but before spending the money, I'd check/re-check the other 3 first.
Posted on Feb 07, 2007
synthea
  • 10 Answers
SOURCE: AL-1631 TONER LEAKING
I had same problem for 6 months. Water didn't run on desk, so my unit WAS level. So, I just pulled out toner & drum and vacuumed up & sprayed air everywhere to clean up, then I made sure everything was tight (including side door where the little wire thing you have to clean occasionally with little green plastic square (supplied w\copier). That piece on door needed to be up and as far back as it can go (It does move slightly in and out - make sure it is IN). I then changed the drum (put same cartridge back) - only this time I made sure everything was really in place tightly. Not sure which fix did the trick, but it stopped leaking, and I've since copied over 400 pages since then and also had to change the cartridge after about 100 pages.
PS I also vacuumed underside the copier unit with tray out, and inside the paper tray as well. I've unsuccessfully cleaned everything up like this before, but 1st time I've changed drum, and 1st time I made sure EVERYTHING was tightly in it's place. Let you know if it starts to leak again. Hope this is helpful to someone out there.
Shari.
PPS. I am NOT using OEM drums or cartridges, but clearly THAT was NOT MY problem
Posted on Jun 29, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Sharp AL-1642CS making blank copies
You have a door on the right side of the machine. in that door is a thin piece of wire mounted inside a bracket. The bracket is white and is at an angle in the door. Do you see that now?
Posted on Jul 18, 2008
  • 29 Answers
SOURCE: Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Posted on Nov 05, 2008
Sharp Tech
  • 63 Answers
SOURCE: Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Posted on Oct 16, 2009
Testimonial: "Wow! A solution to my problem with a copier was posted within a couple of hours, and the procedure worked perfectly! Thanks. OB "
A copy has toner all over the right side on the paper.
Are you mean that toner isnt baked enough? If yes then you have problem with fixing roller bushings.
But if the toner is like printed, change blade and drum.
If the toner is like spiled on copy, vacume and clean the machine
Jul 01, 2010 | Sharp AL 1631 Copier
Sharp AL 1631 Grayscale Copier Placement of Shutter Film strip
you may have removed the toner receiver strip.you have to removed the drum from the assembly.you can remedy that with .5 inch masking tape.
Jun 09, 2009 | Sharp AL 1631 Copier
Black copies after water leak
check your toner cartrige and pull ot the drum unit, if they are wet they need to be replaced.
dry out that cavity where those 2 units go with paper towels. don't ever use canned air, it can blow developer into the drive gears. developer is 70% iron filings and 30% toner.
Good luck
Bob
Apr 15, 2009 | Sharp AL 1631 Copier
Sharp AL-1631
there is severl thing this could be 1. paper feed cluch need cleaned 2-bypayss roller lift arm need removed, 3-or the drum unit need clened out . all thses thing can be dones easilly by a sharp tech about $120 should do it. note this is the only model of copier left that you can refill the toner unit for $6 & drum for $15 ( id keep it )
Mar 10, 2009 | Sharp AL 1631 Copier
Black stripe and white stripe on copies
Black stripes can be down to dirty optics, unplug the copier and remove the glass, then clean all mirrors and the glass itself. If this does not resolve the problem, it will be the drum cleaning blade that has worn and will nedd replaceing.
Feb 16, 2009 | Sharp AL 1631 Copier
Nov 05, 2008 | Sharp AL 1631 Copier
Copy quality always light
Are you using a genuine OEM Sharp toner and drum? The paper pick-up rollers could use a good cleaning. Try a little WD 40 on a cotton cloth and clean the d shaped rollers. Also the feed clutch could be sticking. You have to take the back covers off to see the clutch. Clean and put some light grease on it. Easy parts to order and not expensive.
Aug 02, 2007 | Sharp AL 1631 Copier
Sharp AL-1631
Several things can cause this problem; The drum cartridge is not being cleaned properly or there is a problem with the toner cartridge . Take out the drum cartridge and inspect it for any signs of the defective image. If that doesnot solve the problem, then Call a tech.
Apr 20, 2007 | Sharp AL 1631 Copier
Sharp AL-1631 Laser Toner Cartridges Logo
56 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
